LG LCD TV HDMI PORT FAULTY
  • RossMoodley1967
    • May 2022
    • 8
    • South Africa
    LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
    • 22135
    Put make and model number in thread title ! ! ! https://www.badcaps.net/forum/troubl...n-thread-title
    • lotas
      • Jan 2016
      • 4859
      • Russia
      But this is bad, you will have to change this controller!
      Check the resistance of the HDMI signal lines, there are 8 of them relative to ground.
      • RossMoodley1967
        • May 2022
        • 8
        • South Africa
        Sorry for my ignorance , by signal lines , do you mean the signal lines at the HDMI port pins ... i am counting more than 8 pins. thank you.
        • lotas
          • Jan 2016
          • 4859
          • Russia
          There should be only eight of them and they go to the controller.
          • Gjackson
            Original PS4 BLOD after replacing HDMI port.
            by Gjackson
            Hi, ill try to keep this short. I got my hands on a PS4 with a mangled HDMI port and assumed that it would be an easy fix. before the replacement it booted up fine (white light) however after replacing the port it booted up fine for 2 times and then after plugging in an HDMI cable and turning on the console to check whether it had video out it never booted again, even after unplugging the cable. now it gets stuck on the blue flashing light and after 25-40 seconds it pops out the disk (if one is inserted) and shuts itself off. Upon investigating i found that the capacitors near the HDMI port are...
            10-22-2021, 02:14 PM
          • survivalbloke
            PS5 - no video but hdmi port looks ok
            by survivalbloke
            I'm a little green when it comes to consoles. I've done a fair amount of hdmi port replacement but not really any diagnostics. I've got a PS5 here which powers up but has no video output. I've also tried to boot to safe mode, also with no video. The hdmi port does not look damaged.
            Where do I go from here? Thanks!
            **UPDATE** I take that back. The external part of the port looks fine, but look at the pins to the mobo. Those pads are ripped off. How does this happen when the feet of the port are still sturdily soldered to the board?
            **UPDATE 2** The pads were...
            04-12-2023, 03:29 PM
          • SuperAman
            PS5 HDMI port diode reading?
            by SuperAman
            I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
            02-03-2024, 10:16 PM
          • amuse619
            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
            by amuse619
            Hello!
            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
            08-14-2024, 01:22 PM
          • Stephen
            A1707 20Vs works, faulty left charge port
            by Stephen
            Faulty left charge port, both ports do not work, swapped out port with good one no life on this side, no water damage. Board turns on and fully functions and charges on right side. So this rules out USB C chips etc. I am not seeing any power on both ports on the left side on J3300. Replaced diode that had solder balls under it and still no life on this port. Any suggestions would be great thanks!
            09-20-2023, 03:37 PM
