Need help identifying a component. Supermicro X9DRL-iF
  • fety
    • Jan 2007
    • 27
    Sorry this isn't exactly cap related but I don't know where else to ask. I have a Supermicro X9DRL-iF board and the customer told me that a bad power supply caused these components to blow after he tried a 2nd identical board and the same components blew.
    I need your guy's help, can anyone tell me what these components are called? and where can I find replacements? He would like to get both boards working again. I can't see any markings on them, and I haven't desoldered them yet. I will probably desolder two good ones from the other board just to see if it will even work and worth pursuing.
    Thanks in advance!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Need help identifying a component. Supermicro X9DRL-iF
    They are ceramic capacitors
    • fety
      • Jan 2007
      • 27
      Thanks, is there a way to find out their values so I know what to look for?
      • R_J
        • 9607
        The ic's appear to be ISL6627CRZ, but the data sheet does'nt show the cap values.
        If you can't find the value, remove one of the good ones and check its capacity, I suspect the voltage rating will be low, 10 volts?
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Also check if the caps are connected to the CPU VRM low side (CPU V_core, which is usually 1.x volts) or high side (typically 12V). This will matter for choosing the voltage rating of the caps - for the high side (12V), a rating of 25V or more is recommended. For the low side, 4V or more would be needed.
          Probably best to remove one and check the capacitance (if you have a capacitance meter, that is). Otherwise, going by what voltage rail the caps are connected to, I find that high-side ceramic caps are typically 4.7 uF and low-side caps vary between 4.7 uF to 20 uF, depending on size and count.
          • fety
            • Jan 2007
            • 27
            Thanks for the info guys. Can anyone recommend a cheap but adequate LCR or capacitance meter? I found this on Amazon...
            https://www.amazon.com/dp/B071WNNYQT...1WNNYQT5497854
            Will it do what is needed?
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              For the price, I think that seems to be a pretty reasonable product, considering it's a dedicated LCR meter. Only downfall is that it only goes to 2000 uF, and lowest inductance scale is 200 uH. But not too bad.
              For the small ceramic caps talked about in this thread, this should work fine.
              On the other hand, I can't also help but also recommend one of those cheap "component/transistor testers" from eBay and AliExpress (typically $15 or less with free S&H). The nice thing about them is that they can measure ESR on capacitors as well - very helpful for testing electrolytic caps. They also offer higher range for the capacitance (I think 20000 uF, if not more). As for inductance, IIRC mine couldn't measure below 5 or 10 uH. So, similar to the LCR meter above, the low-range on the inductance isn't that great. But you do get transistor test functions as well.
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • ugamazing
                Assistance with identifying resistor value on 820-02918 A2992 board?
                by ugamazing
                Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
                I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
                09-06-2024, 08:33 AM
              • FeerBaron
                Got in way over my head with Supermicro server board and upgrade.
                by FeerBaron
                Last year I bought a server. It's worked fairly well but had some issues. Some pcie slots didn't work and Xeon v4 is a bit slow and missing AVX 512. Came to realize that the next version up, with skylake uses mostly the same chassis.
                A board popped up on ebay one day being sold for parts. A working board like this is over a grand at best. This particular one was about $125 and I decided to gamble.
                At first it seemed simple enough. According to the description it looked like some mechanical damage.
                Found the missing 560uf cap and thought I was...
                Starts
                01-26-2024
                Ends
                01-26-2024
                01-26-2024, 06:36 AM
