I just bought a used PS3 for 50 bucks that for the most part refuses to display any video. When I do get it to display the video it's mostly garbled and then the system freezes. I'll have to turn it upside down to temporary fix it. I'm tempted to attempt a heatgun reflow, or try baking the motherboard in the oven at 390 C. Anyone have any success stories or any tips they'd like to share on this repair?
PS3 Gpu problem
Tags: None
Re: PS3 Gpu problem
I would not recommend you bake the board in an oven. Too many things that can go wrong. At the very least, there's components on both sides of the board, so some of them may fall out. Plastic on the connectors may melt as well.
Besides, there's plenty of cheap heat guns that will do the job. I got mine pretty cheap from Micro Center (it's this one).
You will also need flux, preferably the no-clean type since you will be putting in under the CPU and GPU before the reflow.
Remove any thermal compound from the CPU and GPU before the reflow and put new one afterwards.
By the way, can you post a picture of the blue-ray ribbon connector on the main board? I just did a PS3 reflow last month, but was unsuccessful. I suspect the "tech" who reflowed it before me screwed up something, including the blue-ray connector (which looked damaged), but I'd like to confirm this. Thanks.Last edited by momaka; 11-20-2010, 12:30 AM. -
Re: PS3 Gpu problem
390C is too much. I always went with 210C over 7 minutes when i was using the oven. And no i never had any stuff fall out tho i did melt some plastic parts on an Asrock motherboard - that was because the oven's thermostat broke without me knowing it. Since then i've used my multimeter's temperature probe to monitor things.
Anyway before you try any reflow method please remove everything you can from the board, and see if the board is flat. If it's bowed forget about it. I had a Gigabyte AMD board that completely failed when i tried to reflow it because they used a plastic CPU backplate and over time the board bowed hard enough to damage the soldering. When i cranked the heat up on my hot air gun, i heard cracking noises. That was the chipset unsoldering itself completely because the board was so bowed.
Also if you want a reflow to last apply liquid flux prior to reflow and make sure the heatsink goes on real tight afterwards.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Re: PS3 Gpu problem
Originally posted by Th3_uN1Qu3Also if you want a reflow to last apply liquid flux prior to reflow and make sure the heatsink goes on real tight afterwards.Comment
Re: PS3 Gpu problem
Here are some pictures. The first picture is of the bluray cable and the next is the aftermath of the heatgun. I bought some liquid solder flux from microcenter... but it looks messy as hell... I'm hoping I got the right type. I blasted the gpu at around 220 and 240 C for 10 minutes. I noticed the board was kinda warping so I used some bolts and washers to try to keep it in palace. This is the 3rd time I've done this. The other two unsuccessful attempts I blasted it for around 5 minutes. If this doesn't work I'm probably going to sell it for parts.Comment
Re: PS3 Gpu problem
Wow, yours too? I reflowed mine twice, but nothing changed for me as well (was still getting YLOD).
Are you at least still getting the same problem or is your PS3 totally dead now? Or do you have the Yellow Light of Death (YLOD)?
Originally posted by Th3_uN1Qu3390C is too much. I always went with 210C over 7 minutes when i was using the oven.
Doubt the warping was caused from the heat because I reflowed mine twice, with the second time at over 400C. No warping or damage to the board whatsoever. Did you pre-heat your board? If not, peraps this could have cause the issue.Comment
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by huj3rHi there!
I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
Photo of the situation after the black shadow dissipates:
After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
> This indicates HFR Communication error. [ HFR Communication... -
Assuming...7 Photos -
Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
I'm new to soldering but the only feasible way to fix this issue is to do something myself.
MY QUESTION:
I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)... - Loading...
