PS5 Dualsense controller stick drift a mainboard issue?
  • dbuergi
    • Jul 2024
    • 123
    • Deutschland
    I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
    I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components?
  • Unspun01
    • Jun 2011
    • 349
    Double check that you did not damage any of the traces to/from the hall effect potentiometer. Usually there is 4 pins: Vcc, ground, 2x poles. If one of these traces is damaged, or not making connection then the calibration will not be correct. See attached image. It is for PS3 but gets the point across.
    Not sure if this applies to your controller since I can't remember what is inside PS5 controller, but maybe will give you some hints. Also, double-check that the replacement hall effect sensor is identical to the original one. There can be some differences between OEM ones and aftermarket ones.
    • Mogens Riis
      • Mar 2025
      • Denmark
      If there is no hardware issue, maybe someone used the calibration tool and messed up.
      Try a fresh calibration with this tool: https://dualshock-tools.github.io/
      • dbuergi
        • Jul 2024
        • 123
        • Deutschland
        I unsoldered the stick checked eveything again and after soldering it back the problem still is the same. So there must be a hardware issue with lines our maybe caps? Anybody has an idea what to check?
        • m1ch43lzm
          • Mar 2019
          • 466
          • Peru
          Some things to try
          Check the middle pin on the left stick X axis potentiometer
          If using regular potentiometers, measure resistance from the middle pin to both outer pins, with the stick in the center position it should be around 1.15k, the potentiometers are 2.3k
          The potentiometer acts as a voltage divider, the aftermarket hall effect and TMR sticks send a voltage instead that corresponds to the position on the stick
          On one end you have GND, the other end is VCC, I think is 1.8v for the dualsense, not sure
          Check diode mode on your multimeter with red probe on GND, black probe on the middle pin on the board, you should get a reading there
          • Unspun01
            • Jun 2011
            • 349
            @dbuergi: You mentioned that you unsoldered and resoldered the stick. Did you replace the entire joystick with X and Y potentiometers or just one potentiometer?
            Do you have a different potentiometer to swap into the problematic one?
            Or perhaps you can swap the potentiometer/sensor between the X and Y axes on the same joystick to see if the problem moves from X to Y or Y to X etc.
            Swapping the potentiometer or hall effect sensor locations can help determine if the problem is with the joystick pot itself, or the location it is installed into. Then you can see if there is a trace problem or something else like a capacitor.
            • dbuergi
              • Jul 2024
              • 123
              • Deutschland
              Thanks for all the replies!
              The problem stays the same with changed axes even with or without installed potentiometers.
              I checked all lines for continuity and would guess that there is a.problem with a cap.
              Since i have no shorts is there any way to find "wrong" Ohm readings?
              • m1ch43lzm
                • Mar 2019
                • 466
                • Peru
                Hi, Please post pictures of both sides of the board, there are 5 revisions of the dualsense (BDM-***)
                Also a close up picture of both sides of the board where the left stick is located
                The traces from the sticks go directly to the main MCU, it may be broken somewhere
                • dbuergi
                  • Jul 2024
                  • 123
                  • Deutschland
                  Please find pics attached. The copper trace in the front was scratched by me because there was a lot of dirt and wanted to check for damaged. But the fault was already there.
                  • m1ch43lzm
                    • Mar 2019
                    • 466
                    • Peru
                    Measure voltage at the place where I marked 1.8v on the first picture, also measure voltage at the middle pin, marked "X" on the pictures
                    With the stick centered, voltage should be around 0.9v, moving side to side should vary from 0 to 1.8v
                    Also check continuity between the two points marked "X" (middle pin, and where you scratched the trace), it should read 0 ohm, if not, solder a jumper wire from the middle pin and the exposed trace
                    You may find this video useful
                    https://m.youtube.com/watch?v=cWUnZ7KjUIQ
                    The resistance measurements on that video are valid only with regular potentiometers, if you installed hall effect joysticks skip that part of the video, check voltages instead
                    • dbuergi
                      • Jul 2024
                      • 123
                      • Deutschland
                      Thank you for the Input buddy!
                      All lines show no voltages. Also soldering a wire between the X points didn't help even If there was no continuity.
                      Can i solder jumper wires from the marked points to get the voltages?
                      • m1ch43lzm
                        • Mar 2019
                        • 466
                        • Peru
                        Bridge only the 1.8v if it's missing on the X axis potentiometer, the "0.9" is the output of the potentiometer, measure it after you fix the 1.8v
                        Moving the stick left to right should vary the voltage at the middle pin (where I marked "X")
                        • Unspun01
                          • Jun 2011
                          • 349
                          @dbuergi: Inspect the soldering on the 1.8v line. The trace damage in your photo shows missing solder mask and it is easy to accidentally solder across the trace to the nearby traces.
                          Also, why so much melting damage to nearby plastic components? did you use a heat gun? There is a lot of melting to some of the white plastic connectors where flex ribbons go, and your reset button switch is destroyed.
                          A heat gun could also melt the plastic internals of the joystick so it will never work properly.
                          These joysticks have orange pots. Are you sure these are hall effect sensors? or are they TMR sensors? If these are TMR, they may operate differently than resistance pots or hall effect sensors.
                          • dbuergi
                            • Jul 2024
                            • 123
                            • Deutschland
                            i got this controller in a bunch of non working return shipments. Already looked like this.
                            The dealer on ebay offered them as hall effect sticks but the problem was there before.
                            Main fault was a damaged USB port which i repaired and now i try to fix the stick.
                            • dbuergi
                              • Jul 2024
                              • 123
                              • Deutschland
                              It's fixed! One wire did the trick. It's insulated copper but i will also ad a UV mask.
                              Thanks for the help of everyone!
                              • tommy97
                                PS5 Dualsense stick drift
                                by tommy97
                                I’ve been dealing with some stick drift issues on PS5 DualSense controllers. I’ve replaced the analogs on 4 different controllers using parts from 3 different suppliers (Mobile Sentrix and some from eBay), but I’m still getting slight drift, around 0.01 to 0.05 — only noticeable when zoomed in on the DualSense test GUI.
                                Anyone else had this happen even after replacing the sticks? Not sure if it’s the parts, or fault with the controller, or just how sensitive these are. Would really appreciate any tips or suggestions!...
                                08-07-2025, 02:19 AM
                              • Mirenia
                                Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                by Mirenia
                                I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                03-30-2025, 06:47 AM
                              • orcic
                                MASTER TL240 and new mainboard LW36BKC01
                                by orcic
                                I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                                The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                                After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                                Now I have some doubts about how to connect the new mainboard to the old power supply.
                                First of...
                                05-12-2023, 08:10 AM
                              • Devonavar
                                Vizio M43-C1 - How closely do I need to match the mainboard number?
                                by Devonavar
                                I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                                I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                                Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                                So, I've ruled out the PSU for now.
                                The reboot loop...
                                08-14-2022, 08:46 PM
                              • Malva
                                Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                                by Malva
                                I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                                Mainboard model: EAX65684604
                                PCB marking: EBT62954607
                                SPI chip: Winbond W25X20CLNIG Problem description:
                                Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                                After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                                • I bought another
                                06-25-2025, 02:07 PM
