Hi all I have the above noted motherboard stated in the title thread. I replaced the two obvious blown caps on this thing and it still won't POST. I should add it says Dual Channel DDR 400 on it.
I also realized the pattern on the MOBO seems to be backwards. None of the caps were installed "correctly" ie the white negative strip on the caps with the white marking on the board where the caps should be.
The board doesn't shut off at all, the CPU chip seems to be getting voltage because it's warm after I take the fan off.
I tested all the other caps with the ESR meter all seem to be ok.. am I missing something or is it possible something else is kaput on this board? I've tried different CPU chips and RAM. The onboard and AGP and PCI video don't work either.
Any ideas?? Thanks!
Any ideas?? Thanks!
