Replace memory module with lower density
+ More Options
Posts
  • Ken123
    • Oct 2021
    • 58
    • Sverige
    Hello. Im playing with the idea of using a Samsung K4ZAF325BM hc14 to replace a faulty hc16 on my rx 6800
    I have some hc14 on stock but no hc16 and want to get The graphicscard going until hc16 arrives.
    Is this possible?
    If it is do you loose 1gb or 8g vram in that case?
  • Ken123
    • Oct 2021
    • 58
    • Sverige
    Re: Replace memory module with lower density
    I was too curious. Had to try it so i just yolo it.
    It Kinda works and Kinda not. I did get image but i guess What happens is you loose 1gb and The gpu sends 2gb to that chip.
    Some parts of The image gets lost.
    Anyway i got to see that The graphicscard Will work when i get The new chips.
    Not only a loss atleast οΏ½οΏ½
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3570
      • slovakia
      did u even read and compare datasheets?
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Possibly you could get it working by flashing a BIOS of a card that actually have the same or lower amount of memory as what you installed.
        You can look in the Techpowerup GPU BIOS database for one.
        • Ken123
          • Oct 2021
          • 58
          • Sverige
          Nah 😜
          • Ken123
            • Oct 2021
            • 58
            • Sverige
            There is only 16gb bios there. But i found a supplyer in EU and ordered some correct ones. Should in 1-2 weeks. I guess i just need to wait πŸ™‚
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3570
              • slovakia
              There is no density difference dude!!!!
              • Themi
                Dell XPS 13 9310 2 amber 4 white memory failure
                by Themi
                I have this laptop a dell XPS 13 9310
                Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure​
                I believe this is the spec from using micron tool to decode marking
                Images of the ram
                I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
                Another...
                11-24-2024, 09:06 AM
              • repair-it
                TOSHIBA DLP 52HM95 How to reset timer module on bulb
                by repair-it
                I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                10-11-2023, 07:18 PM
              • m1ch43lzm
                70mai Dash Cam A510 - help identifying connector on camera module
                by m1ch43lzm
                Hi everyone
                I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
                The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
                I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
                05-11-2025, 06:02 PM
              • AlexVG
                Replacing the WiFi module on a vacuum cleaner iROBOT i7
                by AlexVG
                I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                (This board does not respond, only the LEDs light up in a circle.
                The liquid damage is catastrophic and restoration is impractical).
                (I bought this board to get the WiFi module and camera).
                The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                If...
                10-22-2024, 07:20 AM
                Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
                So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
                The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
                You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
                09-07-2024, 07:26 PM
