PlayStation 4 shuts off immediately after hdmi port repair
  • curt2199
    • Oct 2013
    • 54
    About to pull my hair out, picked up a PS4 with a botched hdmi repair. It would boot up fine to the solid white led. I removed the mess the previous “shop” made and installed a new hdmi port. Tested all the pins for continuity. I put it back together and now it beeps, turns blue, shuts off after about a second. The only info I can find is about sticking washers under the Heatsink bracket to temp fix an APU that needs a reball. I don't see how me taking it apart and repairing the hdmi port suddenly caused the apu solder to crack. The power supply testes fine and I also cleaned the apu and applied fresh arctic silver thermal compound.
    I'm clueless as to where to go next.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: PlayStation 4 shuts off immediately after hdmi port repair
    maybe a solder bridge on the hdmi pins have you got a microscope you can have a close look with
    • ecking767
      • Oct 2009
      • 492
      install the screws for the fan and all cables connections
      • curt2199
        • Oct 2013
        • 54
        I have a magnifying glass and good lighting. I soldered some sewing needles to the test leads on my fluke dmm so I could get in and probe each pin easily: I’ve doublechecked and each pin has continuity with the board and have also probed adjacent pins to make sure there are no bridges.
        Also from what I’ve read a problem with the hdmi port and chip wouldn’t keep it from booting up? Ifhat were the case it wouldn’t have booted up from the beginning because whoever worked on it before had 90% of the pins shorted together.
        • curt2199
          • Oct 2013
          • 54
          I don’t follow. There are no screws for the cables and fans.
          • ecking767
            • Oct 2009
            • 492
            the 2 long screws for the fan and the CD-ROM cable.install and connect it
            • curt2199
              • Oct 2013
              • 54
              There are two long screws that go through the power supply to the case but I don't see any screws to secure cables or fan? Are we both talking about a PlayStation 4?
              • ecking767
                • Oct 2009
                • 492
                I did the same repair on a PS4 with a bad HDMI port and poor soldering by the owner. replace the HDMI Ports confirm there was no solder bridge between each pins of the HDMI connector and install the main board into the case. Made all necessary cable connection.
                unit wouldn't power on white light, the only hardware was missing was the metal bracket and I didn't install the two screw, see picture
                once install the unit power on fine with a picture
                • jazzie366
                  • May 2016
                  • 304
                  The reball problem is so common with the PS line of consoles it pisses me off. I got a 10$ PS3 from a garage sale, exact same problem. Why in the fuck do they make the cooling so shit? There are tons of other companies online that will sell new coolers that work better and prevent that shit from happening. What the fuck, Sony.
                  Popcorn.
                    • 31072
                    ps3 reball is a scam, the heat from reballing is fixing a different problem.
                    the problem is special caps that short out - same as some toshiba laptops.
                    that and the thermal paste under the cpu cap against the silicon die fails.(fast fan issue)
                    • jondoe
                      • Nov 2016
                      • 547
                      https://www.youtube.com/channel/UCtf...eEY_vq_UOL4PDQ
                      There are some decent PS4 repair videos on this guys channel, among other things.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Sounds just like Intel push-pin heatsinks! And IIRC, Radeons, back in the pre-AMD Radeon era...
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • Dimitrios
                          • Nov 2013
                          • 127
                          • Greece
                          Just finished a repair like yours, my first actually. After putting new HDMI port had the same issue as before fixing being the immediate powering off. I also put some big washers on the screws and voila. Led light stays on and white but NO picture coming from HDMI, pity... Try the washers to boot.
                          • curt2199
                            • Oct 2013
                            • 54
                            I actually tried that with no luck. I've had terrible luck with repairing PS4 hdmi. Last one I didn't notice but had a tiny solder bit bridge the last two edge pins and powered on to smoke and dead ps4. Even with my microscope I missed the solder. I have 3 systems sitting on the shelf now. Lucky they were dirt cheap.
                            • RossMoodley1967
                              LG LCD TV HDMI PORT FAULTY
                              by RossMoodley1967
                              LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
                              02-28-2024, 08:38 AM
                            • survivalbloke
                              PS5 - no video but hdmi port looks ok
                              by survivalbloke
                              I'm a little green when it comes to consoles. I've done a fair amount of hdmi port replacement but not really any diagnostics. I've got a PS5 here which powers up but has no video output. I've also tried to boot to safe mode, also with no video. The hdmi port does not look damaged.
                              Where do I go from here? Thanks!
                              **UPDATE** I take that back. The external part of the port looks fine, but look at the pins to the mobo. Those pads are ripped off. How does this happen when the feet of the port are still sturdily soldered to the board?
                              **UPDATE 2** The pads were...
                              04-12-2023, 03:29 PM
                            • SuperAman
                              PS5 HDMI port diode reading?
                              by SuperAman
                              I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                              02-03-2024, 10:16 PM
                            • amuse619
                              Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                              by amuse619
                              Hello!
                              Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                              Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                              08-14-2024, 01:22 PM
                            • ktmmotocross
                              Ps5 pro - one beep and not start after hdmi port change and decoder ic reflow
                              by ktmmotocross
                              Hello.
                              Have this ps5 pro EDM033 that came with damaged hdmi connector. i replace it and console works for few days but show hdmi problems when cold start. so cold joint. reflowed connector and decoder ic as i think he have cold joint. but now i have only one beep and no start. can heatdamage of this decoder ic prevent start?
                              i have ps5 repair guide but not ps5 pro so link me to it if u know it
                              04-27-2025, 01:10 AM
