Logitech M305, optical LED went amber.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    I don't even know where to begin with this one.
    Its a constant amber color. It doesn't vary with temperature or use. Still works on white or yellow surfaces, but that's it. The LED package isn't yellowed or burnt.
    It seems like the phosphorus is poisoned or something. Anyody got any explanations? Seen this before?
    I'll post pictures of the inside once i find my jewlers screwdriver set..
    Follow the white rabbit.
    • 31046
    Re: Logitech M305, optical LED went amber.
    if it is phosphor-doped UV or blue die then it could have cooked the phosphor.
    but why the hell use that tech for red of all colours?
    • redwire
      • 3910
      I would say it's a red led that got zapped from ESD. I have seen that damage an LED and the colour shifts and it's dimmer.
      Or the bonding wire has lifted and made a current hot-spot which roasts part of the die, and you get shifted colour.
      Logitech M305 probably uses (looks like) Avago (Broadcom) optical mouse sensor. Maybe check the part markings. https://sensor.fyi/list/
      Avago spec a 5mm red LED 634nm for their sensors. Amber is around 620nm, IR LED's are around 940nm.
      ADNS-3050 is an example.
      ADNS-6010 is a laser type, but still red.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        ^ Hmm. I wonder if swapping it for a 640nm LED would work. 620nm does!
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          The sensor is an ADNS-5095. Opening it up i found some black oxidation on the leads of the LED, near the package. I think redwire is right, its been overheated.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Wowza.
            First time I see a mouse and an LED fail like that. (Most LEDs I've cooked - when I was younger and still learning electronics - just ended up burning until they got dimmer and dimmer.)
            ... then again, most of my mice are with a ball. No red LEDs or lasers.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Originally posted by momaka
              Wowza.
              I would think that LEDs with a missing phosphor, would be bluish or purplish!
              (Not HPS-like amber)
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
                LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
                This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                09-12-2024, 01:58 PM
              • Widget
                Logitech R20 speakers - Replacing one of the speakers.
                by Widget
                Hi guys,
                I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
                Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
                Printed on the back of the Logitech speaker is;
                LOGITECH...
                05-29-2024, 07:07 AM
              • shahnld
                Sony kdl 65xg9505 green amber blinking
                by shahnld
                Good Day.
                I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                01-03-2024, 03:05 PM
              • dreamlayers
                Weird clipping on Logitech Z-10 speakers
                by dreamlayers
                I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                05-22-2025, 11:41 AM
              • huzo
                HP 470 G5 blinking amber light no power
                by huzo
                The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                I've tried flashing the bios...
                interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                06-08-2023, 04:08 PM
