CMOS battery holder solder pad trace
  • Kemer
    • Apr 2023
    • 41
    • Turkey
    I will add a photo of HP 15 laptop mainboard. The positive side of CMOS battery holder solder pad has been broken. What I want to ask is, the trace of positive pole. If you look at the photo, you will notice red color "A" and "B" letters for two different shades of blue.
    Anybody help?
  • MobsterLobster
    ASUS FX505DT w/ FX505DD Mobo - Not Turning On
    by MobsterLobster
    As per title, when battery is connected or jack connected: keyboard light flashes once but cannot turn laptop on. Holding power button for 10 seconds then the KB backlight will flash again. Unknown history and signs of previous repair (jump wire from CMOS battery holder positive terminal to R2453, presume broken trace under it)
    Thermal camera at board, 3 points warming up (not hot, just warm). CPU, BQ chip and ethernet controller. I guess this is OK??
    - Ethernet chip I guess is powered for wake on lan functionality?
    - BQ chip is driving input mosfets
    - CPU warming...
    12-09-2024, 05:05 PM
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • corrize
    Best way to solder LVDS connector for beginner (and qfn) ?
    by corrize
    Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
    I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
    I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
    See the test :
    https://youtu.be/bNAzC-EvqHs?t=1767
    With hot air from bellow the board, that's...
    03-09-2023, 02:57 AM
  • magistertc
    CMOS battery drains quickly
    by magistertc
    This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
    as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
    Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
    Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
    configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
    07-06-2024, 09:55 AM
  • myth77
    UV solder mask - high temp resistent, recomendation?
    by myth77
    Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
    Is there any solder mask...
    03-28-2022, 04:04 AM
