Gigabyte GA-990FXA-UD3 rev 1.1 No boot
  • mon2
    • Dec 2019
    • 14659
    Hi. Have a PC with about 8 years of field use that will not power on and post. Motherboard is Gigabyte GA-990FXA-UD3 with AMD AM3+ CPU.
    Have replaced the power supply; removed and reseated the CPU; removed the RAM; removed all cards - added an internal speaker - no power on beep for the missing ram or missing video card.
    Fans do turn on. Removed all SATA devices. No difference.
    Have access to the schematic and boardview for this unit. Any ideas?
    The sole power rail from the fresh power supply @ 3v3 is present. Have not placed any logic analyzer on the M-BIOS (yet) but could the bios have blown its brains out? Have a SPI flash programmer but that sounds extreme.
    Visually, all caps look ok - could not find any burnt looking components. Client said they did not do anything but turn it on one day and found it not boot.
    The replaced MB are $$.
    Welcome all suggestions.
    Have not reflashed a bios before for this motherboard - what is the procedure? Can hot air remove the SMD bios but the full bios dump should be applied onto this component (ie. full erase and full program)?
    The dump is available here or should be from Gigabyte website?
    Thanks!
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Gigabyte GA-990FXA-UD3 rev 1.1 No boot
    Do you mean you have the schematics or do you need them? I added here anyway
    Do you have any Vcore?
    Follow me on YouTube
    Learn Electronics Repair
      • 21841
      It has a dual bios so you can try the recovery method https://forum.giga-byte.co.uk/index.php?topic=15067.0
      The full bios is available at the support site,you just need to extract it https://www.gigabyte.com/Motherboard...upport-dl-bios
      • mon2
        • Dec 2019
        • 14659
        Thank you both. Very much appreciated.
        Will try to invoke the 2nd bios with the noted method and will report back.
        • mon2
          • Dec 2019
          • 14659
          Thank you again.
          The voltages appear to check out fine.
          Vcore @ 0v99.
          The 1v5 rail is ok.
          3v3 is present on the mBios pin.
          +12v is present.
          1v2 rail is present.
          I think we would like to give the BIOS reflashing a go. The pressing of both the RESET & POWER ON for 10 seconds did not impact this operation. Still no beeps out of the motherboard.
          On the BIOS download from the Gigabyte website, is this a raw binary file?
          Can this binary file be read into the flash tool and applied 1:1 ?
          The file extension is not .bin but rather .10e
            • 21841
            The *.10e file is the bios binary,Its 4096KB (4MB) .You can rename it to .bin , .rom if the programmer doesn`t recognise the file extension.
            • mon2
              • Dec 2019
              • 14659
              Thank you. Learning so much. Amazing info. Will report back...
              • mon2
                • Dec 2019
                • 14659
                Ok. Desoldered and reflashed the MBIOS IC (Winbond W25Q32) with the latest bios image from Gigabyte website. Verified ok.
                The original contents were non-blank but still did a full erase and applied the latest bios.
                Still no power on beep for the missing video card. Have the DRAM sticks installed at this time.
                Any other ideas?
                Could the CPU be dead? Looking into sourcing another AMD cpu for testing. Very strange the board would just 'die'.
                  • 21841
                  Did you flash to both bios chips .
                  • mon2
                    • Dec 2019
                    • 14659
                    No. only the MBIOS chip. The 2nd chip is under a heatsink. Should that IC be flashed with the same latest firmware (bios) image?
                      • 21841
                      The M should be main ,and B should be backup so it should be ok with the bios you flashed. I didn`t know the B was under a heatsink, i only asked to make sure you hadn`t just flashed the backup and not main.
                      • dicky96
                        Sun Seeker
                        • Mar 2017
                        • 1825
                        • Spain
                        Not sure what test equipment you have...
                        but are any of the clocks running (U185A)
                        What is happening with the CPU reset signals
                        • mon2
                          • Dec 2019
                          • 14659
                          Will check tomorrow. The reset appears to be ok. Checked against the cluster of 2n7002 gets. If #reset is pressed then the open drain lines are pulled low.
                          All caps appear to be fine and no low resistance across the caps.
                          Will study the clocks tomorrow.
                          Thanks.
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            Hello chaps. I have a fairly similar MB with a fairly similar issue, so I thought I'd join too, in addition to creating my own thread, in case someone's been watching this more than mine.
                            My board is a ga-990fxa-d3 and has pretty much the same symptoms: won't do anything upon hitting the power button aside run its voltage rails and spin the fan. No beeps, not nothing. All the voltages seem there, including VCore (CPU gets hot). I know the CPU and RAM are good because I tested them in another MB and they work fine (unless this bad MB killed either of them somehow in the process, which I doubt, because I used this CPU before in it and then moved it back to the functional MB and it survived).I found the schematic for my board (though no boardview, so if anyone has one, it would be great if you could share it) and I'm thinking of maybe replacing the clock chip on page 13 (ics9lprs477)...
                            I tried using one of those cheap POST diagnostics cards, which although FAR from professional, tells me there's probably something wrong with the clock chip, because the "CLK" LED is only dimly lit and flashes every 2 seconds along with the RESET LED. The LCD display of the test jig shows what you see in the pics, which is not very relevant. The CPU has Vcore and gets hot, so I assume it's OK.
                            What I tried:
                            -reflashing the M_BIOS SPI chip as described before
                            -replacing the crystals around the bottom heatsink for the SB where the clock chip is located, not knowing what each does at that time. Looking at the schematic, I now know X7 is the one connected to the clock chip itself. It's worth noting all of them came from another dead board I had around, so it's not guaranteed they're good (do crystals have a tendency to fail or don't like being heated up too much ?)
