ps5 disc, white light, no display
  • Themi
    • May 2020
    • 79
    • Scotland
    Weird problem. I've got a ps5 disc with no display however the console gets to a solid white light and appears to be boot fine and getting to safe mode without any issue (getting to safe mode blind, I've got a recording of the menus from another ps5)
    So far I've replaced the HDMI port as it did look like one of the pins had broken however that wasn't the case and it was the plastic of the hdmi port sitting at an angle out of place. I checked the original port for shorts and found none but I haven't checked the new one (I'll do this when I disassemble it again).
    I can get the console to safe mode and have tried all the options apart from resetting via usb stick or updating and all of them appear to do exactly what they're meant to do but the display has not come back.
    I can get the console to the home screen (still no display) and sleep it so everything underneath appears to be working fine.
    So what to try next? New HDMI encoder? I would have thought if it was dead I'd have got a boot failure.
    Just looking for some ideas as it's a bit of a weird case.
  • Themi
    • May 2020
    • 79
    • Scotland
    Re: ps5 disc, white light, no display
    Measured values of the hdmi pins against known good values. All good. Replaced hdmi encoder and still no change. Also checked traces from apu to encoder and they’re all good too. Not sure what else to try if anyone has any ideas?
    • semtex
      • Sep 2021
      • United Kingdom
      White light means the console is booting up normal but you have no video output. this could be down to a bad hdmi port or a bad hdmi encoder chip.
      • Themi
        • May 2020
        • 79
        • Scotland
        Hdmi port changed and encoder for known good one still the same.
        Wondering if my issue is at the apu based on these voltages?
        • the old man51
          • Dec 2022
          • 11
          • yorkshire
          have u tested the filters for shorts...or is the small cap missing under hdmi pins right side
          • Themi
            • May 2020
            • 79
            • Scotland
            Yes tested for shorts + continuity from caps near apu to encoder and from encoder through filters to hdmi. Small cap at hdmi not missing.
            • the old man51
              • Dec 2022
              • 11
              • yorkshire
              check liquid metal for spillage
              • Themi
                • May 2020
                • 79
                • Scotland
                Top of the apu?
                • aktinson
                  PS Lover
                  • May 2023
                  • 18
                  • Bulgaria
                  Hi Themi,
                  This indeed is a puzzling case. You seem to have covered almost all bases - HDMI port and encoder replacement, checking for short circuits and continuity. Based on your description, it does seem like the APU is functioning correctly, given that the console boots up to a solid white light and even reaches safe mode.
                  The idea of checking for liquid metal spillage by 'the old man51' could be worth investigating. Liquid metal used for thermal management could, if it spills over, potentially cause shorts or interfere with the operation of nearby components. It's not just the top of the APU you should be concerned about, but the surrounding areas as well.
                  Also, I know this might sound rudimentary, but have you tried using a different HDMI cable or different display? Sometimes, the simplest solution is the one that's overlooked.
                  If all else fails, it might be an issue deeper within the APU itself or the graphics subsystem, which would be difficult to diagnose or repair without specialized equipment.
                  Hope you manage to solve this mystery. Cheers!
                  • nwcs
                    • Dec 2015
                    • 311
                    • usa
                    Did this ever get solved. I am in the same situation except that I changed the severely damaged HDMI port. I have done all that Themi has done and still not display.
                    • CapLeaker
                      Leaking Member
                      • 8324
                      Can you go into safe mode?
                      • ongobongo
                        • May 2023
                        • 58
                        Check the filters again, this time for cross-shorts. Maybe there is an issue.
                        If not, check the rest of the HDMI-circuit. I once had a PS4 Pro with the exact same problem. The problem was a blown resistor connected to Pin 18 (don't remember exactly which Pin it was.
                        • Reticula
                          • Jan 2024
                          • México
                          I have the same problem and I did the same process of fix. Can you fix the problem? How? Thanks
                          • ruletero
                            HP Omen only do not turn on, only flashes white light
                            by ruletero
                            Hi everyone
                            Please help me with this laptop
                            HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
                            It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
                            But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
                            Bios was programmed with a working version, no changes.
                            Voltages
                            +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
                            06-07-2023, 10:11 AM
                            RAB Lighting 30 and 48 White LED 9-12VDC Blinding Light Bars—> Very nice light bar
                            by sam_sam_sam
                            I bought these LED light bars from Electronic Goldmine surplus store online
                            These light bars are the nicest LED light bars I have ever seen in there online store
                            I read the description of these light bars and said yeah right there bright at 9 volts
                            Let just see if this is the case or not and just how bright is bright because I bought some of there light bars that they said were very bright and were ok but I would not say they were as bright as they claim
                            But I thought I would give these a try only because they had both light bars on sale as a bundle...
                            02-11-2021, 10:03 AM
                          • stevenallauca
                            HP laptop does not charge the battery, the light turns amber and then changes to white.
                            by stevenallauca
                            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                            - ACN (BQACN) 19.6v
                            - ACP (BQACP) 19.6v
                            - CMSRC (BQCMSRC) 19.6v
                            - ACDRV...
                            09-23-2024, 11:30 AM
                          • Ihandyrepair
                            sony 55X850D black screen no front white or red led light.
                            by Ihandyrepair
                            Hi guys
                            strange one
                            I have a dead Sony 55X850D
                            when plug in, black screen, no front white or red LED, no back light no screen
                            Voltages I get
                            3.3v LD/power and main board
                            reg 12V
                            reg 19V
                            3.3v on power on pin
                            no Tcon on
                            no tcon 12v
                            no BL_on
                            I do get BL_ERR 2.0v
                            I tried to bypass it by ground it but still get same symptom
                            I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                            or is possible the chip next to...
                            08-07-2024, 04:58 AM
                          • apostsamking
                            latitude 3350 blink 1 white light on
                            by apostsamking
                            Pls I have latitude 3350 laptop and it stop working. I realize that anytime I press the power button it powers on blink 1 white light on and off. I flash bios but the same problem. I realize that the 3.3v that's on the bios chip is not stable. It goes on and off. But when I remove the bios chip from the board power is stable. I have change the bios chip still the same problem. What should I do.
                            05-30-2024, 02:02 AM
