WeirD ProBlem on On boARd...
  • wan901
    • Jun 2007
    • 69
    Guys'....i had a weird problem on this system... Gigabyte 946GCMX-S2 ,1 GB RAM (KINGMAX) , Dual-Core Processor E4400, 160GB Seagate SATA, Lite-ON DVD-RW,Normal PSU 450W max.... Okay lets started with the problem..... I had Continues short BEEP error....i take a look at the manual of the Gigabyte board its say the beep is POWER error....okay, so i changed the power supply, Mobo, RAM ,and processor.....tested and okay no more beep....in the next morning i test turn it on again the same problem cameback again "Continues short beep"...now had no idea withit ....Already have Power Regulator....so now wut Should i do next ?>?> Any Idea ???/
  • gonzo0815
    • Feb 2006
    • 1600
    Re: WeirD ProBlem on On boARd...
    What should this be? from my opinion a normal 450w PSU by todays standard is something real crappy.
    So you changed this "normal" PSu against a other "normal" one?!
    It is pretty much the case, that you replaced a junk PSU against another junk PSu with the expected result.
    State the detailed information of the label here, if you want to get an answer whether it may be your problem or not.
    • wan901
      • Jun 2007
      • 69
      Well....Its the new PSU i used...not junk one.....well when i replace the psu is still same brand but new still in the box.... ^_^ well....give me some opinion....
      • stevo1210
        • Oct 2006
        • 4156
        What brand is your PSU? and is the Gigabyte board the new board or the old board?
        • starfury1
          • May 2006
          • 1256
          Gonzo is referring to "QUALITY" of PSU used.
          A lot of El cheapo's claiming 450W 500W would be lucky to see 250W on a good day with a wind behind them (figuratively speaking)
          So what Brand and model were the PSU's ?
          Since you are using a Dual Core, what type of video card?
          I take it its this MB Here
          standard questions apply , is it a new build.... was it working fine before this.... did you change alter or update anything.
          The other thing I would do is re seat the connectors and make sure the on board ATX12* connector is seated properly (*see page 19 of manual)...also the video card etc
          (*it actually mentions if its not on or if the psu is not up to par it wont power up or will have issues and possibly not startup)
          There has been some comment on Gigabyte MB's failing too..so maybe your just real unlucky
          When I build a system I don't screw anything down tightly (MB cards I mean) ...I just leave it slightly slack to allow a little play while seating cards etc ...
          then nip them up, check and power up
          not saying this is your problem but it something that has to be ruled out as a possible cause since the symptoms (from what you say) point to a power issue.
          HTH
          Cheers
          • wan901
            • Jun 2007
            • 69
            Well....its was really fresh PSU that came out from a bx 2gether....well there is no Graphic card also then actually the PC is not mine...was my customer PC....well this is 7th time sent back to me with same problem... Continouse Short Beep error when my customer bring it back to me....well...when i need to boot to the windows...i need to reset the CMOS back....then the Mobo will be okay...hmmm...i have no idea already...lolz....Changed the Mobo...change the PSU...change the Processor , change everything....like wut i can say is Whole new pc give it to my customer already....after 3-4 day....the same problem will came back again.....wut im thinking is the Power Surge or Instabality Current ....is it supposed to be the error about ??? =_=
            • toastygoodness
              • Jul 2005
              • 813
              don't use the psu from a case. buy a separate from a good brand such as Corsair (reccommended for gaming), Seasonic (the OEM for Corsairs), or FSPs. the lite-ons and deltas you can use though. nothing that says ISO, or Deer, or L&C, etc.
              • gonzo0815
                • Feb 2006
                • 1600
                Why don`t you put the sticker information from your PSU in here? Is it that hard to understand that no one can do anything with such descriptions like "really fresh PSU" or "old PSU" or "new PSU"?
                Just take the manufacturer and model from the picture on the PSU and we may help you.
                But without this information it is a wast of time.
                But if you pulled it from a case, there is not much hope, that this PSU is in any way suited for your system.
                • toastygoodness
                  • Jul 2005
                  • 813
                  actually i bought a few gigabyte cases for my customers and they came with Delta power supplies. thought that was pretty good for a case psu.
                  • starfury1
                    • May 2006
                    • 1256
                    This is not to say the psu is the issue, but its a good starting point since what you say and what they say is pointing to a power issue.
                    since you changed everything with same brand model (mostly) and had the same issue all I can assume is there is some sort of mismatch and the other thing you mention is that it was at a customers place...slim I know, but I assume you run it up with his HDD with OS so maybe he has some corruption virus spyware...whatever.
                    Is this happening when windows goes into some suspend mode.
                    its somewhat ruling out a piece of hardware as being faulty if you changed most of it but still have the same issue.(since the chances are small both would have the same fault..unless it some design interaction problem unlikely but possible)
                    The other thing is possibly Bios maybe buggy....did both boards have the same BIOS is it the latest or does it have known issues.
                    (is there some some subtle thing happen between BIOS and OS that causing corruption since you mention resetting the BIOS)
                    You need to line up you ducks from most likely to least likely and knock them down one at time.
                    This sounds like a sticky one and its better if you can nail down the true nature of the fault, but sometimes you can fix something without knowing its true nature...trouble is its a potential issue waiting to come and bite you on the bum when you lest expect it.
                    me Id rule out PSU (by using a know quality one)
                    then rule out customer HDD by doing a fresh install on a new HDD
                    in the meantime Id look into possible bios issues and have an updated firmware ready to try (if there is one)
                    you say 7th time how long from the time he took it new till the first time it happen.
                    has this increased frequency wise.?
                    ( EG . like he took it, had it for 3 weeks no issues.... then it happen and now happens ever day or 2)
                    Ram, ram settings could cause boot problems but think you have ruled that out.
                    (and possibly better to only use on stick when trouble shooting)
                    I guess too there is some MB and Ram, brands types that are just not going to play together nicely...or may need a tweak to get them to work together happily.
                    Anyway I could totally be barking up the wrong tree and yeah not the guru.
                    But hope it gives you some avenues to look into,
                    Id like to think a decent PSU would fix your issue
                    but I am stating to thing it something more subtle.
                    listing the full system specs would help too , someone might notice a problem .
                    Cheers
                    • bgavin
                      • Jan 2007
                      • 1355
                      I worked a client yesterday with a regular, continuous short beep.
                      Bad keyboard.
                      Bug moved when I swapped the keyboard.
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • huj3r
                        Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                        by huj3r
                        Hi there!
                        I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                        Photo of the situation after the black shadow dissipates:
                        After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                        I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                        > This indicates HFR Communication error. [ HFR Communication...
                        08-15-2023, 10:55 AM
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • pkslowk
                        Debug Card Error Code and Solution
                        by pkslowk
                        Sr. Motherboard Debug Error Code Solution
                        1 Intel 845 E9 Bios Related Problem
                        2 Intel 845 D4 CPU Socket Related problem
                        3 Intel 845 37 Bios Related Problem
                        4 Intel 845 7C Bios Related Problem
                        5 Intel 945GCPE 34 Bios Related Problem
                        6 Gigabyte 845 2 Ram Related Problem
                        7 IBM Server A6 A7 Ram Mismatch Problem
                        8 Asus 845 29 CPU Related Problem
                        9 Lenovo I946 97 C-Mos Jumper related
                        10 Gigabyte 845 A0 CPU Related Problem
                        11 Asrock G31M-VS D7 Bios Related Problem
                        12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                        01-28-2021, 12:51 PM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
