More weird HDMI problems...
  • spleenharvester
    • Mar 2010
    • 921
    I gave up on the HDMI splitter and started switching the cables manually using a coupler. I'm having issues with the following configuration:
    HP 24fw --> HDMI cable #1 --> Coupler --> HDMI cable #2 --> DisplayPort adapter --> Computer
    I have two brand new cables, and neither of them will give any output if placed in either position #1 or position #2. These cables both work fine if I skip the coupler as follows:
    HP 24fw --> HDMI cable #1 --> DP adapter --> Computer
    So they do clearly work and it would suggest an issue with the coupler/extra cabling. But where it gets weird is other brand HDMI cables I've tried in position #2 in the first example work absolutely fine with the coupler. I've replaced both the coupler and DP adapter for new ones of the same brand and the behaviour is unchanged.
    So why am I fussed if the other cables work? Well I'm worried it's going to damage something - one of my DP adapters died after a week's use and I'm wondering if it's something to do with this setup.
    Has anyone got any ideas why this would happen?
    Thanks everyone
    Last edited by spleenharvester; 05-13-2020, 02:11 PM. Reason: Split to seperate post
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • 31294
    Re: More weird HDMI problems...
    maybe volt-drop in the cables is too high
    • spleenharvester
      • Mar 2010
      • 921
      Yep I believe this is it - a split second after posting this (as always seems to be the case!) I realised I have one of those cheap passive HDMI repeaters. If I put that in place of the coupler all cables work fine! Hopefully the new DP adapter doesn't die on me...
      • spleenharvester
        • Mar 2010
        • 921
        Oh christ I just plugged my PS4 into the repeater and I'm now getting no picture on any monitor I plug it into. Has this thing just killed my PS4?
        Edit - starting a new thread, system is 100% WLOD now
          BTW, how long are the cables?
          • spleenharvester
            • Mar 2010
            • 921
            They're all a meter.
            • japlytic
              Certain DisplayPort-HDMI cables can disable HDMI CEC communication
              by japlytic
              With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
              An examination of the HDMI CEC wiring...
              07-10-2022, 09:48 PM
            • japlytic
              Certain "Class 2" HDMI cables can be marginal at 4K 60 Hz
              by japlytic
              For some time, a "Class 2" HDMI cable (part number BN39-01583B) supplied with a Samsung 4K 60 Hz display sometimes causes the display to overlay a few horizontal lines of flickering pixels of random colours and sometimes drops out, particularly on content requring HDCP.
              Since changing the cable to a thicker Class 2 unit, this problem has not occured again - do you know of other marginal "Class 2" HDMI cables supplied with displays?
              09-06-2023, 08:50 PM
            • aliougm
              Marantz SR4003 AVR HDMI board issue, seeking for help
              by aliougm
              I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
              Connection as below:
              Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
              If I bypassed AVR then HDTV screen color be good.
              I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
              3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
              I replaced all...
              04-30-2022, 12:21 PM
            • RossMoodley1967
              LG LCD TV HDMI PORT FAULTY
              by RossMoodley1967
              LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
              02-28-2024, 08:38 AM
            • budwich
              ESD Diode on HDMI output of Yamaha a1050 RCVR
              by budwich
              I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
              I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
              09-11-2023, 12:21 PM