                            -I noticed that if I remove the ATX_12V connector so the CPU is not powered, the CLK LED DOES light up solid, which would almost make you believe there's something wrong with the CPU and it kills the clock line. Then again, I'm not sure what these cheapo diagnostics cards really look at in order to determine if that CLOCK LED should be on or off, since there are multiple clock lines - not just the CPU one.
                            Wattevah...
                            • dicky96
                              Sun Seeker
                              • Mar 2017
                              • 1825
                              • Spain
                              @DannyX
                              I don't know if this relevant but I have a POST test card where the RESET LED goes off when the reset switch is pressed, and comes on bright when the board is running. Like it works the opposite way round to what I would have expected. What happens with the CLK LED on your POST tester?
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                Actually, I stand corrected:
                                On a working MB, the RESET LED comes on when you actually hit the reset button (pull the RESET pin of the front panel connector low to GND). On the "bad" Gigabyte motherboard, it does the same thing, except it flashes every 2s as the board fails to start and keeps resetting. It stays on continuously if I unplug the ATX_12v connector, but not if I remove the CPU itself ! It's as if the CPU is not being detected, as it has little impact on the whole operation whether it's in place or not, though it DOES get hot and I get Vcore.
                                The CLOCK LED: it stays on in a functional MB and glows dimly on the Gigabyte one and flashes whenever the RESET one also flashes. It does this with or without the CPU in place. It goes out entirely if the ATX 12v connector is disconnected.
                                EDIT: I made another discovery, which for some reason I thought I had already made. The CPU I'm testing this MOBO with is an FX-8320....guess what: this is not in the supported CPU list over on Gigabyte's website....
                                A little backstory: this board belonged to a friend of mine who asked me to take a look at it once it no longer worked. He brought it in with his own CPU which I can assume was compatible, since it had worked till that point. He took his CPU back after a while and that's when I remembered I had this 8320 lying around, so I dug it out and without checking, just tossed it in the socket. Since it fit, I just assumed I could carry on trying to fix the MOBO, but it turns out it's not in the support list, so that is certainly part of the problem....I sure hope I didn't kill the 8320 too, since I DO have a good MOBO I want to use it in, so that would be pretty sad ! :|
                                Wattevah...
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  Ok, I actually managed to get mine working. This is what happened:
                                  After realizing the CPU I was testing with was not in the supported CPU list, I ordered the cheapest one I could find that was compatible. It didn't change anything: same exact behavior and messages from my post card. At this point I had nothing to lose, so I used some flux and hot air to reflow the Southbridge chip (bottom heatsink). Still nothing.
                                  I was then going to scrap the board and keep the two heatsinks, so after popping off the one on the Northbridge too, since the board was still hooked up to my test setup, I thought "meh - why not" and used a screwdriver to push down pretty hard on the NB. Get this: I heard like a "click" from the buzzer and the POST codes on my POST card suddenly started changing and going apesh!t... Realizing I may be on to something, I cut the power, added a graphics card and tried firing it up again normally. This time, I actually got some POST codes AND a beep ! Better still: I got picture and the BIOS began copying over from the backup one, so the board is now working ! Turns out it was the NB all along. I didn't bother to reflow it like I did with the SB, since I'm not planning to do anything with this board, so if it works it works. If it dies again, maybe then I'll hit the NB with some heat as well. It's highly unlikely it will last, since the solder balls are probably gone and will fail again if left unused - it's probably because the chip got warmer than normal when it had its heatsink removed that got it going and me pressing down on it was just a coincidence....
                                  Try it - nothing to lose.
                                  Wattevah...
                                  • taxxin
                                    • Mar 2021
                                    • 133
                                    • thailand
                                    Very nice read, I like the screw driver trick. i have 2 amd boards sitting here untested, so its great to know
                                    Successfully completed Repairs:
                                    Current repairs:
                                    • tlhIngan
                                      • Jun 2021
                                      • Country
                                      Just created an account to download that board view. I have the same board and it started no-POSTing and no-beeping a few days ago. I ruled out the power supply, RAM, video card and CPU by trying spares.
                                      Tonight, I took out the board to give it a thorough look and found a burned chip near a cap, next to the northbridge. I can't attach pictures with a new account. Hopefully, this is the (only) culprit and can be replaced cheaply.
                                      Thanks for the board view!
                                      • dicky96
                                        Sun Seeker
                                        • Mar 2017
                                        • 1825
                                        • Spain
                                        @tlhIngan
                                        You're welcome
                                        • kenkaniff
                                          HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                                          by kenkaniff
                                          Product Name: HP Pro x360 Fortis 11-inch G9
                                          System BIOS: U94 Ver.01.08.00 10/06/2023
                                          Serial Number: 5CG31946F5
                                          SKU Number: 85W05EC#AK8
                                          Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                                          This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                                          I needed to remove bios password...
                                          10-01-2025, 04:32 AM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • q2v5
                                          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                          by q2v5
                                          Lenovo T480s
                                          Model 20L8-S3TE00
                                          Board ET481-U10
                                          Chip MX25L12873F
                                          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                          08-15-2024, 10:40 PM
                                        • Neddsme
                                          Bios partially corrupted somehow and now warm boot doesn't work which is critical
                                          by Neddsme
                                          Hie.
                                          I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                                          Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                                          I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                                          I managed to run Windows troubleshooting and...
                                          02-04-2022, 05:57 AM
                                        • Max029
                                          Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                                          by Max029
                                          I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                                          I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                                          TY,
                                          08-18-2024, 08:28 PM
