Help With Reassembling Basic 110 VAC Motor
  • Used_Cars
    • Oct 2015
    • 102
    My "Ridgid" brand shop vac stopped working in a puff of white smoke because I was vacuuming bees out of a junk TV set (while wearing a bee suit) and it started to "misty" rain. I thought I'd burned the thing permanent, so never tried to turn it back on.
    Disassemble the motor housing and extracted the Motor, disassembled the motor. Very simple, very basic. Visual inspection shows the brushes both look good, no scorching or burning on the stator, it spins freely, the cord ohms good, the switch ohms good and the ONLY thing I can see that might have shut the thing off is a 1 1/2" "something" inside a protective sleeve on the interior windings of the motor. Assume this is a current overdraw protection, or thermistor, or something.
    The windings ohm short where they should, and open where they should. I have very basic understanding of how motors work and that's where the question comes in.
    I don't want to wire this thing wrong and risk burning it up. I can't remember which wire goes where. I have one constant wire from the AC cord that goes straight to the motor, and the other wire goes through the big, main Power Switch before it also goes straight to the motor.
    I have four terminal clips to choose from, and I assume one wire goes on one side and the other wire goes on the other side, but I'm concerned that it matters which one goes where.
    One side of this motor has a big letter "N" next to where the brushing clips to the windings, and the other side does not. I assume "N" is for neutral, but is Neutral the switched side, or the common side? (Please correct my terminology, it's been years since I really needed to put this knowledge to use.)
    I can post pics if necessary. Hoping this text is descriptive enough to get help. Also hoping that it will work when I put it together, because disassembly and cleaning of the motor housing was a real PITA.
    Other questions:
    1) I decided not to lubricate anything inside the motor (grease, WD-40, etc...) because it would attract dust and eventually be a drag on the motor. Correct?
    2) What's this fabric covered thing spliced into the windings inside the motor? i.e. What's most likely; current overdraw or temperature protection? Both?
    I can post pics of all of this. It's right here on my desk next to my elbow. Thanks in advance.
    Re: Help With Reassembling Basic 110 VAC Motor
    Yes, post pictures.
    "the ONLY thing I can see that might have shut the thing off is a 1 1/2" "something" inside a protective sleeve on the interior windings of the motor" That this thermal protection incase the motor wiring gets too hot then it goes open circuit, so check to see if it shows resistance of <1 Ohm on that device.
    N = NeutraL
    L = Line
    They usually use single pole-single throw power switch to break the Line when switch is off.
    If they use Double-pole-single throw switch then they are breaking the L and N when switch is OFF
    • Curious.George
      • Nov 2011
      • 2305
      • Unknown
      Have you since tried to turn it back on? I.e., the magic smoke getting out suggests something has given up the ghost (it's not a "resetable" failure). Trying to turn it back on would confirm that.
      Is it a "one speed" vacuum? Is it reversible (blower)? Or, does it require you to move the "hose" to the exhaust port to reverse it?
      [The STATor is the STATionary part of the motor. The ROTor is the part that ROTates.]
      Have you verified isolation between each winding and the stator/rotor? I.e., that a winding hasn't shorted to the frame (even if the "other" continuity measures seem correct)
      [Imagine touching the shaft while it is powered up only to discover the LINE has effectively been shorted to the rotor]
      When taking a photo involved a trip to the drug store and a week's wait for the prints to arrived, it didn't make a lot of sense to photograph DAMN NEAR EVERYTHING. But, now, when you don't even have to PAY for the "processing" of the film and can view finished prints moments after taking them, its silly not to be taking photos every time you "do something".
      Polarized (3 wire) power cord? If so, the wire to the power switch is LINE (instead of NEUTRAL).
      NEUTRAL is electrically connected to GROUND -- GROUND being the "third wire" in the power cord. It often is not at GROUND potential owing to the IR losses in the NEUTRAL conductor (the GROUND conductor should never be carrying any current).
      Other questions:
      Correct. Any bearings/sleeves will probably be self-lubricating/sealed (e.g., sintered bronze).
      How many terminals enter/exit the "thing"?
      Please do. And, review them before posting (nothing worse than looking at a bunch of "flash blooms" that washout all of the pertinent detail!
      • Used_Cars
        • Oct 2015
        • 102
        Originally posted by budm
        Yes, post pictures.
        • Used_Cars
          • Oct 2015
          • 102
          Yes, post pictures.
          N = NeutraL
          L = Line
          The AC cord is two-prong, no ground wire. The white wire goes directly to the motor, the black wire goes through a switch before going from there directly to the other side of the motor.
          I double-checked the continuity tests. Calling the two sets of terminals posts "N1 and N2", and "Not N1 and Not N2":
          N1 to N2 reads open
          Not N2 to Not N2 reads open
          N1 to Not N1 reads short
          N2 to Not N2 reads short.
          I can post a pic labeling the posts, terminals, whatever the word is, for clarity.
