Epox 8RDA3+ Recap My First Poly Mod
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Hi, this has been one of my favourite mainboards
    It's gone through allot of CPU's and different memory, I've owned it since November 2003. It now has 2GB Corsair TWINX2048-4000PT memory in it that only cost $400 when I bought it December 2006
    The CPU it uses is a Mobile Athlon XP-M Barton clocked to 2300Mhz
    Lately it has been commisioned into a HTPC at my parents place, I bought a ATI 2400Pro graphics card for it, it's connected to a Sony KDL-40D3550 LCD TV
    Last month or so it started locking up, it had been running rock solid up untill then at this OC, for several years...
    So I placed an order with Big Pope, since this mobo has such a sentimental value for me I thought I'd go overkill on it and give it some solid polymer caps
    Code:
    6x 2700uF 2.5v X-CON ULR
    3x 2200uF 16v Samxon GC
    4x 820uF  4v Sanyo OS-CON SEPC
    1x 1500uF 16v Samxon GC
    8x 1000uF 6.3v Samxon GC
    7x 470uF  16v Samxon GC
    3x 220uF  16v X-CON ULR
    After recapping it works great, I will see when I have time if there is now more overclocking headroom, I would think there is...
    Maybe I can also lower vcore now and still maintain stability
    The second pic I posted below as a thumbnail only shows locations of caps and their values...
    What was strange was that the caps I removed checked out ok for both capacitance and ESR, go figure, all where TEAPO except the 3 input caps for the CPU VRM (GSC). None where bulging...
    Last thumbnail to the right is an old before pic I found...
    Note; you can click image for a larger version
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: Epox 8RDA3+ Recap My First Poly Mod
    Congratulation
    Let's see if it last other 6 years.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • yanz
      • Nov 2004
      • 910
      nice work. it always a worthy recapping if it's an epox board..
      days are so short when you actually do something..
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Thnx guys
        Correction to the above from Big Pope, the 3 input caps for the CPU VRM are Samxon GD, not GC
        Btw, I was meaning to use solid polymers for the 4x 1000uF 6.3v caps around the RAM, but I was unable to fit the Sanyo OS-CON 820uF caps there because they where too thick (actually 3x OSCON's I could fit but the last one was impossible, so I used Samxon GC 1000uF 6.3v 8mm instead...)
        • sofTest
          • Aug 2008
          • 361
          Tjena.
          Good job. So Big Pope is in business? I sent him an email a couple of weeks ago for a quote on some caps, but hasn't received any answer. I've ordered the caps elsewhere after a few days without reply, so it doesn't matter any more. I'm not impressed by his interest though.
          Be a mensch
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Tjena
            Perhaps the mail was lost or something, he usually answers very quickly...
            • Big Pope
              Approved Vendor
              • Dec 2005
              • 426
              Originally posted by sofTest
              Tjena.
              Sorry for this, when you sent you me e-mail? and Which e-mail you sent? Thanks.
              My SAMXON Capacitors Database HERE!!
              X-CON is a new brand for SAMXON's Polymer Capacitors.
              • sofTest
                • Aug 2008
                • 361
                Sometime last week, with subject "Quote" or "Price quote". As I said, I've ordered the caps elsewhere on Monday, and received one of the lots today. I ordered from a couple of eBay vendors I hadn't purchased from before, and the Panasonic FCs I received today checked out OK. The other lot of Chemi-Con KZJs was confirmed shipped on Tuesday, so if they also are OK, I'm sett for caps for my current projects within the next few days.
                Be a mensch
                • zandrax
                  Hit and miss
                  • Dec 2007
                  • 1157
                  • Italy
                  Congrats Per: nice work. Keep us updated if the board OCs higher
                  Zandrax
                  Have an happy life.
                  • Big Pope
                    Approved Vendor
                    • Dec 2005
                    • 426
                    It is ok, wait for your e-mail soon. But, just remind you that KZJ and KZV have already discontinuation from Chemi-con snice July 2007.
                    • CapLeaker
                      Poly VVX-250 VOIP POE problem not booting fix
                      by CapLeaker
                      I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
                      Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
                      11-25-2023, 10:46 AM
                      ASUS P5GC-MX motherboard recap
                      by momaka
                      Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                      This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                      So here is what the motherboard looked like with its original caps:
                      CPU VRM area up close…...
                      01-27-2021, 11:59 PM
                      no-name Radeon 9600 XT recap and cooler
                      by momaka
                      I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                      This one was actually suggested to me by ChaosLegionnaire....
                      11-06-2020, 07:54 PM
                    • chth96
                      Can I replace KME cap with Samxon GF cap?
                      by chth96
                      Hello.
                      I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                      Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                      I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                      04-17-2024, 07:11 AM
                    • kotel studios
                      Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
                      by kotel studios
                      Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
                      Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
                      So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
                      What I've tried so far:
                      replace the original N-MOSFETs with beefier 60V ones for testing
                      Resolder the resistors near the Vcore Jumper block
                      Short Vcore...
                      05-25-2025, 01:46 AM
