Complete Xbox 360 Recap?? (Polymer)
  • Morinzo
    • Jun 2013
    • 14
    This is the original launch console and I'm wanting to try a complete polymer recap but don't know what values to use.
    Could someone make suggestions on what brand, V, uf polymers to use to replace the following caps.
    4 - 4v 820uf - Yellow & Black
    15 - 16v 100uf - Nichicon VZ(M)
    7 - 10v 220uf - Brown KY
    9 - 16v 1500uf - KZJ
    13 - 6.3v 2700uf - Rubycon MFZ
    Thanks For Any Help!!
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Complete Xbox 360 Recap?? (Polymer)
    These are most likely Fujitsu M series, which are functional polymers.
    Is there a main reason you want to replace them all with polymers? Because Chemi-Con KY, and nichicon VZ are good caps.
    You definitely want to replace the Chemi-Con KZJ and Rubycon MFZ. I would use SEPC or nichicon polymers.
    For the KZJ, you should get these: https://www.badcaps.net/store/produc...products_id=78
    And for the MFZ, you should get these: http://www.digikey.com/product-detai...228-ND/1826692
    • Morinzo
      • Jun 2013
      • 14
      Two of the caps are swollen like the one on the left in the img below.
      these are the yellow & black ones if they will help figure out what brand they are. You can see where I touched a soldering to one of the yellow ones by accident, lol.
        • 31293
        Fujitsu make - i think they are poly's
          master hoarder
          • May 2008
          • 12175
          You didn't perform a towel/hairdryer/heatgun reflow, did you? It's generally rare for caps in a Xbox 360 to bulge by themselves - at least I haven't seen many.
          The KZJ are known as unreliable series from Chemicon (along with KZG), but in Xbox 360s, I've never seen them cause a problem.
          As for the Rubycon MFZ - they are very low ESR caps similar to MCZ. Usually very reliable caps unless they are abused by heat. That said, the 360 does run a bit hot, so maybe after many years of use, they can fail. But in general, I consider them reliable.
          So what can you use?
          For the 16V 1500uF KZJ, you can use 16V 470 uF polymers. 560 uF, 680 uF, and 820 uF will also work, as long as they are all rated for at least 16V. Just whichever you can find cheaper (as polymer caps can be expensive).
          Suggested brand and series:
          Nichicon/Fujitsu - LE, LF, NU, and NE series
          Chemicon - PSA, PSC, PSF,
          Sanyo/Panasonic - SEPC
          For the 6.3V 2700 uF Rubycon MFZ, anything in the range of 2.5 to 6.3V and 820 uF to 1200 uF should be more than fine. Again, suggested brand and series are:
          Nichicon/Fujitsu - R5, R7, NU, NE, NS, LE, LF
          Chemicon - PSA, PSC, PSF, PSG
          Sanyo/Panasonic - SEPC, SEPF
          Fujitsu FPCAP RE series. These are functional polymers, just like some of the series I suggested above. They are very reliable. You don't need to replace these.
          Now, one thing worth mentioning is that if you don't have a very good soldering iron or station (minimum 60W and chisel tip), this recap would be nearly impossible. I know because I've tried it before. These boards have very thick copper planes and will suck the heat away from just about any iron. If you have a regular iron and not a proper temperature controlled station, it is best to pre-heat the board to about at least 50C (or higher if you can handle it with some gloves and manage not to burn yourself)... but not higher than 100C, of course. Flux is a must.
          As for the small 220 uF and 100 uF caps - you would blow a lot of money on these if you want to replace them with polymers. Moreover, they are in low-stress areas and don't fail. So polymers wouldn't really benefit you here... unless you are just doing it for the glory (but if you want my 2 cent worthy opinion, I consider that a waste since these boards will sooner or later fail due to poor cooling on the GPU and lead-free solder).
          • Morinzo
            • Jun 2013
            • 14
            No towel or heat method has been used, I've never had a issue with 360 but it is a launch day console so it is around 9yrs old and temp wise it used to run from 80c-85c. But I have 2 of the thermalright hr-03 heatsinks coming for it tomorrow so hopefully it will lower the temps some.
            These are the heatsinks I will be putting on tomorrow. This console is a Jtag so I don't use a disk drive in it.
            As for my soldering station I have a 70 watt Aoyue 968A+ SMD Digital Hot Air Rework Station, because I do alot of repairs and mod chip installs..
            • Morinzo
              • Jun 2013
              • 14
              I'm slowly removing the caps and I noticed that one of them had the GND pad that was lose from the motherboard before I even touched it, so when I install the new one should I just run a wire from the closest GND point to the leg of the cap? Obviously it's nothing major because the console was still working before I started removing caps..
                master hoarder
                • May 2008
                • 12175
                If you can solder the new cap's lead to that pad, then probably there will be no need to do that.
                • Morinzo
                  • Jun 2013
                  • 14
                  the pad was not attached to the motherboard in any way, so there is no way to attach it to it.
                  I'm not sure how or why the pad wa loose, i went to grab it before I touched it with the Iron & noticed it..
                  here is a schem to the cap with the loose pad, its C5B7 (Bottom Center). Will it be ok to attach it to any GND? Or should I find & attach it to the GND side of C8B1?
                  http://gyazo.com/d4b698c22e138cc6adea6c2db75faa86
                    master hoarder
                    • May 2008
                    • 12175
                    You can just attach it to the ground pad to the cap next to it. Or, if this is for the CPU or GPU VRM lowside caps (i.e. the 6.3V ones) and you end up using something like 1200 uF or 1500uF caps, then you may even skip it altogether and not install anything in that spot.
                    • Morinzo
                      • Jun 2013
                      • 14
                      ended up not being to hard to pull them if I use the hot air to warm up the motherboard slightly & then using the 70 watt iron.
                      Thanks for all suggestions so far..
                      • OriginalDaggers
                        XBox 360 All Polymer Capacitors
                        by OriginalDaggers
                        As the title says, Xbox 360 Polymer Capacitors, replacing all on a Kronos 1 revision board.
                        I went over a thread here (Xbox 360 with blown caps) and gather some extremely useful knowledge!
                        If I have things right, I can replace them TO
                        x9 : 1500uF 16V 10x20mm
                        TO: 470uF Nichicon FPCAP R7
                        x2 : 820uF 6.3V 8x12mm
                        TO: 2.5V 820uF Nichicon FPCAP R5
                        On this revision, there are other 820uF polymer capacitors for GPU/CPU - I'll be replacing those anyway with the above FPCAP R5
                        What's a good replacement for the smaller...
                        This can be anything from game consoles to arcade games to anything else that doesn't really fit into any of the above categories. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
                        02-20-2024, 12:49 PM
                      • TMTGTR
                        An Xbox One PSU Odyssey
                        by TMTGTR
                        Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                        =>Background:
                        I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                        06-17-2022, 05:40 PM
                      • Cartel
                        FORD 1996 ECU RECAP: Aluminum - Polymer worth bothering?
                        by Cartel
                        I will be pulling my crown vic ECU and recapping it. 3 in total, 47uf 16v x2 and a 10uf 63v
                        I hope they havent puked yet. I was thinking of replacing them with Aluminum - Polymer thru hole caps. probably 47uf 25v and 10uf 80v
                        They arent cheap. Anyone have any experience with them? Am I wasing my money on premium caps?
                        Nichicon PLV series
                        thanks
                        06-01-2025, 04:58 AM
                        HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                        This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                        09-12-2024, 02:00 PM
                      • grimacelord
                        Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                        by grimacelord
                        Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                        After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                        I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                        10-24-2024, 12:31 PM