          • Used_Cars
            • Oct 2015
            • 102
            No. Just assumed something fried and opened it up a couple months later.
            It's one speed. You "reverse" the hose to the fan's output to make it a blower.
            Thanks. Good to know I was at least in the ballpark.
            After reading this, I just tested all four posts ("N1", etc...) against the Stator and all read open. Which I assume means it's good. Also I just posted continuity tests between all the terminals in the post above.
            Assumed that since it was so simple, simple text might be enough.
            No, see above.
            No neutral to worry about here.
            Just noticed that the back side (away from the brushes) is a sealed bearing that also swivels.
            Four, see above
            Not my 1st rodeo.
            Also, just noticed that the plastic housing that holds the bushings can be installed both (180 degree) ways against the Stator, which puts the white sleeved "thermal protection" thing (what's it called?) either on the "N" side or the "Not N" side.
            • Used_Cars
              • Oct 2015
              • 102
              I decided to take pic and do a graphic of the continuity tests.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                Well that white sleeved thing probably has a thermal protection fuse inside to prevent a fire if motor overheats. If N1 is conductive to not_n1 then the fuse is probably okay. Determining if the windings themselves have a winding to winding short, you probably will need to look for a ring tester, or perhaps a low voltage transformer and feed to the Nx and Not_Nx poles and see how much average current flows (but you don't have a baseline, though comparing the two poles against each other probably is at least a start.)
                It looks like the winding 1 and winding 2 are wound antiparallel, so to get opposite poles at the stator, power needs to be fed in opposite directions. Hopefully the connections to N1 N2 not_n1 not_n2 are connected properly externally? Where/how do they connect? As they need to be fed in opposite directions, I'd guess N1 and N2, or not_n1 and not_n2 (N1 XNOR N2? ) are connected together externally if there's not a separate driver for each winding?
                Backing up, what exactly happened to the motor?
                Did the motor stall while it was powered up? This would be the most damaging part, not the water entering. The water entering the bearings causing it to stall, however, is a destructive act. Water on the commutator causing contamination can cause damage. But water vaporizing off hot windings actually should help cool the motor making it last longer (until salts deposit on it or the water causes thermal stress causing cracks on the lacquer.)
                • Used_Cars
                  • Oct 2015
                  • 102
                  I don't know what happened to the motor. As mentioned in the OP, I was busily minding my own business in a bee suit ruthlessly murdering africanized bees and suddenly my weapon stopped working.
                  Look. I didn't understand a word of any of that. "Fed" this and "Fed" that. This is freaking electronics, not Chef Ramsay's Kitchen. It's hard enough trying to remember 30 year old electronics training (that I never used), without all these euphemistic words being thrown around. I have a white wire and a black wire. I have two brushes. All four of those things need to be plugged into those four terminals so I can put it together and see if it works. The only difference between one side and the other is one winding has the thermal cut off device and the other doesn't. If I install these wires backwards, or if I put the wrong color wire to the thermal protection side, will the motor burn up? Will it run backwards?
                  Will an AC motor like this one run backwards if you reverse the wiring?
                  Does it matter which wire (black vs. white) gets the thermal device thing?
                  Looking at my continuity tests, it's obvious to me that each brush plugs into each side, and each wire goes to each side. The wires aren't going side-by-side, and the brushes CAN'T go side by side. So the only questions are the orientation of the "N" side of the housing (thermal device side or the other), and what color goes on the "N" side.
                  • Sparkey55
                    • Jan 2010
                    • 1523
                    The whole thing is a series circuit. The rotor windings are in series with the commutator brushes and the brushes on each side are in series with the field coils. The BLACK wire coming from the power cord goes to one terminal of the switch. The other switch terminal goes to one end of a field coil. The WHITE wire of the power cord goes to one end of the OTHER field coil. Remember that BLACK wire is HOT and WHITE wire is NEUTRAL. Never put the switch in the NEUTRAL wiring.
                    • Sparkey55
                      • Jan 2010
                      • 1523
                      You can check the thermal fuse by a continuity check across the field coil winding that it is installed in. Beep is good and no beep is bad (open thermal fuse). Most likely rated for 121 degrees C.
                      • redwire
                        • 3912
                        For the thermal cut-off, these are a pain to work with because you would have high-current crimp connections to it. Soldering a TCO is very risky, due the heat tripping the fuse. I crush open the eyelets with pliers.
                        Rigid Shop Vac thermal fuse replacement youtube vid microtemp TF121C
                        Don't worry about wiring it wrong and burning it out, you can put a light bulb in series to limit power, or even run it on a low voltage AC or DC power supply. It's a universal motor, AC or DC. They may even run slow on 24V.
                        I'd apply 20 or 30 weight motor oil to the bearings, one drop. It doesn't cause extra drag, as the load is the vacuum.
                        Don't run the motor with no load (impeller) and full mains voltage. It would over-rev and damage the motor.
