Why I avoid Gigabyte
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Looks perfect, mainly Rubycon with some G-Luxon
    But won't P.O.S.T. - with or without battery fitted
    Possibly corrupted firmware in BIOS chip
    Any other board, pull the chip and rewrite with EEPROM burner
    Not an option with Gigabyte - they save what ? - maybe 5 cents per board, by soldering it direct
    Another Gigabyte to be cannibalised !
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • stevo1210
    • Oct 2006
    • 4156
    Re: Why I avoid Gigabyte
    Is the chipset fried by any chance? That would also cause what you said.
    I had a board similar to that one also by Gigabyte with a fried ICH5 southbridge and it exhibited the same issues. Fans would run but no POST.
    It too had Rubycon, Sanyo, Nichicon and G-Luxon caps on it.
    One sign that it was running was the fans spinning and the incredibly hot southbridge chipset.
    And yes, I also avoid Gigabyte boards because I've had a variety of boards from them which are utter crap.
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
    • Newbie2
      • Sep 2005
      • 885
      The board is probably dead. A failed northbridge or southbridge is probably the problem.
      I've had good experiences with GIGABYTE motherboards actually.
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Southbridge does not go over mildly warm - not the problem where you can burn your finger after a few seconds
        My issue with Gigabyte is when you do have corrupted BIOS firmware, there's nothing you can do about it, unlike most other makes, even cheapies like Jetway and PC Chips where the BIOS chip is socketed
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          yawn
          • davmax
            • Dec 2005
            • 899
            Perhaps you need to consider the current Gigabyte boards. In terms of bios they have dual bios so if one is corrupted the board will auto boot off the other. A leader in multiphase power and solid caps.
            Gigabyte EP45-DS3L Ultra Reliable (Power saver)
            Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
            160Gb WD SATAII Server grade
            Nvidia 8500GT 256Mb
            160Gb WD eSATAII Server grade for backup.
            Samsung 18x DVD writer
            Pioneer 16x DVD writer + 6x Dual layer
            33 way card reader
            Windows XP Pro SP3
            Thermaltake Matrix case with 430W Silent Power
            17" Benq FP737s LCD monitor
            HP Officejet Pro K5300 with refillable tanks
            • yanz
              • Nov 2004
              • 910
              Is dual bios really works?
              days are so short when you actually do something..
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                that board is known for failures in between layers under the nic or i/o chips.
                i have several in my scrap box.
                look for bubbling or discoloration under the chips.
                they also stink when they die.
                • stevo1210
                  • Oct 2006
                  • 4156
                  Wow, I didn't know that failures between layers actually exist. I thought they were a myth. I guess I have now been proven wrong.
                  As for discolouration of boards. I have seen many boards like that. In particular, Gigabyte boards. Though I have a Trigem board here with a similar issue as well. Usually they discolour under chipsets or MOSFETS probably due to the excessive heat those components emit.
                  • Wizard
                    • Mar 2008
                    • 2296
                    Poorly cooling with or without heatsink or using wrong TIM or not enough copper plane in ounces per inch.
                    I had a MSI board (socket 462 athlon) with MOSFET array (mosfet pull up x 3 and mosfet pull down to ground x 2), all gauged together by one controller IC, I THOUGHT it was 2 or 3 phase but it is NOT, just push-pull! Because it was hidden under a orange heatsink soldered down with double sided sticker tape. NO TIM! It went into trash after parts yanked off. VIA chipset also. Was working pull but wasn't 100% perfect. Occasionally annoyances.
                    Cheers, Wizard
                    • davmax
                      • Dec 2005
                      • 899
                      Yes dual bios does actually work. It happened to me last week. The bios had an error and boot was stopped with an error message then the system booted on the second bios. After that experience I reflashed the bios to make sure that I did not run out of bios.
                      Nvidia 8500GT 256Mb
                      33 way card reader
                      Windows XP Pro SP3
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Looks like HM ?? on the board too??
                        i845GV was a bad time/vintage to have HM's.
                        Gigabyte is same as Asus in my eyes. - Average.
                        Some good, some junk.
                        I have two GA-8IPE1000MK in service ~ a year and they are doing fine.
                        One had KZG in VRM Vcore side - replaced with MBZ as precaution before service.
                        Other had MBZ on Vcore as original.
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • pentium
                          • Mar 2006
                          • 2778
                          You make it sound like it's a commodity.
                          Find Nedry!
                          Check the Vending machines!!
                          <----Computer says I need more beer.
                          • Newbie2
                            • Sep 2005
                            • 885
                            Every GIGABYTE motherboard has the dual BIOS feature. IIRC, older GIGABYTE motherboard had two physical BIOS chips, but now on some motherboards (primarily the cheaper ones) it is "Virtual Dual BIOS" which works in a similar way but I don't see two physical BIOS chips on my GIGABYTE GA-P35-S3G motherboard.
