Sharp Microwave - no backlight
  • gurj1979
    • Dec 2014
    • 186
    Need help fixing mums Sharp microwave oven combi.
    R-595 (sl)a
    Backlight has gone. Can still see digits buy super dim.
    Anyone with microwave experience help me out here ?
  • R_J
    • Jun 2012
    • 9580
    Re: Sharp Microwave - no backlight
    Are you sure it uses a backlight or is it a VF Display? post pictures of the control board
      • 31157
      is that really the part number? or is it R959?
      • R_J
        • Jun 2012
        • 9580
        If it is a R-959, the display is an LCD with 10 led backlights (D10~D19) in series with a driver transistor Q2
        • gurj1979
          • Dec 2014
          • 186
          You're correct. it's R959. I must have gotten mixed up with numbers.
          • gurj1979
            • Dec 2014
            • 186
            Thanks RJ. Sounds right about the number of LED's. There's a good few of them in series. So if I replace that tranny, then all should be good ? Do I need to replace and SMD caps too ?
              • 31157
              if the leds are in series a bad one will stop them all
              having said that - it doesnt look like they are driven hard
              • gurj1979
                • Dec 2014
                • 186
                It's gradually dimmed over a period of 1 year. So LED's are probably good, but the Driver has failed.
                Any idea what the tranny part number is, or equivalent?
                  • 31157
                  no, but try reading the voltage across each led instead of just blindly changing stuff.
                  did you meter the transistor?
                  • gurj1979
                    • Dec 2014
                    • 186
                    I'd have to desolder the whole LCD panel to gain access to the LED's behind it. Thanks Sharp. Lol.
                      • 31157
                      well if you can get to the transistor you can test that with a meter
                      10 leds in series is gonna need 20-30v so thats what needs to be seen
                      • gurj1979
                        • Dec 2014
                        • 186
                        Ahhh right. I can measure that. I'll try tomorrow. After that I'm on holiday for a week.
                        Will update this post after some results.
                        Thank you guys.
                        • R_J
                          • Jun 2012
                          • 9580
                          Looks like the supply for the led circuit is around 18 volts, Q1 is the regulator transistor, C4 is the reg. output cap, R4 seems to be 51Ω1W then there is another C10? 47µf/16v so the actual voltage for the leds is likely around 10~12v, the schematic gets blurry when enlarged.
                          • gurj1979
                            • Dec 2014
                            • 186
                            You're a superstar. Thanks for that info.
                            Yes I had that issue with blurriness too.
                            • gurj1979
                              • Dec 2014
                              • 186
                              What about Q2 ? It's directly connected to the LED.
                              • petehall347
                                • Jan 2015
                                • 4433
                                Q2 is the driver .
                                • R_J
                                  • Jun 2012
                                  • 9580
                                  Yes Q2 collector connects to the led string, the emitter connects to a 27Ω resistor which connects to the +18 supply. The transistor base gets biased on by D5,D6 and R5
                                  • gurj1979
                                    • Dec 2014
                                    • 186
                                    Thank you
                                    • stormanimal83
                                      • May 2014
                                      • 74
                                      ... sorry folks... never mind... but in my oppinion a microwave oven is dangereous to fix and not worth to fix... take care of what u doin and think about what i said... i would never ever open such a thing... not worth riskin´yours and others health...
                                        • 31157
                                        buy the guy a new oven then.
                                        there are lots of things that fail in microwaves that arent related to the high voltage capacitor.
                                        newer machines may not even have one if they are invertor-driven.
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • Misterfixit
                                          Sharp LC-58Q7330U No Backlight
                                          by Misterfixit
                                          This set has the known reputation of failed led backlights. The set does not turn on, but when plugged in, the power led stays lit for about 5 seconds followed by two short blinks and then it repeats itself. While shinning a flashlight on the screen, you can make out the Sharp logo, then it goes out and repeats the cycle. I measured some voltages across the led backlight connector. What has me puzzled is that when I place the negative lead of my vom on the led backlight pin connector (in which the black wire going to the leds was), I measure as high as -228volts, and then it falls to -95 volts...
                                          06-04-2023, 07:39 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Misterfixit
                                          sharp LC-50LB601U No backlight
                                          by Misterfixit
                                          I have a sharp LC-50LB601U that has no backlight. It starts up fine, and has sound, however, I can only see the screen using a flashlight. I took the tv back off and measured voltages at the power supply connector CN-8601. As you can see by the picture, the led connector has 2 sets of 2 red wires and 2 sets of black wires going to the led backlights. Between each set of black wires and corresponding red wires, I measure 30 volts (pins 1 and 4) and 30 volts from pins 8 and 12. From ground to each set of red wires ( pins 1 and 12 to ground), I measure 35 volts. This voltage seems very low compared...
                                          04-04-2023, 01:21 PM
                                        • DanPoka
                                          by DanPoka
                                          02-15-2025, 05:05 AM
