Jetway 830 CF v3.0
  • elbtax
    • Apr 2008
    • 59
    Re: Jetway 830 CF v3.0
    Mr. Wilson,
    I have a Jetway 830cf. Removed bad caps to left of cpu fan about a month ago. (12 caps) Have to order new ones and forgot if they are all 2200uf,6.3v,105c, or if some were 1500uf. If u remember pls post for me. Thanks....
    • JEWilson
      • Sep 2007
      • 369
      • Scotland, United Kingdom
      Ok
      Here's what I have replaced
      12 of 6.3V 2200uF
      5 of 6.3V 1500uF
      1 of 10.0V 1500uF
      6 of 10.0V 1000uF
      1 of 16.0V 470uF
      Replaced them all with Panasonic FM
      • elbtax
        • Apr 2008
        • 59
        Mr Wilson,
        Thanks for the "recap" on the caps for the Jetway. U are correct on the MOBO being difficult to get a good solder joint. I recently capped an Acer S58M and it went without a hitch using 60/40. For the Jetway i got a 40w iron and am going to use the high-tech silver-bearing solder 62/36/2.
        Thanks again about the caps. I have CRS at 61 & need all the help i can get......
        • JEWilson
          • Sep 2007
          • 369
          FWIW
          Once you have replaced a cap...
          Before snipping leads, test physical integrity of joint(s) by
          moving the capacitor slightly.Just enough to test if
          the unsnipped leads move!
          Cap lead movement a particular problem with this mobo.
          Post solder joint, the connection should be shiny not
          dulled. Otherwise considered a cold or bad joint.
          HTH
          • elbtax
            • Apr 2008
            • 59
            Thanks for the info. Am just getting into repairing mobos & such. My brother did all that for me but he passed on at 54. My area is software. Started with plain DOS. Move to windows was excruciating. Anyway..Started this cause a friend gave me a 19"LCD TFT monitor that the power light would stay on but no screen. After two weeks of research on web & forums discovered it was due to "dry" solder joints at the inverters. FIXED!!! Now have a nice 19" LCD monitor. Thanks for your help. Have replaced the 3 bulging GSC Caps 1500uf, 6.3v, 105c. Had them on hand. Others are ok at this time. I have 7- 2200uf, 16v,105c , 1-2200uf,6.3v,105c vent?,1-2200,6.3v,105c, 3-2200uf,10v,105c to go where the 12 are to the left of the cpu. Will it be o.k. to mix the voltages like this? And also, what is a capacitor that says "vent" on it? It also has name of mfg. on it...
            • JEWilson
              • Sep 2007
              • 369
              #26
              Very probably the mfg of the cap - or, that is, crapacitors
              Good rule of thumb to stick with is;
              When doing a recap, replace them all with known good brands.
              For sure, it 2/3 have failed, the ESR on the others will point
              to problems, if not now, then very near in the future.
              To test the caps, if you have an ESR meter to hand, you
              can test the caps in circuit on the mobo. Also, can
              use the low ohms setting on a multimeter to determine
              if a capacitor has gone s/c or reads anything above
              a minimal (very) resistance.
              3.3V rail requires 6.3V capacitors
              5.0V rail requires 10.0V capacitors and
              12.0V rail requires 16.0V capacitors
              3.3/5.0 could use 10.0/16.0v respectively
              Never undervolt a capacitor on the equivalent rail, so...
              12.0V - no 6.3V or 10.0V caps
              5.0V - no 6.3V caps
              You can marginally raise the capacitor replacements such
              as 1000uF original, replace with 1200/1500uF
              Exercise caution- conduct your research and make sure
              you are replacing with the correct matierals.
              It is easy to make a mistake, such as correct polarity etc.
              Good Caps thread
              see further https://www.badcaps.net/forum/showthread.php?t=414
              Bad Caps thread
              see further https://www.badcaps.net/forum/showthread.php?t=388
              Also, search the forum, there is plenty of good advice and shared experience.
