Crack & Stink Gigabyte GA7N400 Pro 2
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 661
    • samsara
    Fired up a (Gigabyte GA7N400 Pro 2) motherboard that i had in storage, that was previously running OK
    Board on bench with good ram and psu, with just the power and power LED connectors connected and a stick of ram.
    Pushed power button fans started to spin then a couple of seconds later heard a crack sound (like the sound of a whip cracking) and then the smell of something that has burned, coming from the board.
    After searching for a couple of hours, with a strong light and magnifying glass, i couldn't see any sign of burned components, bulged or leaking caps.
    It wouldn't turn back on (even using a jumper across the 2 motherboard power-on pins), so i removed the connectors and 'paper-clipped' the earth and start terminals on the power connector, to get it going.
    Noticed the RAM LED on the board lighting up and then another 'crack' sound, so immediately stopped the psu.
    Since i couldn't find any noticeably burned-out components, i removed the CPU and the north-bridge, and didn't find any signs of damage there.
    So checked voltage on the motherboard power pins - 4.1v
    The south-bridge gets hot to touch - so power is getting to that
    Removed the 6.3v caps - they look OK, and charge up/discharge similarly
    What component, other than exploding caps, can make this crack sound, and burning smell with no visible signs?
    What would be stopping a jumper across the motherboard power-on pins, from activating the psu?
    TIA
  • selldoor
    Slow Learner
    • 7870
    Re: Crack & Stink
    pictures top and bottom - what surface are you working on.
    • socketa
      Asbelowsoabove
      • Jun 2014
      • 661
      • samsara
      Re: Crack & Stink
      Working on cardboard
      Photos here http://www.stillflowing.comze.com/gigabyte.htm
      (Have put the 3 X 6.3v caps back in - the 3 at the bottom of the heatsink)
      And have tried again with new ram/different slots/no ram,
      still now power-up
      you can see the green jumper on the top RHS, the placement of, which fails to activate the psu
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Re: Crack & Stink
        If it gets -too- hot to touch, usually means a deceased motherboard in my experience
        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
        • Agent24
          I see dead caps
          • Oct 2007
          • 4959
          • New Zealand
          Re: Crack & Stink
          With a noise and smell, something has definitely blown. Might have blown out the bottom where you can't see it though. Something like the VRM controller IC(s) perhaps.
          You could try checking all the MOSFETs for shorts.
          Also, please post photos on the forum for future visitors.
          -David VanHorn
            • 31045
            Re: Crack & Stink
            take the cpu out and look to see if it has surface-mount poly's under it.
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 661
              • samsara
              Re: Crack & Stink
              Did that already (in post #1)
              All the polys look good, thanks
              Have gone over the board several times, thoroughly, with a magnifying glass and see no signs of burned components or shorted/damaged traces
              Found this thread:
              https://www.badcaps.net/forum/showth...&highlight=462
              But, unfortunately, it went nowhere, unresolved, and ended with someone giving up and buying another motherboard (as so many of these discussions, on the internet, do)
              However, (and consequently), i see that the first thing to do (after a thorough visual inspection), is to test the pins that the psu plugs into.
              I think that a systematic approach is better than unnecessarily de-soldering mosfets at random, and and testing them
              So the first step is to do a power-pin test
              And now i see that there is a short on the main 3.3v rail (all 3 pins are shorted to earth).
              The other pins test open circuit, after (what looks like) some initial current to capacitors.
              Am thinking (but not sure) that maybe it isn't the input/output mosfets - because the psu fan spins, and the southbridge heats up, when the psu is jump-started.
              What would be the next logical/sensible step in testing?
              Seems that there is some faulty, burned-out, shorted-to-earth, component in between the power button switch terminals and the power supply, that is preventing mobo from being switched on.
              As requested, here is a photo of the motherboard
              • Agent24
                I see dead caps
                • Oct 2007
                • 4959
                • New Zealand
                Re: Crack & Stink
                You don't need to desolder them to test them for shorts. If they are shorted, they will show as shorted on and off board.
                -David VanHorn
                • c_hegge
                  • Sep 2009
                  • 5219
                  Re: Crack & Stink
                  Is it just me, or does the southbridge look slightly brown on top?
                  If you're only running the board for a few minutes, then the southbridge should hardly feel warm. If it's getting too hot to touch, then it's cooked.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16956
                    Re: Crack & Stink
                    the southbridge has defintely been hot.....but that's not uncommon for a nforce chip.....but its definitely scorched.
                    The fet circled in this image appears to be cracked....but it was hard to tell from the low res photo.
