Why I avoid Gigabyte
  • stevo1210
    • Oct 2006
    • 4156
    Re: Why I avoid Gigabyte
    Speaking of dual BIOS, I just purchased the Gigabyte K8NNXP and that has a dual BIOS system as well. It has two physical bios chips, just like my Gigabyte 8PE667 Ultra.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Originally posted by stevo1210
      I agree with you on that one. Intel made boards run practically forever. I've never had one dead before. I even have an Intel SE440BX-2 Motherboard from 1997 still running well until today.... and that's powering an internet firewall.
      I have 3 SR440BX boards I pulled out of W98 machines that were getting scrapped 3-4 years ago. They still work fine. Just never had a use for them.
      Mann-Made Global Warming.
      - Dr Seuss
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        still satisfied with intel boards but they have shit distribution here. Intel should require shops to stock some boards if they want the procs. asus and gigabyte own the market here. intel still persist in the enthusist market also but no real success, bad reviews. amazing they cannot listen and do what the reviewers tell them.
        • bgavin
          • Jan 2007
          • 1355
          The best Intel boards I have so far are the D875PBZ you recommended to me. They are not the fastest on the block, but they are consistent.
          I've been getting a bad taste for Intel boards lately, after seeing those pieces of shit in the Gateway machines. No floppy controller, terrible reliability, slug-like performance, slow bus. And they have the P35 chipset installed. Go figure.
          Yes, the Intel board reviews seem to have a very consistent, negative tone. I like the ABit IP35 Pro at the moment, as it has none of the problems associated with the Gigabyte DS3 boards. The only downside to the IP35 is the PSU connector in the top NW corner of the board. This is a real bitch to access if you have a big Zipang cooler in an Antec P182 case.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Originally posted by davmax
            Yes dual bios does actually work. It happened to me last week. The bios had an error and boot was stopped with an error message then the system booted on the second bios. After that experience I reflashed the bios to make sure that I did not run out of bios.
            My biostar Tpower N750 only has 1 bios, but before it will run the bios it will check any usb mass storage devices plugged in for its specific bios. Right now, I leave my usb drive in all the time, and I backed up the bios to it using biostar's utility. So if the bios on the mobo goes caput, it will simply read it from the flash drive, and restore the bios. If you want to update the bios, you can either use the biostar utility, or put the update in the same file as the current bios, and reboot, it will update the bios using the flash drive, delete the old bios backup on the flash drive and create a new one.
            On another note, it has a AMI bios, and it has lots of features, including a full internet browser in the bios!!
            • gdement
              • Jan 2007
              • 690
              #26
              I am wondering if the single package boards have two bios chips in that package.
              It wouldn't need to be that complicated. It's probably just a flash chip with double the normal required capacity. The high address line would be tied low or high depending which BIOS image is selected.
              Many flash chips also support write protected sectors. They could be using that feature for the backup image.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                I avoided Gigabyte, because they seem to require a gazillion BIOS updates for them to work properly.
                I didn't want to take the chance with a GA-P35DS3, because of possibly being forced to drop in a Prescott for the motherboard to boot because of it not recognizing E2180s.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  um... the Pentium Dual-Core E21x0 is based on the Core2 series (in fact: its a Core 2 Duo with cut-down Cache.. thats it)...
                  same thing for the Celeron S4xx series and the Celeron Dual-Core E12xx.
                  it will even boot if the BIOS doesn't "know" the proc.
                  happened to me with my Gigabyte P35-DS4.
                  had to test a Core 2 Duo E8400 (Wolfdale) with it.
                  the old BIOS i was using at that time didn't recognize it correctly, but it worked fine.
                  • DynaxSC
                    GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                    by DynaxSC
                    I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                    General test conditions:
                    - Tested with Core i5 6500 and Core I7 6700K - no difference
                    - Default BIOS settings, but tried also altering several memory setting - does not change anything
                    What is wrong:
                    With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                    When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                    03-21-2025, 06:23 PM
                    Thermal pad thickness for various laptop GPU / Graphics Cards
                    ASUS Dual RTX 2070 OC 8GB
                    ASUS ROG STRIX RTX 3080 OC
                    ASUS ROG STRIX RTX 3090
                    ASUS TUF Gaming RTX 3080 OC Edition
                    ASUS TUF GTX 1660 S-O6G GAMING
                    EVGA RTX 3060 Ti XC GAMING 8GB
                    EVGA RTX 3060 XC GAMING 12GB GDDR6
                    EVGA RTX 3080 FTW3 ULTRA GAMING
                    EVGA RTX 3080 TI FTW3 ULTRA GAMING
                    EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                    Gainward RTX 2080 Phoenix GS Specs
                    Gainward RTX 3070 Phoenix 8GB
                    Gainward RTX 3080 Ti Phoenix
                    GIGABYTE AORUS RTX 3080 MASTER 10G
                    02-09-2024, 08:08 AM
                    A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                    by momaka
                    More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                    And a shot of the label:...
                    01-26-2022, 03:26 AM
                    Gigabyte 7X Notebook Specification for Upgrade or Repair
                    This specification for the Gigabyte 7X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7X boardview and 7X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte 7X Notebook is accurate,...
                    09-07-2024, 07:19 AM
                    Gigabyte AORUS 15X Netbook Specification for Upgrade or Repair
                    This specification for the Gigabyte AORUS 15X Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15X boardview and 15X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte AORUS 15X Netbook...
