Zotac gtx-750ti 2gb vcore short
  • adelfr2009
    HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
    by adelfr2009
    I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
    After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
    09-28-2025, 10:21 PM
  • jm942
    Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
    by jm942
    My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
    I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
    I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
    I did voltage injection on the cpu with 0.7V and i have a current...
    07-11-2024, 05:11 AM
  • pavithra_uk
    Optiplex 3050 Vcore Mosfet short
    by pavithra_uk
    it is 3+2 vrm
    vcore high side mosfet (AON6380) shorted when turned on instatly killed the processor (i5 7400)
    gate drive chip (NCP81166) also gone.
    any suggestions before replace mosfet and gate drive chip? what if I replace 3 high side mosfets with more current capable mosfets?
    odd question:
    what if I put two silicone diodes series in forward way? assume each diode 0.7v drop and total of 1.4V. vcore not exceed this but can protect cpu from direct 12V hit from shorted mosfet ?...
    10-21-2025, 11:32 AM
  • T4H
    RTX 2080 ti (Zotac - triple fan) - No video output / Vcore / Vmem missing
    by T4H
    I have an RTX 2080 ti (Zotac - triple fan) with no video output.
    So far I have measured the following:
    • PS_FBVDD_PH3_SW = 40 ohm to ground (Micron ICs) - Memory should be fine right?
    • 12V power rail present
    • 3.3V power rail present
    • 5V power rail present
    • 1.8V power rail present
    • Vcore power rail missing --> PS_NVVDD_VREF is present. (from uP9512P / U812)
    • Vmem power rail missing --> Not there because Vcore power rail is missing.
    Any idea? I have already tried to flash the BIOS chip (backup got created) - sadly no changes.
    Source: https://www.techp...
    08-19-2023, 08:14 AM
  • tony359
    GTX480 short/vCore issue
    by tony359
    I have a weird issue with a GTX480 I am repairing for fun.
    Originally it would crash Windows when drivers were being installed. I checked with MATS and found a faulty RAM IC. I replaced it, MATS is happy but still the installation fails to install the driver - but no more BSOD.
    While testing I found something weird.
    What I think is the VCORE, is completely shorted. I read 0.4 Ohm to ground. I'm aware that low resistance is normal around a GPU but I don't think 0.4 is ok?
    If I check the inductors and all the mosfets,...
    04-24-2023, 03:15 PM