                        • will62
                          • Dec 2016
                          • 229
                          • usa
                          For the wiring, go to about 4:45 in on this video:
                          https://www.youtube.com/watch?v=Ekx0-TJzOaw&t=456s
                            Wiring.
                            Once you have it all together, if there is no open circuit then you should see low resistance reading between the two blades of the AC plug when power switch is closed.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8706
                              Weird, the windings look deceptive in the pictures, thought that one was left hand wound and the other right hand wound. The connection diagram would imply both need to be wound the same way -- hence the curiosity on how it was wired before removal and a mere guess at how it was supposed to be connected.
                              As long as you don't shunt power and have everything in series, you should be OK though hooking it up wrong would not allow the motor to spin. If you were to just hook up power across one field and hook the brushes to the second stator (incorrect), then you could fry something...
                              • Used_Cars
                                • Oct 2015
                                • 102
                                Wiring.
                                Okay.
                                So the more I am forced to type out what I think I know, the more I actually KNOW what's going on. I've looked at this and thought about it enough to (think I) know that the only real question I have is which side of the circuit the thermal cut-off needs to be on (thanks, redwire).
                                Does it go on the white, common, "always felt" side, or the black, switched side? Does it matter?
                                Since I never tried to run the motor after it cut-off, I have no reason to believe that the components in the motor aren't 100% functional. The fact that the thermal cut-off side of the windings read short should be enough to show it's still good. It's never cut-off before. Seems unlikely to me that the one time it pops is also the time that kills it, but damages it in such a way that, when cool, it reads a short.
                                I intend to just put it back together and see what happens, but the one thing that holds me back is which wire goes to which side of the motor. As soon as I know that, I can start reassembling it and see if it still works.
                                FYI, I'd like to endorse this "Ridgid" brand vacuum. It has loyally served me for years of hard, professional use, vacuuming up the worst-of-the-worst, such as drywall dust and thin-set powder (used for tile installation, and is as small as drywall dust and much more abrasive). And also water, as I use it to take up spills, pump smaller amounts of water, etc... It also makes a decent blower for yard work, if you can get used to being tethered by a cord. And it's not nearly as loud as some brands I've used, "Genie" being the worst.
                                • Used_Cars
                                  • Oct 2015
                                  • 102
                                  Wiring.
                                  Oh. I posted the previous post before looking at your modified pic. I'll follow that diagram and post results. Thanks for the artwork.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8706
                                    Yes ideally the thermal cutoff is at the hot end of the chain - black/small blade/... side along with the main power switch and any other fuses. However thermal cutoffs were usually designed to be one-time and need to be replaced when tripped.
                                    Shop vacs are neat. I only have a small 1.5HP "shop vac" branded one that I used to ...
                                    ... vacuum out a yellow jacket nest...
                                    It started raining once when I had it set up to vacuum out the nest and it survived. Dodged a bullet there? Not sure.
                                    • Sparkey55
                                      • Jan 2010
                                      • 1523
                                      Okay.
                                      Like was stated earlier, a non-resetable thermal fuse, one that is designed to burn open circuit can not be reused. IF what you said in your original post is true about it shutting off then the thermal fuse is history. But IF you had the shop-vac connected to a circuit breaker type of power strip it is possible that the resetable circuit breaker on the power strip stopped the vac instead of blowing the fuse.
                                        BYW, based on this measurement you provided: https://www.badcaps.net/forum/attach...2&d=1521157574
                                        N1 to Not_ N1 did not show open circuit so that means the Thermal protection did not go open circuit.
                                        Once you put it all together to check to see if it shows open circuit or not between the AC plug's blades then we can go from there. Be careful on those brushes when putting them back together.
                                        • juergenb
                                          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                          by juergenb
                                          i am asking for some Help.
                                          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                          The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                          So i got a few of these from Banggood.
                                          I swapped the motor and now i have a new fault condition.
                                          In a working Frother you would press the start button, it will light red and work for a few minutes.
                                          If you press longer it will light blue and just mixup the milk.
                                          With the new Motor it just starts...
                                          03-23-2021, 11:24 AM
                                        • d00m178
                                          Philips toothbrush 4100 (HX369BK) - motor getting hot
                                          by d00m178
                                          trying to fix Philips toothbrush 4100 (HX369BK)
                                          The battery started draining quickly.
                                          After disassembling it, I discovered that the motor gets very hot when brush is off, which is apparently causing the battery to lose charge.
                                          The motor is connected to contacts M1 and M2.
                                          When I turn on the brush, 0.4V appears on these contacts, and the motor starts running as expected.
                                          But when I turn off the brush, the voltage changes to 3.8V—exactly the same as the battery.
                                          The motor gets so hot you can't touch it. And after 5 minutes, the battery drains to 0V.
                                          (To...
                                          11-12-2025, 03:11 PM
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
                                        • emeskay
                                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                          by emeskay
                                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                          08-06-2024, 07:13 AM
                                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                          by sam_sam_sam
                                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                          12-16-2023, 08:39 PM
