Yaesu FT726R Transceiver
  • llonen
    • Sep 2014
    • 495
    • hampshire
    So this came into the workshop recently for repair, sadly as per the norm I don't have pics of the current state of the ongoing repair, if I remember to when next working on this I might take some only due to the wide extent of the damage. Customer report not working no transmit no audio, bench report no audio (speaker disconnected ?) transmit sometimes, receive mostly but anything up-to 500kc off frequency random.
    Further findings were either full output power and or little to no output power, VFO unit PB-2445 not setting up as per service manual specifications. I had a source of one of these boards so a drop in replacement solved some of the transmit problems and put the receive back on frequency.
    Remaining problems of note, random low power output in the order of a few 100 mili-watts, found the drive ALC line to the RF modules was not as per service manual setup. Reluctant to make transceiver alignment adjustments to a radio that was very unstable I lifted a few of the electrolytic's for inspection some measured bad ESR but what suprised me most was the extent of the leakage onto the PCB. Removal of these SH%^y caps around 30 of them, deep cleaning the board and replacement with decent branded caps has brought about and good return to service of the board and radio.
    Now although the radio now works I am going to have to go through the remaining 5 boards and potentially replace the caps there as well.
    • 31007
    Re: Yaesu FT726R Transceiver
    what caps did it use?
    most old japanese stuff uses rubycon
    • CapLeaker
      Leaking Member
      • 8138
      That radio is very well known for the RX-TX relay going bad (sometimes it receives, other times not). Also if one replaced that brick in the 2m module with a new one (it's not exactly the same as the old brick), then you get the ALC problem where you have to turn up the mic gain all the way and I think you are still going to be short a few watts.
      • llonen
        • Sep 2014
        • 495
        • hampshire
        I am not sure what the caps were since I replaced the lot on the TX board and they went in the bin, I have a number of boards left to investigate so will let you know along with some pictures if I remember. The presenting problems were such that it was immediately clear the modules were not the specific cause, they are asymptomatic at preset. It was immediately clear from the assessment that the pair of relays on this board had been replaced or removed and re-installed at some point due to the cruddy soldering.
        Will keep you updated.
        • llonen
          • Sep 2014
          • 495
          • hampshire
          So I fished some of the detritus from the bin, other than Elna which I would not know much about other than they still seem to be available, the rest of them appear to be unbranded crud.
          See below, sorry if the pictures don't do justice to the PCB destroying sh&* that had leaked from them. If I remember to, will see to it that some pictures of the rest of the repair in progress are uploaded.
          For your viewing pleasure then oh and excuse the adjustments circularisation of said devices, they were not the easiest of things to grip with needle pliers, and no they were not torn from the PCB.
            • 31007
            elna are good for general use,
            i see the small ones have a mitsubishi logo on them!
            • llonen
              • Sep 2014
              • 495
              • hampshire
              Well radio is all reassembled and back to the customer, in all 70 plus bad and or failing capacitors were replaced, I never really got down to what was wrong with the VFO (PB-2445) and since the board was replaced it is somewhat academic anyway. Most likely it would be some borderline capacitor but I no longer have the radio to follow this up with, another happy outcome.
              • CapLeaker
                Leaking Member
                • 8138
                my guess is that the VFO was jumpy?
                • llonen
                  • Sep 2014
                  • 495
                  • hampshire
                  The VFO problem was one of many, it was very jumpy or unstable and would not always lock, furthermore it would not setup as per service manual alignment. I did find that changing the dial frequency would sometimes get it to lock but it was often off frequency in excess of 500kc on receive while inhibiting the transmit. Given the board was causing problems with service manual alignment checks it seemed a likely candidate and since I have access to a known good board at an economic cost that was where the repair was started.
                  I did get around to replacing the few electrolytic's but since the radio was working with the replacement VFO board and the remaining alignment checks carried out as per service manual I had little incentive in potentially replacing a known good VFO with one that although the electrolytic s had been replaced and solder joints checked was still suspect bad.