              HTH
              • elbtax
                • Apr 2008
                • 59
                #27
                Thanks....
                • elbtax
                  • Apr 2008
                  • 59
                  #28
                  Got all the caps in. No Go. Will not post. Cpu fan comes on, cd rom light, and hard drive light stays on. Green light on monitor never comes on. I think i need to go ahead and order the correct Caps and recap the board. Using a "hodge-podge" of diff caps seems not to work. Thanks for all your advice. Will have to order caps online since none of the local electronics stores have these specific caps in stock. Will let u know the coutcome after i recap with correct cap values. Thanks again....
                  • krazykev64
                    • Feb 2009
                    • 49
                    #29
                    Originally posted by JEWilson
                    Odd issue with this
                    Rec'd board dead - was recap city
                    Most of the caps required replacement
                    Anyway, recapped these with Pana FM
                    Got some memory from eBay
                    2 of Crucial 512MB PC133 ECC Unbuffered
                    Using MemTest86 v3.3 to test the RAM
                    1st stick inserted DIMM slot 1 - Ran Test 5 and 8 for 20 iterations
                    Took some time - but tested ok
                    2nd stick inserted DIMM slot 1 - Ran Test 5 and 8 for 20 iterations
                    Tests ok
                    Inserted both DIMMs in slot 1 and slot 2
                    Test 5 fails - get bad memory address recurrently
                    I suspect this may be more of a problem with the mobo as opposed
                    to memory.
                    Thinks I'll re-check the traces and cap ESR on the DC-DC regulator
                    for the RAM
                    Any suggestions?
                    i got a 830ch version and there was a total of 18 bulging and/or leaking caps. every cap on the board is a GSC. THIS ONES FOR THE BIN
                    • Wizard
                      • Mar 2008
                      • 2296
                      #30
                      Is the memory *known good* in other machine with this same tests? I don't trust ebay till I'm 100% sure *especially* the generic memory, and I still test to make sure with used brand name memory (like made by samsung, micron etc stickered on as OEM for other makers, not like kingston, OCZ etc).
                      One more thing, yes, do all the caps for the memory also.
                      Cheers, Wizard
                      • JEWilson
                        • Sep 2007
                        • 369
                        #31
                        Y - the memory in known good
                        Only seems to work with 2 of 128MB ECC Unbuff MSC branded DIMMs
                        in each slot. That is for ECC Unbuff memory of course
                        Don't appear to have the same issue with non-ECC DIMMs.
                        Odd
                        • chth96
                          How Can I test PWM DM0365R?
                          by chth96
                          Hello
                          I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                          So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                          I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                          I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                          06-18-2025, 04:14 PM
                        • khelane
                          test active pfc power with lamp test
                          by khelane
                          Hello
                          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                          Is there a way...
                          06-03-2025, 01:00 AM
                        • chronic519
                          Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                          by chronic519
                          Hello.
                          GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                          Found issue with a RAM block
                          Replaced, green lines gone.
                          Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                          Used a good card to test and same results low errors 32+.
                          I am just search for some form of command to do a full test on the GPU.
                          I just ran the mats command with my good GPU and passed after roughly 40 min.
                          The repaired one, ran...
                          05-20-2025, 07:56 PM
                        • SluggerB
                          Help with trying to fix phone that is not charging (Pics inside)
                          by SluggerB
                          I have two TCL A30 phones.
                          Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                          New Phone: Works fine, bought as a donor board to try and repair Old Phone
                          My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                          08-12-2024, 08:11 AM
                        • hemant_2222
                          Yamaha 2064 No sound but Test audio working
                          by hemant_2222
                          Hello Guys,
                          Greetings!
                          Hope you all are doing well.
                          I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
                          PCM1681DBQR - IC263 and it worked fine.
                          Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
                          11-01-2025, 11:20 PM
