FORD 1996 ECU RECAP: Aluminum - Polymer worth bothering?
  • Cartel
    • Feb 2006
    • 112
    I will be pulling my crown vic ECU and recapping it. 3 in total, 47uf 16v x2 and a 10uf 63v
    I hope they havent puked yet. I was thinking of replacing them with Aluminum - Polymer thru hole caps. probably 47uf 25v and 10uf 80v
    They arent cheap. Anyone have any experience with them? Am I wasing my money on premium caps?
    Nichicon PLV series
    thanks
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    All older ECU’s I’ve done, I replaced the old caps with either Panasonic, Nichicon or Rubycon low ESR, low ripple, 105c rated caps. Never had a complaint with capacitors coming back and I like to keep it that way.
      • Jul 2011
      • 6070
      What are the issues when the capacitors go bad and how do you determine weather or not it is a capacitor issue or something else
        • 31283
        sam_sam_sam bad ecu caps usually leak on the tracks - specially Honda ecu's
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8351
          Also Ford, Toyota, Cummins, etc do all the same thing. First off is a complaint something isn't working, or engine runs like crap. Open up the ECU and you find leaked out capacitors, rotten holes and traces. Fix it up and to 90% that was it. Sometimes there is something else still not working, but that usually has a different damage. I also get water damaged ECU's and basically I end up checking each component on the board around that damaged area. It takes a long time to do an 18 wheeler ECU. Sometimes I get lucky like that excavator ECU with the burnt MOVs. I don't do ECU's a lot, but here and there.
          • Cartel
            • Feb 2006
            • 112
            I was thinking since Aluminum - Polymer has no liquid they would never leak. I dont plan on having the car another 30 years so maybe regular caps would be good enough
              • 31283
              yiou wont get polymers under 100uf,
              just use panasonic FC series if you care about AEC-Q200 rules.
              • Cartel
                • Feb 2006
                • 112
                PLV1K100MCL1
                  master hoarder
                  • May 2008
                  • 12175
                  Actually, I think there were a few Japanese ones that went as low as 47 uF. Forgot which brands and series, though.
                  Otherwise, I agree, I think Panasonic FC and FP series, along with United Chemicon LZA are the way to go, as those are all approved for automotive use (AEC-Q200 compliance.)
                  If the original caps are Nichicon PL, those are obsolete series now. Their current replacement is the PM series. I'd say replace them, because I've seen a few PL series start to show signs of "about to leak electrolyte from the bottom", though never seen any do it yet (not it my own stuff anyways.) The PR series are well-known for doing that, though. Being related and both quite old at this point, I can't say you'd be wasting money replacing them, at least if you intend to keep the vehicle for as long as possible.
                  BTW, also beware of UCC LXF series - same issue with leaking from the bottom like Nichicon PR. In fact, a lot of the early low ESR series based on quaternary ammonium salts​ had this issue. So these old series should always be checked and/or replaced, especially if they have been in a not-so-friendly environment, like automotive use (vibration and wide temperature swings.)
                  • Stanley1843
                    HP EliteBook 2540P - Aluminum Foil on Speakers
                    by Stanley1843
                    I have the HP EliteBook 2540P and when I disassembly the screen I cut accidentally one aluminum foil where it was on the top of the one speaker. What is the purpose of these aluminum foils on the top of the speakers....
                    09-07-2025, 02:54 PM
                    ASUS P5GC-MX motherboard recap
                    by momaka
                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                    So here is what the motherboard looked like with its original caps:
                    CPU VRM area up close…...
                    01-27-2021, 11:59 PM
                    by momaka
                    03-15-2023, 10:17 PM
                    no-name Radeon 9600 XT recap and cooler
                    by momaka
                    I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                    This one was actually suggested to me by ChaosLegionnaire....
                    11-06-2020, 07:54 PM
                  • souaqi01
                    surface pro 9 1996 bios
                    by souaqi01
                    hi any one plz help for unlocking bios surface pro 9 1996
                    SN : 0F020VR222400E
                    06-19-2025, 02:42 PM
