Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
  • amuse619
    • Mar 2024
    Hello!
    Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
    Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Does pin5 of this IC is connected to edp connector. If yes,note the pin number of edp and compare what it stands for. Very likely +3VLCD
    • ArchangelGabriel
      Aorus 17G YD laptop, broken display, could not switch to external monitor
      by ArchangelGabriel
      Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
      11-23-2023, 03:55 AM
    • maralexbar
      How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
      by maralexbar
      I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
      It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
      If anyone knows how to force the external monitor as primary for Notebooks of those models
      11-02-2024, 09:18 AM
      by momaka
      03-15-2023, 10:17 PM
    • keepread
      Dell monitor PSU vs Dell laptop PSU
      by keepread
      Hi there!
      Someone gave me their old monitor, it's Dell S2715ht.
      The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
      Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
      10-30-2025, 04:45 PM
    • fasda1984
      GS66 Stealth 11UE, it start only in external HDMI monitor, Internal display died
      by fasda1984
      , Hello have same GS66 Stealth 11UE, it start only in external HDMI monitor, Internal display died without crash or something, just started in black screen, checked driver in devices and have only external display, no more internal... Any suggestion? External working fine, no problems no errors
      06-22-2024, 01:43 AM
