Hello!
I have got a DFI Lanparty NF3 250GB motherboard, that have all of the capacitors failed, board still working.
I have read, that I need to match ESR, Capacitance, Voltage to have a quality recap, but with ESR im in a problem. 0.012 ohm is what i see on the vrm caps specs, but lowest I could find is 0.018 and up, usually 0.04. Can someone help me find good replacements?
I'm located in EU, and I have found a guy here on the forums who listed the caps, so here are they:
- 20 x Nichicon 1000uF 6.3v HM 105C
- 5 x Chemi-con KZG 1000uF 10V
- 1 x Chemi-con KZG 470uF 16V
- 4 x Chemi-con KZG 1500uF 16V
- 6 x Chemi-con KZG 3300uF 6.3V
- 18 x Chemi-con KMG 100uF 16V
- 4 x Chemi-con KMA 100uF 16V
+there is 4 5m 10 16V smd polymer caps too.
Thanks!
Thanks!
