Gigabyte EP43-UD3L stuck in POST
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8700
    I have a Socket 775 Gigabyte EP43-UD3L that gets stuck in POST - after displaying the POST screen it hangs. Swapped PCI cards, RAM, and CPU and it must be something on the the motherboard that's the problem.
    Supposedly this board uses all solid polymer capacitors.
    Anyone had one of these boards go south on them?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Gigabyte EP43-UD3L stuck in POST
    It's time to clean the board then reseat all cards and RAM!
    And if it's DDR 2 and have all slots filled, take out 2 of the RAM sticks, raise the VDIMM to 1.90V then put the other 2 RAM sticks back in and try again.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8700
      I had four sticks of DDR2 in it (2x2G PC6400 2x1G PC5300), removed the 2G's and moved the 1G's to the slots previously occupied by the 2G's - still same flaky behavior and still tends to hang in BIOS. I didn't try increasing VDIMM, that would not be a good sign that it had been working a while, and stopped working.
      (Though honestly it could be due to the 1G DIMMs going bad... hmm. They were HP/Micron DIMMs. I had removed the 2G DIMMs because they're G-Skill brand and I had RMAed one set before. I don't quite trust G-Skill.)
      Also forgot to mention the behavior is repeatable on a different PSU - I was using a OCZ SXS2 600W and repeatable on a cheapo raidmax (oh deer?) 380W, both tried without HDDs and PCIE video... Probably can safely rule out the PSU (I'm currently using the SXS2 with another motherboard successfully now)? I tried it with both my original-on-board Q9550S chip as well as a P4-650 chip, both would hang at the same spot in BIOS...
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        I had the same problem with a similar revision board and ultra expensive one.
        I did repair my mistake about getting a Gigabyte board by buying an ASUS.
        Problem solved.
        • c_hegge
          • Sep 2009
          • 5219
          ASUS are generally, much, much less reliable than Gigabyte. I rate them as being one of the worst. I use Gigabyte boards exclusively in new PCs. They almost never fail. ASUS, on the other hand...
          @eccerr0r: Will the board let you do a BIOS update? I'd give that a go. It's quite easy on those boards to do without booting into an OS
          • Kiriakos GR
            Banned
            • May 2012
            • 940
            • Greece
            This is topic is about Socket 775 please send due Paypal 200$ to me so to love back Gigabyte.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Definitely QFT. Asus has a lot of good socket 775 boards. Their P45 and P43 boards are good.
              Arc A770 16 GB
              • c_hegge
                • Sep 2009
                • 5219
                Disagreed. They've been junk since the early s775 days.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  That's because 2004s and 2005s were meh.
                  Arc A770 16 GB
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    ^ sorry, junk!
                    Follow the white rabbit.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      The P5Q series and Maximus II series weren't junk.
                      Arc A770 16 GB
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Dunno about the Maximus, but the P5Q series were junk, as was anything else with a P5_____ model. I've seen plenty of those die young.
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          alot of DOA on my end....
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            A lot of pre-2008 P5x had meh caps at best.
                            Most P5Qs have Fujitsu/FPcap caps.
                            Arc A770 16 GB
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8700
                              [Off topic on my own topic] I have here a bad Asus P5GD2 that a friend gave me sitting on the floor. He complained it wouldn't stop crashing and lo and behold it indeed crashes in the OS. Plus its silly power shield makes it just about impossible to desolder caps due to the immense power plane.
                              [back on topic]
                              Hmm... I never thought about that, the BIOS. The board would basically freeze, so I can't get into BIOS setup, I never tried firmware update. Sometimes it does get through that hang and will proceed to start booting, but then I shouldn't need to update CMOS config... And since the board is "dual bios" wouldn't the other copy do something?
                              Since this board was working, I never flashed BIOS on the board (don't fix what ain't broken). Pity it stopped working...
                              • c_hegge
                                • Sep 2009
                                • 5219
                                The other copy (Backup BIOS) will only kick in if the main BIOS is really wrecked. If you can get it to go past the POST, then try doing a BIOS update.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8700
                                  Well, finally I got some more information: if I disconnect all drives, SATA-IDE-USB and everything, the board will boot, get into bios, etc. I can even select to clear BIOS settings to defaults and it still won't accept any disks at all.
                                  No storage systems = useless :-(
                                  Except perhaps the only way I can boot it now is through PXE...
                                    master hoarder
                                    • May 2008
                                    • 12170
                                    ^ What about PCI IDE or SATA add-on card? If you have one, give it a try.
                                    Sounds almost as if something is wrong with the SB, since SATA, IDE, and USB are all implemented through that.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8700
                                      Well, almost 8 years later I try the board again... (PresHott installed)
                                      hey... it booted... What gives?
                                      Well, after getting shot down my my underclocked Barton that doesn't have SSE2, I tried to give this board a try with the 20GB IDE HDD that ran out of spare sectors and is "FAILING NOW". To my surprise, it booted up just fine (using the IDE port), oddly enough, and the RadeonHD 3650 that also wasn't in good shape seemed to power up without artifacts at least for now.
                                      Weird.
                                      Maybe the SATA ports are shot? But I had nothing connected to them...
                                      Maybe it will work fine once more and I should use it for my server again, really could use more PCI/PCIe slots... ahh PITA swapping...
                                        master hoarder
                                        • May 2008
                                        • 12170
                                        Re-reading the thread again... your original issue sounds similar to the one with my Pegaton M2N78-LA... which I haven't been able to figure out so far, but I highly suspect flaky CMOS chip on mine. Not sure how yours got better from sitting unused, though, as it doesn't really make sense. But maybe the little gremlins inside yours calmed down a bit.
                                        As for the artifacting HD3650... that will come back for sure, IME. Give it a few heat cycles or put under 3D load.
                                        IMO, not a good idea to use it for anything you care about / that will be hard to rebuild - at least not until you've used the motherboard for a while as a 2nd / test setup and gave it enough time to feel comfortable the issue(s) won't come back.