                  • CapLeaker
                    Leaking Member
                    • 8138
                    That's what I thought, as I dealt with an 726r before. Heck, that reminds me, I need a donor PLL board for an old IC-751.
                    • llonen
                      • Sep 2014
                      • 495
                      • hampshire
                      While I don't have much in the way of IC-751 donor parts, what appears to be wrong with you PLL board ?
                      • CapLeaker
                        Leaking Member
                        • 8138
                        got a weird problem I never seen before. The VFO works like a charm as it should and count's properly, but the VCO is weird. The vco works fine for the first 9.999khz, then it repeats the same signals in that 10khz window to every 10khz window to the full 100khz. Then the whole thing repeats with what ever I heard in the first 10khz window on the next 100khz, every 10khz to the next 100khz.
                        Are you still with me? lol
                        For example lets take 7.000.0 Mhz. I hear signals as it supposed to be from 7.000.0 to 7.009.9 Mhz. Then I hear the same thing again on 7.010.0 to 7.019.9 Mhz. Then its doing the whole smear over and over until 7.100.0 Mhz. Finally I hear new signals on 7.100.0 until 7.109.9 Mhz. So it repeats again the same signals every 10khz, until the next 100khz to 7.200.0 Mhz. It does this on all bands.
                        Makes my head spin reading my own crap.
                        • llonen
                          • Sep 2014
                          • 495
                          • hampshire
                          In many respects that is partly how this PB-2445 unit was behaving, while the display worked flawlessly for which ever band option was selected most of the time it would not provide a lock for the transmitter but when it did often it would be every so many khz this was either 30 or 50 khz for 145500 (two meter) it was slightly different for 70cm and 6 meter. The receive would also smear over and repeat itself. And this was all very unstable and intermittent, given the general bad condition of the components on all boards within the radio I suspect the problem would have been solved when I replaced the remaining capacitors on the PB-2445 unit but since by now I had a fully working radio it was not my inclination to strip the unit out and replace.
                          I would suggest pulling some of the caps around the area and inspect for leakage and test esr etc.
                            • 31007
                            does it use digital control?
                            maybe an old 40 or 74 series chip?
                            • CapLeaker
                              Leaking Member
                              • 8138
                              your issue is different than mine. Mine has to do something where the VCO isn't counting properly. The VCO voltage should rise as you go up the band. Well, mine jumps back. There is a contraption out of 2 IC's to make the VCO rising in voltage properly and my problem is the 10khz count is bad.
                              • CapLeaker
                                Leaking Member
                                • 8138
                                You are correct, it is an IC that has the problem (I verified it with my Oscope), but it isn't easy like a 40 or 74 series single IC. There are 2 IC's that together make these counts happening. I can't remember out of my head the markings off the IC's. However, look at a IC-751 schematic, go to the PLL board and look at the VCO section. Not having any old IC's like that, makes it hard to repair. I did see that the PLL board off a IC-745 looks the same as the IC-751, but I haven't gone any further to see, if it actually would work.
                                • shelby5041
                                  clock radio / radio lifespan?
                                  by shelby5041
                                  hi
                                  ive got a modern digital clock radio approx 15yrs old
                                  my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                  since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                  the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                  it uses very little power just a few watts i would imagine that may have something...
                                  09-14-2024, 03:30 AM
                                • UserXP
                                  Vintage SONY Digital Clock Radio ICF-C12W no audio
                                  by UserXP
                                  Dear all,
                                  I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                  i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                  My question is, do you know of this brand of capacitors and how bad are...
                                  07-21-2025, 08:35 AM
                                • praveenramavath
                                  Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                  by praveenramavath
                                  Hello All,
                                  I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                  https://www.hifivision.com/threads/m...-screen.98243/
                                  Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                  04-26-2025, 09:08 AM
                                  HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                  This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                  09-12-2024, 02:00 PM
                                • Omron
                                  Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                                  by Omron
                                  Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                                  My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                                  - Tried to unplug radio and plug it back in into power,
                                  - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                                  - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                                  05-23-2024, 01:27 PM
