Bios dump for Dell Optiplex XE?
  • shippy
    • Dec 2016
    • 21
    • Romania
    Hi, does anyone have a bios dump for this model? or a method to extract the BIOS from the dell website? Thanks!
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Bios dump for Dell Optiplex XE?
    http://downloads.dell.com/published/...tiplex-xe.html
    • shippy
      • Dec 2016
      • 21
      • Romania
      Thank you!
      • OKRPKCOMP
        • Dec 2020
        • 439
        • PAKISTAN
        Can anyone extract bios bin from dell site bios????
        • hoaca388
          Badcaps
          • Jan 2022
          • 12325
          Here
          • OKRPKCOMP
            • Dec 2020
            • 439
            • PAKISTAN
            Originally posted by hoaca388
            Here
            Will u share how u did it pls????
            With wich soft????
            • hoaca388
              Badcaps
              • Jan 2022
              • 12325
              Use writeromfile command in cmd. For example, we have a file A05.exe -> A05.exe -writeromfile, the result is a file A05.rom.
                • 21853
                Its the wrong size though.You need the backup to compare it against and then youll know where to cut,edit or merge it.
                • OKRPKCOMP
                  • Dec 2020
                  • 439
                  • PAKISTAN
                  Yes sir, U r rite its size is wrong but amazingly its working with wrong size 1984kb instead of 2048, i check only display may be it create probs afterward.
                  so now i should compare it with old bios???
                  compare with which soft???
                  • OKRPKCOMP
                    • Dec 2020
                    • 439
                    • PAKISTAN
                    use writeromfile command in cmd. For example, we have a file a05.exe -> a05.exe -writeromfile, the result is a file a05.rom.
                    ty
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12325
                      I was also surprised at its size but I thought it might have to be some part of the original file but I don't have the original file to check.
                      • OKRPKCOMP
                        • Dec 2020
                        • 439
                        • PAKISTAN
                        This one original backup
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • mikeybass
                          by mikeybass
                          04-23-2025, 04:30 PM
                        • capoplays
                          Help with BIOS update on Dell G15 5515 after chip replacement
                          by capoplays
                          Hey everyone,
                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                          When I check the BIOS using the F12 menu Flash...
                          10-24-2025, 06:53 AM
                        • Akhlz001
                          by Akhlz001
                          09-20-2025, 07:15 PM
                        • jhanra
                          by jhanra
                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                          11-02-2024, 04:19 AM
