Ps5 pro - one beep and not start after hdmi port change and decoder ic reflow
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3616
    • slovakia
    Hello.
    Have this ps5 pro EDM033 that came with damaged hdmi connector. i replace it and console works for few days but show hdmi problems when cold start. so cold joint. reflowed connector and decoder ic as i think he have cold joint. but now i have only one beep and no start. can heatdamage of this decoder ic prevent start?
    i have ps5 repair guide but not ps5 pro so link me to it if u know it
  • Gamingrepairsukk
    • Apr 2025
    first check for any shorts around ic and port, if all good remove ic clean all solder and attach again
    • aliougm
      Marantz SR4003 AVR HDMI board issue, seeking for help
      by aliougm
      I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
      Connection as below:
      Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
      If I bypassed AVR then HDTV screen color be good.
      I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
      3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
      I replaced all...
      04-30-2022, 12:21 PM
    • japlytic
      Certain DisplayPort-HDMI cables can disable HDMI CEC communication
      by japlytic
      With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
      An examination of the HDMI CEC wiring...
      07-10-2022, 09:48 PM
    • spleenharvester
      Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
      by spleenharvester
      I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
      I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
      03-12-2025, 03:42 PM
    • RossMoodley1967
      LG LCD TV HDMI PORT FAULTY
      by RossMoodley1967
      LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
      02-28-2024, 08:38 AM
    • RatherLoopy
      Pioneer VSX-44 receiver HDMI dropouts
      by RatherLoopy
      I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
      I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
      And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
      05-26-2023, 03:54 PM
