A Lesson In How To Recap Profesionally.
  • User
    • May 2007
    • 36
    Re: A Lesson In How To Recap Profesionally.
    Oh dear Lord, this is so ugly to say the least.
    I don't claim to be an export in soldering technique, but damn dude.
    I think he did not use flux and couldn't get the solder to flow so he used butane torch thinking “oh, it just need all little more heat”.
    I'm sorry for rude comments, but some people need to do basic research on soldering before messing with soldering equipment.
    • Krankshaft
      • Jan 2007
      • 2328
      I wouldn't consider a blow torch soldering equipment unless you're working with copper pipe .
      • User
        • May 2007
        • 36
        I didn't say that blow torch is considered soldering equipment? Did I?
        I sad he does not have a clue on how to use soldering equipment and flux that is why he needed a blow torch to "GET MORE HEAT" thiking it would aid in solder flow.
        • kaniki
          • 514
          that reminds me of a situation i was in a while back. We were putting a new faucet assembly in for the shower/bathtub and the pieces/fittings had to be soldered into place. I had someone come over to help me and I asked if he knew how to solder pipes. he said yes and then asked where the soldering gun was. Im like huh?? Ended up finding out that he thought flux was something that you put on after you soldered to give a second layer of protection to make it water tight. He did not even know that flux was used to clean.. I took the stuff and said i would do it myself. Considering the bathroom was on the second floor, i did not need the mess... if you know what i mean..
          • ant3202
            • Jun 2006
            • 275
            • Singapore
            Imho Fail!!!!!!!
            Real Bad Soldering Skills!
            • DellUserHardcore
              • Feb 2011
              • 3
              #26
              I don't think the word skill was even anywhere near that guy when he did this LOL
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                Originally posted by hardwareguy
                I learned to solder when I was 9.... I built speakers from cheap Radio Shack 5" full range drivers and plywood with dad.
                Initially my joints were HUGE, sloppy and I had no concept of cleaning flux off of anything. Tinning the leads happened by accident because I used solder like I used hot glue but at least I didn't fry my speakers or melt the leads too much.
                So you can tell him that his "IT guy" got beat by a 9 year old kid.
                I built my first power supply when I was 12. The 5 volt one from "Building Power Supplies" by David Lines. Got that book from radioshack when they were still worth something. Still have it, too. Its original Nichicon filter cap is fine
                Ya liked building speakers as a kid, like me, hardwareguy? How many times were you told to turn it down?
                Why the hell would that 'IT guy' open the PS and check the caps? He probably buys antec's "it's normal for the ripple to exceed spec after a year" bullshit. Just the person NOT to ask "can you fix my 'puter."
                -Paul
                "pokemon go... to hell!"
                EOL it...
                All style and no substance.
                guilty,guilty,guilty,guilty!
                guilty of being cheap-made!
                • Lance Thornton
                  • Jan 2005
                  • 84
                  #28
                  All I can say is damn. I know everyone has to start somewhere, but usually it's on a dead board............
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5069
                    • New Zealand
                    #29
                    Well, you have to give the guy credit for the fact that he tried to use solder, rather than glue, or squashing the bulging capacitors down flat again.
                    Still, those photos make me cringe...
                    -David VanHorn
                    • smason
                      • 1652
                      That doesn't work? oopsie...
                      • Ami Sapphire
                        Extreme Lurker
                        • Sep 2010
                        • 180
                        This thread always gets me every time it resurfaces. However, I showed Mom the photos (and she does not even do electrical work!) and her response was "That's horrible."
                        Showed my sister after that. On the first and second photos: "What did he use to fix this, a flamethrower or something?" On the third photo: "It looks like a forest where all the tress were burnt down." Priceless.
                        Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
                        I have two v2s and one v1.
                        I am still looking at these boards nearly every day.
                        What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
                        • kaboom
                          "Oh, Grouchy!"
                          • Jan 2011
                          • 2507
                          That would be funny if it weren't true.
                          Years ago, this knucklehead in school assured me that he could connect wires with Elmer's glue. Another kid and I made 'flashlights' out of bulbs, wire and two D-cells. Those two worked. The 'wannabe' thought he could 'invent' a new method of connecting the wires. He promised he'd have it done over the weekend.
                          Well, Monday came and no third flashlight. Maybe if he used conductive glue!
                          EOL it...
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5069
                            • New Zealand
                            #33
                            Haha, what a Although I did say it because I know people have tried it.
                            Also I recall one of 'The serviceman' articles in EA detailed someone who had reconnected wires in a tape deck back together.. by tying them together.... in knots... and without removing the insulation first...
                            -David VanHorn
                            • piloteer
                              • 8
                              #34
                              Just saw this thread for the first time. You guys just ain't as old as me.
                              He cleary used a Black Beauty 500 Watt iron. A 400W would have been enough.
                              • moola
                                Banned
                                • May 2011
                                • 20
                                #35
                                Haha this thread made me lol...
                                  ASUS P5GC-MX motherboard recap
                                  by momaka
                                  Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                  This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                  So here is what the motherboard looked like with its original caps:
                                  CPU VRM area up close…...
                                  01-27-2021, 11:59 PM
                                  no-name Radeon 9600 XT recap and cooler
                                  by momaka
                                  I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                  This one was actually suggested to me by ChaosLegionnaire....
                                  11-06-2020, 07:54 PM
                                • varunviolin007
                                  Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                                  by varunviolin007
                                  Hi guys,
                                  I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                                  I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                                  Looking for someone experienced with older PC boards who uses...
                                  07-29-2025, 11:53 PM
                                • Foetuss
                                  Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                  by Foetuss
                                  Hi all
                                  Hope this is in the correct place.
                                  I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                  Could use some double checking to see if I'm not doing something stupid .
                                  Pictures of the boards are attached.
                                  What I will be replacing with what : (planned)
                                  Soltek Golden ::
                                  4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                  6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                  01-18-2025, 11:44 AM
                                • Guest
                                  A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
                                  by Guest
                                  Hello all!
                                  Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
                                  After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
                                  09-26-2024, 03:31 AM