                    <--- Badcaps.net Founder
                    Badcaps.net Services:
                    Motherboard Repair Services
                    http://folding.stanford.edu/
                    Team : 49813
                    Join in!!
                    Team Stats
                    • socketa
                      Asbelowsoabove
                      • Jun 2014
                      • 661
                      • samsara
                      Re: Crack & Stink Gigabyte GA7N400 Pro 2
                      Appreciate you guys (which, of course, may include non-male guys) taking a look at this.
                      That fet is not cracked,
                      i think you might be looking at the shadow.
                      Also note that the photo didn't show the short middle drain pin (but it's there).
                      However, then had a look at the south-bridge
                      Rubbed finger across it and felt a very fine ridge on it's surface.
                      At first, thought it was the printing on the surface, but upon closer inspection there is, what appears to be, the tiniest little crack in it.
                      Previously didn't get spend too much time over it, thinking that the south-bridge controlled the peripheral ports - not the on/off switch that starts up the PSU
                      So is that a good sign that it's knackered?
                      Can i test it with a meter?
                      Can a such noticeable odor, come through such a miniscule crack?
                      Also tested the big mosfets, 3 of them had shorts, from drain to earth and from source to drain.
                      All 6 of them had shorts from source to earth
                      So are these last 3 OK because they don't have shorts from drain to sink and perhaps have their sources connected directly to earth?
                      For the sake of completeness, here is the visual of the suspected crack, that might have resulted from the audible crack - it's between the V and the I
                      • c_hegge
                        • Sep 2009
                        • 5219
                        That southbridge is well and truly cooked (and yes, that crack is all it takes to let out the magic smoke and give off that burned electronics smell). I'm afraid your board is cactus.
                        Just for future reference, we prefer images to be attached locally, rather than using 3rd party image hosting
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          yep, its buggered!
                          Follow the white rabbit.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4959
                            • New Zealand
                            Yes, it's blown, unfortunately. There is no test you could do that would tell you anything you don't already know. The only thing you could do is replace the chip (not worth the time and expense, unless you are rich and want to do it for 'fun')
                            And yes, burnt silicon always has that strong smell. You'll never miss it if you ever smell it again!
                            In general the VRM circuits have at least two MOSFETs (some have extra in parallel) in a totem-pole configuration, and the lower one has its source connected to ground, so that is normal - plus the other MOSFET would have its source connected to ground through the shorted one below it.
                            -David VanHorn
                            • socketa
                              Asbelowsoabove
                              • Jun 2014
                              • 661
                              • samsara
                              Thanks,
                              That took up two whole days.
                              Have got some spare parts now.
                              And seeing that the board came with a big copper heatsink and athlon xp3000, it might have being a gamer computer, and possibly, overclocked - would've that helped to cook the chip?
                              Bought it second hand, and had it lying around for a few months.
                              Turned it on, and a few seconds later, it went "crack", and the fans stopped.
                              (Just noticed that i used "sink" instead of "source" in the previous post.)
                              How do i upload images locally?
                              i checked the link properties of the last pic, on this thread, of the south-bridge - it appears to be local because the address is: https://www.badcaps.net/forum/attach...3&d=1404195288
                              If not, then i'm happy to give it another go.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4959
                                • New Zealand
                                I suppose it's possible that overclocking and overheating resulted in early failure of the chip, but as for the thing burning out completely, I don't know.
                                This FAQ here: https://www.badcaps.net/forum/showthread.php?t=1868 shows you how to attach\upload images.
                                -David VanHorn
                                  • 31045
                                  in my experience,
                                  unless you buy a server class board from someone like tyan,
                                  the chips either need heatsinks that arent fitted, or the heatsinks are too small.
                                  every board i get, i run for a few min and then do the finger-test.
                                  i usually end up changing sinks or finding some way to mount a decent fan on them.
                                  this especially goes for some of the newer intel chipsets - those bitches generate more heat than the cpu!
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    bad power supplies with +5stby overshoot and static/bad devices on usb caused most of those nvidia chip failures.
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16956
                                      Yup, you let the holy smoke out of the SB chip. its quite clear in that second pic.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • socketa
                                        Asbelowsoabove
                                        • Jun 2014
                                        • 661
                                        • samsara
                                        thanks all
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • DynaxSC
                                          GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                          by DynaxSC
                                          I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                          General test conditions:
                                          - Tested with Core i5 6500 and Core I7 6700K - no difference
                                          - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                          What is wrong:
                                          With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                          When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                          03-21-2025, 06:23 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
