Recapped VP6 posted once... :(
    Recapped my VP6 with the recap kit, didn't have any problems removing the old caps, I used solder wick (with a little flux wiped onto it) and it worked nicely. Used lacquer thinner to clean up the flux before installing new caps, cleaned up all the solder joints afterward, they all looked good, no cold solder joints, didn't get the board too hot either removing or reinstalling the new caps.
    Upon first boot, it posted fine, counted all the ram, saw both CPUs, etc, but I rebooted it before it tried to load Windows and reset the cpu speed to 100x7 for a pair of PIII700s, and warm booted it. Now it won't post, no beep, cleared CMOS, same thing. Can't understand if it posted once, wonder what happened to it that it won't post again? Only thing I changed was setting the CPU speed to 100x7 and set primary display to AGP. Clearing CMOS would have reset that to PCI, and also defaulted the CPU speed to 466mhz.
    Any thoughts or suggestions?
    FYI, I have had quite a bit of experience in electonics repair, and also worked building motherboards and all kinds of cards for IBM AS400 and RS6000 servers, worked on the wave solder lines, SMT lines, manual build, etc so I feel that I at least have a somewhat respectable clue as to how to do this kind of work.
    Thanks for reading...
    take out the cmos battery and wait awhile.
    i had a vp6 get into a bad state and removing the battery cleared it.
      can we see some pics of the recapping?
        Working fine now
        Oddly enough, it started going through post after letting it sit a few hours, but hung repeatedly with a flashing cursor where it would normally say "verifying DMI pool" and the last thing in the PCI register it saw, was the ACPI controller. I looked at the IRQ assignments, realized that there was no network controller. I thought hmm.... Took the NIC out of it, it went on through post and went to the desktop like there never was a problem.
        I flashed the bios with the yt_234 file, reinstalled the same NIC in the same PCI slot, and it has been working fine since doing this. Go figure!
        It doesn't freeze in windows like it did before, and I really didn't think I did anything wrong in soldering, I was very careful and cleaned it up really good, the solder joints look too good for that to have caused a problem. I thought well maybe there was something other than just the caps wrong with it, but it seems like it is fixed now, and running fine.
        Before I recapped it, there was only a fresh install of XP pro on a clean format, and I couldn't even open control panel and click on "switch to classic view" without it locking up. I mean every single time I tried that, it would lock up. Naturally, that's the first thing I did after recapping, and so far no lockups or any other problems whatsoever that I can tell.
        Now I can load some other apps and load Sandra as well, see how it does with the burn-in wizard, then see how it does with slight overclocking, etc.
        Glad I found you guys
