Ps3 fat Cechk04 no power
  • Admirality
    • May 2020
    • 80
    • South Africa
    Hi all my ps3 when plugged in just flashes green the ned and afterwards no led at all,pls help,it will be greatly appreciated
    • 31015
    Re: Ps3 fat Cechk04 no power
    do you have more than 1?
    it's going to be faster if you can swap in a different power supply.
    • Admirality
      • May 2020
      • 80
      • South Africa
      No i am checking it for someone stj
        • 31015
        get the service manual - it will give you the pinout for the psu control cable
        then you can check the standby voltage and maybe even force the psu on without the mainboard.
        it may be shutting down because of a shorted capacitor on the mainboard though.
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          is it the nec tokin caps shorting out again?
          • Admirality
            • May 2020
            • 80
            • South Africa
            I checked for the 12v it is supposed to have and dont get a reading there on the power supply
            • Admirality
              • May 2020
              • 80
              • South Africa
              Thanks guys for your help so far,much appreciated
              • Admirality
                • May 2020
                • 80
                • South Africa
                What i also noticed is that it has a Delta psu instead of an original ps3 one
                  • 31015
                  there are several psu's used in ps3's
                  • Admirality
                    • May 2020
                    • 80
                    • South Africa
                    Thanks stj,where can i find a service manual with a psu to check for fault
                      • 31015
                      someone may link one here - they are too big for me to upload.
                      • Admirality
                        • May 2020
                        • 80
                        • South Africa
                        Thank you stj.
                        • Admirality
                          • May 2020
                          • 80
                          • South Africa
                          Hi has anybody got a schematic of Delta power supply on ps3 fat.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            The power supplies don't get a mention in the PS3 service manuals.
                              master hoarder
                              • May 2008
                              • 12175
                              ^ Indeed, or as far as I remember that is correct.
                              You don't necessarily need a schematic of the PS3 PSU to test it. Fat PS3 PSUs have 2 standard outputs: 12V and 5VSB (5V standby - always present when the PSU is plugged in the wall.)
                              The big round pins that stick out of the motherboard and connect to the bottom of the PS3 PSU are for the 12V (and ground/return) connections.
                              The 5VSB can be found on the small 5-pin white cable that connects to the front (or is it back) of the PS3 PSU.
                              Looking at the PS3 PSU so that the 5-pin connector is on the left side, this is the pinout:
                              Pin 1: PS_ON
                              Pin 2: Ground
                              Pin 3: Ground
                              Pin 4: 5VSB
                              Pin 5: 5VSB
                              First check the 5VSB with the PS3 PSU disconnected from the console, but connected to the wall. You should see 5V between pins 4/5 and any ground connection (i.e. pins 2 and 3 or the metal case of the PSU.)
                              If you have 5V, then your 5VSB is working normally.
                              Next, check the 12V output - that would be at the connector socket on the bottom of the PSU. Before doing this, it is recommended that you connect a load to the 12V output, just so the PSU is not running completely unloaded. A 12V PC fan or two or a car 12V light bulb will do fine (the car light bulb may be a better option, as you won't have to figure out the polarity of the plug, as long as it's an incandescent bulb, of course.)
                              Once you have your load connected, use a 50 to 470 Ohm resistor to jumper 5VSB to the PS_ON pin (hint: install the white 5-pin connector on the PSU and insert resistor in the connector on the other end.) This will enable the 12V output of the PSU. If you have 12V, the PSU is probably working fine.
                              On that note, the only fat PS3 PSUs I've seen go bad fairly frequently are the ones made by Nichicon (model number ZSSR539ia.) The ones made by Sony and Delta are usually pretty solid.
                              Whichever PSU model you have, NEVER test a PS3 with the top cover removed. Those PS3 PSUs rely on the top cover to get air circulated through them. Without that, they can overheat and fail. This is actually the main problem with the Nichicon PSUs - some of the components inside them are already running near their thermal limits, and that's why they fail so often. The PCB scorching seen on the Nichicon PSUs is a good indication of that.
                              Anyways, with the above tests complete... if PSU is still shutting down when connected to the motherboard but not when connecting an external load to it, then it may be the board that has an issue. Those fat PS3 boards have a lot of fuses on them, so test those out too. It's a fairly simple and quick test, so I always recommend doing it before assuming there is a bigger problem.
                              • Admirality
                                • May 2020
                                • 80
                                • South Africa
                                Momaka thank you very much for the info
                                • Admirality
                                  • May 2020
                                  • 80
                                  • South Africa
                                  On the Delta psu it has a 3 pin plug for 5vsb and obviously the 2 connectors for 12v to the main board,what would be the pin for p on gnd and 5v
                                    • 31015
                                    yes, the FAT i have in bits here is a 3pin plug too.
                                    you can find ground by metering to the metalwork,
                                    5v will have 5v on it,
                                    that will leave you with the control-pin
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      You sure you're not confusing the fat with the slim PSUs?
                                      All of fat (old style shiny top cover) PS3s I've taken apart had 5-pin PSUs.
                                      The newer smaller (slim) PS3s are the ones that have the 3-pin PSUs.
                                      In any case, I took what I call a slim PS3 PSU that has a 3-pin output. Looks like a Delta unit, model EADP-300AB. Pin out for that one, with the 3-pin connector on the left side when looking at the front of the PSU, is as follows:
                                      1: 5VSB
                                      2: GROUND
                                      3: PS-ON
                                      Exactly!
                                      With the PSU unplugged, first find the ground pin by using multimeter in resistance mode. The ground pin will have very low resistance to the case (3 Ohms or less, depending on multimeter capability to measure low resistance.)
                                      After that, plug in PSU but don't connect the 3/5 -pin cable and check which pin(s) have 5V. That would be your 5VSB. If none, then you're likely looking at a faulty PSU.
                                      PS_ON will have no voltage on it (or maybe in the range of mV). It's an active high input, meaning you have to pull it high (to 5V) to enable the 12V output of the PSU. Most TV PSUs are like that too. On the other hand, PC ATX PSUs are the oppositve: you pull PS_ON low (to ground) to enable PSU outputs.
                                        • 31015
                                        the fat's have touch-sensors, slims have cheap tactile buttons.
                                        the 3pin fat i have here is CECHM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • dicky96
                                          Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
                                          by dicky96
                                          Hi guys
                                          I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
                                          If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
                                          If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
                                          03-24-2023, 06:33 AM
                                        • cajoeg
                                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                          by cajoeg
                                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                          02-10-2025, 04:01 PM
                                        • russpall
                                          LG 39ln540v - red light flashes twice, no power to LED driver?
                                          by russpall
                                          Hi there,
                                          I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                          The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                          08-27-2024, 01:07 PM
