dsi xl battery connector?
  • quiggy
    • Aug 2014
    • 136
    • United Kingdom
    I dont know if this is in the right place but I have a dsi xl and someone has ripped the connector for the battery straight off the board. They probably tried to pull it out instead of popping it out.
    Anyway, i cant seem to find a replacement connector anywhere perhaps they're called something else. Does anyone know anywhere that sells them?
    • 31247
    Re: dsi xl battery connector?
    it would help if you seperated the plug from the shell of the socket that it's still plugged into!
    it's probaby made by JST btw.
    • diif
      • Feb 2014
      • 6978
      • England
      Or cut off the connector and solder straight to the board ?
      • quiggy
        • Aug 2014
        • 136
        • United Kingdom
        I'm keeping it attached so I don't misplace it lol and I didn't actually think about soldering it directly to the board I just figured doing it properly would be a better option.
        Who are JST?
          • 31247
          http://www.jst-mfg.com/index_e.php
          • nojgib
            • Nov 2014
            • 30
            A lot of times that connector is not damaged and simply needs resoldered.
            • quiggy
              • Aug 2014
              • 136
              • United Kingdom
              Any rough idea what to be looking for on JST?
              It looks like a leg is missing on it to me when I look closely although it's one of the front 2 legs.
              If I were to just solder the wires on, how would I go about doing it? would I just attach them to the back 2 points with the positive and negative symbols? and ignore the front 2 points?
                • 31247
                yes, the front points are just to hold the connector down physically.
                btw, if you wanted to lookup the connector the first thing you need to know is the spacing between the pins.
                • quiggy
                  • Aug 2014
                  • 136
                  • United Kingdom
                  I managed to get it working, had to bridge a wire across the underside too to the positive point as there was no continuity, I had no idea what had gone wrong there but it all powers up now.
                  However the zif connector ( I think that's what they're called ) for the touch screen broke off so now I have the joys of attempting to replace one of those. Fun days ahead!
                  • mkdj
                    ASUS X571 no power : battery issue?
                    by mkdj
                    Mark and model: ASUS X571
                    Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                    Tests already made:
                    - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                    - I have removed...
                    07-14-2025, 09:16 AM
                  • techfreak9356
                    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                    by techfreak9356
                    I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                    09-14-2023, 11:10 PM
                    NVDC charger configuration...
                    11-05-2024, 03:28 PM
                  • ferah831208
                    Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                    by ferah831208
                    Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                    03-18-2025, 01:18 AM
                  • huzo
                    HP ELITE X2 1013 G3 weird battery issue
                    by huzo
                    Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                    01-31-2025, 12:09 AM
