PS4 loses date/time settings every time
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: PS4 loses date/time settings every time
    True to a degree and I must admit, the outside image is top notch, excellent, it certainly fooled me when I first came here...what do I mean by that: as I previously ranted in other posts of mine, which I can't help doing every now and then to let off steam, the work environment is far from ideal - with something this big and fancy, you'd expect only top quality tools and conditions, but no - far from it. Quite the opposite - MUCH worse than my former shop which would probably be less than a fraction of this one, if that and that was a small apartment ! That's the way it goes I'm afraid.
    I digress....
    Wattevah...
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Another thing I just remembered is that Mr. G said at one point that the problem might be the "clock" signal...now I'm a bit skeptical about that, I mean, not to contradict someone who's been in the electronics business some 20 years more than me, but just because it's got the name "clock" in it, doesn't mean it generates the TIME What he's referring to is obviously the clock circuit with the crystal and all that, but my theory is that if this were faulty in any way, we wouldn't have a PS4 that turns on with picture on screen, connects to wi-fi and plays sound and all that...
      Wattevah...
        • 30932
        well, if you want to shut him up, check the 32KHz crystal is running with a frequency counter or good meter.
        • CapLeaker
          Leaking Member
          • 7986
          I haven't seen any evidence that a "drifted off crystal" doesn't generate any time. As long as the crystal is working everything else should too. If the crystal is not "quite on the spot" it will result in time going faster or slower. Usually as the crystals age they drift down in frequency. This can be compensated by adding a little more capacitance at the crystal.
          I am siding with stj on the battery voltage not getting there where it should be.
            • 30932
            most faults i'v seen with crystals are either total failure, or massive shifts - like moving the decimal point.
            besides, it's more to shut up the guy who mentioned the "clock" signal than anything.
            • CapLeaker
              Leaking Member
              • 7986
              right on. Exactly my thinking stj.
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                #27
                Just my thought: a "clock" in this case does not refer to time ONLY - there's other functions that it governs which wouldn't have worked as well as they do...like the system turning on AT ALL and actually displaying stuff....all those rely on the clock signal.
                Wattevah...
                  • 30932
                  not that clock - there are many.
                  modern systems usually have a crystal running at say 14.318MHz that runs a PLL chip that outputs lots of different clocks all syncronised to the crystal.
                  but it's seperate from the RTC because it's power hungry and would trash a battery.
                  • petehall347
                    • Jan 2015
                    • 4423
                    • United Kingdom
                    #29
                    for fun i searched google for the answer last night . some hits said solved but wasn't solved .
                    https://www.google.com/search?q=Ce30...hrome&ie=UTF-8
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      #30
                      Yeh, I couldn't find a definite fix for that also, but maybe it's somehow related to the RTC issue in some way. I can understand it throwing that error if the clock was off (like any browser refusing to connect if the clock in Windows is way off), but it doesn't work even after setting the time...
                      Wattevah...
                        • 30932
                        did you trace the battery line yet?
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          #32
                          Nope - I don't have it on hand. The guy took it home, but he said he'll bring it back to me specifically for further digging. He's a colleague of mine.
                          Wattevah...
                          • CapLeaker
                            Leaking Member
                            • 7986
                            while you are at it and if you have the capability, measure the current draw on the battery. It is going to be really small, so you have to have special gear for that.
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              • Romania
                              #34
                              Hmmm...I have an Aneng meter which is supposedly sensitive enough to measure small values like that. The battery wasn't flat when I pulled it out if that's what you were thinking. Getting it in series with the battery might be the trickiest part...
                              Wattevah...
                              • CapLeaker
                                Leaking Member
                                • 7986
                                the point of is to see IF there is any kind of current draw. If no current is drawn, then the question is why isn't there any...
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  #36
                                  Makes sense. I'm expecting it to be very low, in the order of uAmps maybe...
                                  Wattevah...
                                  • CapLeaker
                                    Leaking Member
                                    • 7986
                                    yes, the draw will be very low. A regular current meter won't cut it here.
                                      • 30932
                                      too much talk - just follow the damned track!
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        • Romania
                                        #39
                                        True...now I just have to get my hands on it again. The chap hasn't shown up the past few days around here...
                                        Wattevah...
                                        • khaled1981
                                          • Oct 2019
                                          • 6
                                          • algeria
                                          #40
                                          change cmos battery brother
                                          • YG007
                                            Asus BIOS How To Reset To Default Settings?
                                            by YG007
                                            Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
                                            I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
                                            06-05-2023, 08:22 PM
                                          • titomno2
                                            Gaming Laptop Zephyrus S17 TFT not detected every time !
                                            by titomno2
                                            Hi guys,
                                            I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                                            So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                                            On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                                            Then the screen won't work for a long period of time.
                                            If I wait 1 or 2 hours it work again most of the time.
                                            When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                                            01-19-2025, 08:27 AM
                                          • i440bx
                                            Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
                                            by i440bx
                                            Hey there,
                                            I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
                                            The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
                                            It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
                                            As written above, I plugged in a new CMOS cell and checked...
                                            08-19-2024, 02:28 PM
                                          • throwaway327
                                            by throwaway327
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            06-18-2025, 05:52 PM
                                          • flat-earther
                                            Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                                            by flat-earther
                                            I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                                            To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                                            I have opened the camera and I think there is enough room to add something inside to accomplish this:
                                            The camera is powered by a 3.7V nominal single cell lithium ion battery.
                                            So I need to connect another battery in...
                                            06-08-2025, 02:00 AM
