Ps3 fat Cechk04 no power
  • Admirality
    • May 2020
    • 80
    • South Africa
    #61
    Re: Ps3 fat Cechk04 no power
    Originally posted by stj
    i know FSM - factory service mode.
    i'll have to look demo mode up.
    why did you want to update it?
    hopefully so you can hack it with custom firmware like "Rebug"
    stj what thermal paste should i use,maybe i used the wrong one,and i thought updating it is nesessary to keep it in sync with techno
    • diif
      • Feb 2014
      • 6978
      • England
      #62
      It's a PS3 that was delivered to shops to showcase it's features. I believe it has to be unlocked before put into safe mode and original firmware installed.
        • 31304
        i use MX4 myself, anything good enough for a pc cpu will work.
        as for updating, this is what you need to aim for:
        https://rebug.me/
        because you can put all the games on a harddrive and lots of other cool stuff.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #64
          https://ourpastimes.com/how-to-remov...-12577381.html
          http://www.edepot.com/playstation3.h...JJB1FAOwfpNZSY
          https://www.psxhax.com/threads/ps3-d...xwfRCNXJKS-Upw
          • Admirality
            • May 2020
            • 80
            • South Africa
            #65
            https://rebug.me/
            Thanks stj much appreciated
            • Admirality
              • May 2020
              • 80
              • South Africa
              #66
              vinceroger69 thanks for the great info,i really appreciate it
              • Admirality
                • May 2020
                • 80
                • South Africa
                #67
                diif there is a way to remove demo mode,that i will do when i have repaced the components i need to,thank you for your input
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • dicky96
                  Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
                  by dicky96
                  Hi guys
                  I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
                  If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
                  If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
                  03-24-2023, 06:33 AM
                • cajoeg
                  Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                  by cajoeg
                  Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                  The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                  02-10-2025, 04:01 PM
                • russpall
                  LG 39ln540v - red light flashes twice, no power to LED driver?
                  by russpall
                  Hi there,
                  I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                  The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                  08-27-2024, 01:07 PM
