Gigabyte GA-990FXA-UD3 rev 1.1 No boot
Ahoi mon2!Re: Gigabyte GA-990FXA-UD3 rev 1.1 No boot
Will check tomorrow. The reset appears to be ok. Checked against the cluster of 2n7002 gets. If #reset is pressed then the open drain lines are pulled low.
All caps appear to be fine and no low resistance across the caps.
Will study the clocks tomorrow.
Thanks.
Have you ever found out why your board went bonkers? I'm having Rev 3 here, it' showing the same symptoms...
Cheers, MadComment
by kenkaniffProduct Name: HP Pro x360 Fortis 11-inch G9
System BIOS: U94 Ver.01.08.00 10/06/2023
Serial Number: 5CG31946F5
SKU Number: 85W05EC#AK8
Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
I needed to remove bios password...-
Channel: BIOS Requests ONLY!
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by q2v5Lenovo T480s
Model 20L8-S3TE00
Board ET481-U10
Chip MX25L12873F
Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...-
by NeddsmeHie.
I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
I managed to run Windows troubleshooting and...-
by Max029I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
TY,
... - Loading...
