Ps3 fat Cechk04 no power
    master hoarder
    • May 2008
    • 12175
    Re: Ps3 fat Cechk04 no power
    Originally posted by stj
    the fat's have touch-sensors, slims have cheap tactile buttons.
    Yup, we are on the same page then with the case design.
    I'm still not convinced about the PSUs, though.
    Perhaps post PSU model numbers to be clear?
      • 31086
      i will take a photo or 2 on saturday - it's still in bits waiting for a shell (dont ask!) so no problem doing that.
      • ricardoito
        Rito
        • Jul 2020
        • 17
        • brasil
        Originally posted by Admirality
        Hi all my ps3 when plugged in just flashes green the ned and afterwards no led at all,pls help,it will be greatly appreciated
        The schematic is attached.
        • Admirality
          • May 2020
          • 80
          • South Africa
          Ok stj i tested 5vsb and that is ok,now i just need to test for 12v to check if the psu is ok but it is taking a while as i am working a day job and tired at night and want to be alert when working with electronics
          • Admirality
            • May 2020
            • 80
            • South Africa
            Hi ricardoito thanks for diagrams but my psu,a Delta EADP 260AP A has only 3 pins,pson gnd and 5vsb
            • Admirality
              • May 2020
              • 80
              • South Africa
              #26
              I am sure they work the same way stj,3 pin psu's i mean
              • Admirality
                • May 2020
                • 80
                • South Africa
                #27
                [/ATTACH]I have tested the psu and 5vsb and 12v is there so the problem lies on the main board and found this,are they capacitors?
                  • 31086
                  yes, ceramic caps
                  if just desoldering that fixes your fault then your very lucky.
                  • Admirality
                    • May 2020
                    • 80
                    • South Africa
                    #29
                    Thanks stj,but where do i find the value of the cap
                      • 31086
                      meter a good one.
                      it will probably be o.k. with one missing anyway - so just removing it is o.k. for testing
                        • 31086
                        it is:
                        22uf 16v X7R dielectric in a 3225 size
                        • Admirality
                          • May 2020
                          • 80
                          • South Africa
                          #32
                          stj much appreciated for all your help
                          • Admirality
                            • May 2020
                            • 80
                            • South Africa
                            #33
                            i removed the cap now and tested it,it comes on and has the green led and blue led and gives 3 beeps,does that sound right stj
                              • 31086
                              cant remember, it does different things if for example the settings are corrupt because you took the battery out for a while.
                              hook up a hdmi cable and check the screen - any usb joypad can be used
                              • Admirality
                                • May 2020
                                • 80
                                • South Africa
                                #35
                                Ok are the other caps around the bad one also 220microfarad
                                • Admirality
                                  • May 2020
                                  • 80
                                  • South Africa
                                  #36
                                  i just dont see the caps position on the schematic of side B board
                                  • sigmeyer
                                    • Feb 2020
                                    • 147
                                    • Serbia
                                    #37
                                    The blue lead is indicating that there is disk in the tray ... if there is not the disk in the tray there might me an issue with the CXR chip , or is detecting some kind of error... So did the ps3 come on? , does it turn off again?
                                    • sigmeyer
                                      • Feb 2020
                                      • 147
                                      • Serbia
                                      #38
                                      you can just visually check the area around that cxr chip and under it on the other side of board , if your disk drive is not working...
                                      • Admirality
                                        • May 2020
                                        • 80
                                        • South Africa
                                        #39
                                        Thanks sigmeyer,the ps3 after removing the bad cap comes on,the fan turns on then afterward it flashes red led,that is without the bad cap in
                                        • Admirality
                                          • May 2020
                                          • 80
                                          • South Africa
                                          #40
                                          Yesterday when i pressed eject it made a clicking sound,i am sure the owner of it told me that there is a disc still in the disc drive
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • dicky96
                                            Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
                                            by dicky96
                                            Hi guys
                                            I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
                                            If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
                                            If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
                                            03-24-2023, 06:33 AM
                                          • cajoeg
                                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                            by cajoeg
                                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                            02-10-2025, 04:01 PM
                                          • russpall
                                            LG 39ln540v - red light flashes twice, no power to LED driver?
                                            by russpall
                                            Hi there,
                                            I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                            The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                            08-27-2024, 01:07 PM
