Weird clipping on Logitech Z-10 speakers
  • dreamlayers
    • Aug 2011
    • 8
    I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of the 3rd harmonic crosses over the original signal at 12 kHz and reaches zero frequency at 16 kHz. That means it is mixing with 12 * 3 + 12 = 16 * 3 = 48 kHz. Because 48 kHz is a common audio sampling frequency and the highest frequency supported by the USB audio interface, I don't think this is from power supply ripple.
    The harmonics and their images appear suddenly when digital input level exceeds around 74% of digital full scale. That makes me think "clipping", but it's kind of weird, with different distortion at different frequencies, not simply flat clipped tops. I'm attaching an image of the waveform at 1000 Hz, overlaid with my attempt to fit a sine wave to it. All of this is played via USB and recorded from the headphone jack. Looking at it with an oscilloscope I also see plenty of irregular high frequency noise that should be inaudible.
    According to https://www.badcaps.net/forum/troubl...akers-no-sound "The USB/DSP chip is a Micronas UAC3556B" and a UAC355XB datasheett is available at multiple sources, including https://www.digchip.com/datasheets/p...C355XB-pdf.php. I suspect one of the filtering capacitors attached to the UAC3556B chip is bad. These problems happen with both analog and USB sound input, and with both headphone jack and speaker sound output. The sound probably always passes through the UAC3556B chip, and the analog sound being digitized because the chip doesn't offer an analog sound path.
    The worst thing about fixing these is that the front is transparent plastic with a black backing. That plastic needs to be unglued without damaging the black backing. Then screws can be accessed and the rest should be straightforward. I put the speaker with the controls and electronics inside on a heating pad to hopefully soften the glue. I'm hoping to fix this, though if I can't, I can still use them but limit myself to the portion of digital full scale that doesn't cause this distortion.
    Edit: Heating it up on a heating pad worked well for softening the glue. Then plastic putty knives worked well for separating the front, though I needed to start at particular locations where it was easier. The touch controls were glued to the front, and fortunately I saw that early enough to avoid damaging the ribbon cable connecting to them. The LCD is not glued to the front.
    LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
    This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
    09-12-2024, 01:58 PM
  • Widget
    Logitech R20 speakers - Replacing one of the speakers.
    by Widget
    Hi guys,
    I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
    Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
    Printed on the back of the Logitech speaker is;
    LOGITECH...
    05-29-2024, 07:07 AM
  • Loki_Fido
    (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
    by Loki_Fido
    Hi folks,
    This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
    I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
    BIOS - XMC 25RU128CH10 (1.8v)
    What the heck is this? I looked all over the MB. This is the only bios.
    When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
    03-20-2025, 01:57 AM
    APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
    This started a few days ago and does this about every 8 hours
    After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
    The battery backup is about 3 or 4 years old
    Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
    06-02-2024, 02:30 AM
  • ugamazing
    820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
    by ugamazing
    So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
    1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
    2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
    04-10-2024, 08:06 AM
