Asrock DeskMeet return of the bad caps
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    I have had good luck with asrock products but with that said I ordered a DeskMeet X300 to use up some other components I had laying around Ryzen 3600 GTX 1060. it comes with a 500w power supply built by CWT.
    I thought CWT would use good components but no the primary cap was ChengX and the secondary had lots of chengx and JunFu caps. hope it lasts awhile. I do have a 450w SFX silverstone with teapos on the secondary I could replace it with.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
  • dmill89
    • Dec 2011
    • 2534
    Re: Asrock DeskMeet return of the bad caps
    CWT has always been known to use garbage tier caps in their more "budget oriented" power supplies (as well as many of the OEM units they build where cost is of course a factor). Some of their higher-end units use all Japanese caps though. All those failure-prone Antec Smart Power units with fuhjyyu caps from the early 2000s were built by CWT. They are generally decently built aside from the caps though.
    Even Delta and Seasonic often use sub-par (though generally still a tier above what CWT uses) in many of their OEM power supplies.
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3266
      • Singapore
      yea thats the way it is in the psu market unfortunately... either pay a founders price for a japcap psu or be pounded by junk caps! hehehe!
      u still have it with the original caps? thought u would have recapped it after the warranty expired...
      • dmill89
        • Dec 2011
        • 2534
        It has gotten somewhat better. 20 years ago, even the "top of the line" premium power supplies often used sub-par caps. Now at least the mid-level to high-end retail units generally use Japanese caps (probably largely thanks to the "capacitor plague" highlighting this issue and making "premium" caps a marketing point), though entry-level retail units and OEM units still often use lower quality caps.
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          Replaced emmc.
          Terminal log
          UART
          AC_ON
          E-B
          FDE enabled
          06-01-2025, 02:11 AM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
