Turn 100v X-box 360 adapter into 250v
    Re: Turn 100v X-box 360 adapter into 250v
    Or just use the 53 W you have right now and just do not connect the load to the power supply, the power supply will be in stand mode any way since the PS-ON will not be present so the power supply should draw very little current.
    • playman
      • Jan 2011
      • 252
      Allright I've made the load test and there was no fire (Must have done something wrong(grin))
      When the PSU is not connected to the Xbox I get a few ms of light on the bulbs and the PSU shows amber light.
      When I connect the PSU to the Xbox and turn on the Xbox the bulbs turn on bright for 1 sec or so and the Xbox starts and the amber light turns green, then the Xbox turns off the green light turns amber again and no light on the bulbs.
      Is the Xbox not turning on because of the light bulbs?
        Without having it connected to the XBox, do you get 5V the 5V wire?
        The power supply draws < 2W in standby mode (PS-ON is not present but 5VSTBY is present), then it will draw lots more current when it is fully turned on and loaded.
        At this point since the 53W lamp did not stay full bright (no load (Xbox) to the power supply), it looks to be working.
        1) You can now take a chance running the power supply without the 53W lamp in place.
        2) Or use 1K resistor between 5V STBY and the PS-ON pin then check and see if the switched 12V is present or not (no load (Xbox) connected to the power supply, but the 53W lamp is still in place).
        • playman
          • Jan 2011
          • 252
          I have 57W and 40W bulb connected.
          The 5v wire gives me 5v.
          I placed the resistor in and measured 12.45v and it ran fine for 7 seconds or until I disconnected it, had the bulbs connected.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            go go go time for the Halo test without the DBT
              Go ahead then without the lamp in place.
              • playman
                • Jan 2011
                • 252
                #27
                Just plugged it in and it powered on normally.
                Thank you so much for all that help!!
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Cool. another piece of electronics that would have been tossed in the trash salvaged for reuse!
                  • petehall347
                    • Jan 2015
                    • 4439
                    #29
                    well done . i would of course waited till i had another supply the same and wired in series to see what happens .
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      I had to hack a Xbox PSU for a bit higher voltage (13.8V instead of 12V, instead of upping the input voltage), was kind of annoyed at it because apparently they glued the SMT devices to the board along with the solder. GRR!
                        • 31199
                        the glue is because it was wave-soldered,
                        philips used to make all their tv's that way.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Makes rework that much harder...
                          Any good suggestions on how to deal with it, apparently mechanical force is one way though that has a risk of damaging the PCB...
                            • 31199
                            when the glue warms up it gets soft,
                            i used to use tweezers to twist the part loose after the solder melts.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Then the question is how do you know when the solder melted? That weird forked wire tool that comes with cheap chinese hot air guns becomes ineffective with glue, and tweezers have the possibility of dissipating heat causing the solder to resolidify...
                              At least that was really annoying to remove those things!
                                • 31199
                                you use the tweezers to hold the sides, not the contacts.
                                if it's a bigger package - like a chip, then melt the solder and flip the package by slipping the tip of a knife under the edge that has no pins.
                                if it's 4 sided - use a corner.
                                the "snap-off" blade knives are best - nice and long to keep fingers away from the heat.
                                • gabri2211
                                  Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
                                  by gabri2211
                                  Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
                                  This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
                                  This NEXUS connector broke.
                                  Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
                                  The Xbox has a power supply that provides 12 volts on all outputs, so the power...
                                  07-28-2025, 07:13 PM
                                • Satdude
                                  Xbox 360E won't turn on after voltage regulator shorted
                                  by Satdude
                                  Hello, I have a Xbox 360E Stingray where the 3.3VSTB regulator shorted and put 5V on the rail. I think the RAM and eMMC are on this rail. After replacing the regulátor, I get proper 3.3V but the console won't even turn on. Seems the eMMC is dead, I get power to it just fine but JRunner doesn't even detect the console when I hook up my PicoFlasher. Does a dead eMMC/NAND cause the console to not even turn on? Also does this with the eMMC removed, planning to downgrade it to 16MB NAND but want to know if it's a useless effort to save this motherboard. Thanks
                                  08-28-2024, 03:55 PM
                                • pajdek
                                  Lenovo Y700-17ISK turn on and off
                                  by pajdek
                                  Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                  09-20-2023, 02:49 AM
                                  HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                  This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                  09-12-2024, 02:00 PM
                                • RdeveLabs
                                  MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                  by RdeveLabs
                                  To all the members here...
                                  Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                  So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                  05-05-2025, 04:59 AM