                            IIRC, the newer motherboards (primarily the "Ultra Durable" series) still have the original Dual BIOS.
                            My gaming PC:
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              not really...
                              D = Ultra Durable (II)
                              L = Lite version of the board/bios
                              R = onboard RAID
                              i've got a (dead) G33-DS2R board. one 8MBit (1MByte) bios chip -> "virtual Dual-BIOS".
                              my new board (P35-DS4 Rev.2.0) has 2 chips... so a "real" Dual-BIOS
                              and it works fine
                              tried to put a new picture for the BIOS process (instead of the POST) in there with the gigabyte tool..
                              but the picture was somehow corrupted.. irfanview could still open it, but there was something wrong with it.. (but not the resolution or color depth)
                              well.. flashed the new bios.. no post... nothing...
                              turned off & on again.. waited a few seconds and it told me not to shut down the comp. because the backup bios is copied to the main bios chip...
                              after a "soft reboot" everything worked fine again...
                              • davmax
                                • Dec 2005
                                • 899
                                My current board has two seperate chips. I am wondering if the single package boards have two bios chips in that package.
                                I do have some Gigabyte concerns
                                1. The CPU temp reads low in bios eg 16C for 18C ambient with the base of the heatsink at 25C!!!!
                                2. My ICH10 chip runs at 50C with 18C ambient. Plenty of system fans. Not one on this chip, YET.
                                3. My other Gigabyte board had a memory controller error. Did not matter what memory modules were used or in what slot, always the same error. Replacing the board with my current one removed the problem. The faulty board is being claimed under warranty. Because the turn round is too long it forces the purchase of another board and sale of the warranty return.
                                Nvidia 8500GT 256Mb
                                33 way card reader
                                Windows XP Pro SP3
                                • stevo1210
                                  • Oct 2006
                                  • 4156
                                  I know exactly what you mean. I put my Gigabyte GA-8i945P-G motherboard into repair last year and it took 2 months to come back. Once it came back it was in a worse condition than before (even though it booted this time through). What they had done was melt the plastics in various sections of my board. I got fed up and bought an Intel DP965LT instead. Never been happier after that move. The new Intel board just.... works.
                                  Thanks.
                                  • bgavin
                                    • Jan 2007
                                    • 1355
                                    I picked up several Intel D875PBZ boards on a recommendation from Will... great boards. They are obsolete now, no longer leading edge performers. But.. they seem to just run forever. For business machine use, one can't ask for more.
                                    • toastygoodness
                                      • Jul 2005
                                      • 813
                                      i have enjoyed gigabyte's new ultra durable boards, mainly the P35 ones and the MA790X or MA790FX ones. the AMD chipset ones really do have physical dual bios, which are socketed on the many builds i have used. One time a customer was flashing his bios in the middle of a storm (yeah not too smart, but he kind of lost track of time) and the first one got corrupted. booted up, said there was a problem with the first bios and proceeded to boot from the second. i think it reflashed by itself. seems cool to me.
                                      to the OP, a lot of those 845 chipset boards (not just gigabyte) seem to have problems with the southbridge burning up.
                                      • stevo1210
                                        • Oct 2006
                                        • 4156
                                        I agree with you on that one. Intel made boards run practically forever. I've never had one dead before. I even have an Intel SE440BX-2 Motherboard from 1997 still running well until today.... and that's powering an internet firewall.
                                        • DynaxSC
                                          GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                          by DynaxSC
                                          I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                          General test conditions:
                                          - Tested with Core i5 6500 and Core I7 6700K - no difference
                                          - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                          What is wrong:
                                          With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                          When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                          03-21-2025, 06:23 PM
                                          Thermal pad thickness for various laptop GPU / Graphics Cards
                                          ASUS Dual RTX 2070 OC 8GB
                                          ASUS ROG STRIX RTX 3080 OC
                                          ASUS ROG STRIX RTX 3090
                                          ASUS TUF Gaming RTX 3080 OC Edition
                                          ASUS TUF GTX 1660 S-O6G GAMING
                                          EVGA RTX 3060 Ti XC GAMING 8GB
                                          EVGA RTX 3060 XC GAMING 12GB GDDR6
                                          EVGA RTX 3080 FTW3 ULTRA GAMING
                                          EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                          EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                          Gainward RTX 2080 Phoenix GS Specs
                                          Gainward RTX 3070 Phoenix 8GB
                                          Gainward RTX 3080 Ti Phoenix
                                          GIGABYTE AORUS RTX 3080 MASTER 10G
                                          02-09-2024, 08:08 AM
                                          A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                          by momaka
                                          More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                          And a shot of the label:...
                                          01-26-2022, 03:26 AM
                                          Gigabyte AORUS 15X Netbook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AORUS 15X Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15X boardview and 15X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte AORUS 15X Netbook...
                                          09-07-2024, 07:19 AM
                                          Gigabyte AORUS 15 Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AORUS 15 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 boardview and 15 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte AORUS 15 Notebook...
