Syntax s478 mobo random freezups - caps maybe?
  • Sparky
    High voltage
    • Jan 2007
    • 234
    Hey I have a Syntax socket 478 board with a celeron 2.5GHz in it that randomly will freeze up. It'll run fine for days or weeks (currently been on for a week and a half with no lockups) then have a fit of lockups, then randomly be fine again for an unspecified amount of time before having a fit again. Sometimes it just freezes up once then is OK for the next week. All very random.
    I've stress tested the CPU and RAM, changed PSUs, data cables, and HDs, and reloaded the OS. It still does it. All the caps look fine - no bulging or leaking - but I'm suspecting that they are not right.
    It isn't in an easy to get to spot right now but if I get a change I'll get the system out of its little hole and find out the make of the caps.
  • davmax
    • Dec 2005
    • 899
    Re: Syntax s478 mobo random freezups - caps maybe?
    Intermittent problems are very difficult. You are on the right track, check the cap brands.
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
    • Fizzycapola
      • Oct 2006
      • 423
      If you can use a program for monitoring motherboard voltages. Such as Speedfan/MBProbe/MotherboardMonitor. It theres much fluctuation when idle it could be hardware related.
      Heat and cold boots can cause lockups too & sudden rises or falls in temperature (i.e +-10oC/h)
      Rubycon Rubycon Rubycon
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        try getting the latest bios and flashing it.
        a pic is still worth a thousand words.
        time to pull it out for all to see.never seen a syntax board.
        • Sparky
          High voltage
          • Jan 2007
          • 234
          I am running the latest BIOS right now. I'm going to get into it this afternoon or evening to check the caps on it. After the weekend I'll have my camera with me hopefully and I'll snap some pics.
          • Galvanized
            • Mar 2006
            • 468
            Please do pull the board to get some good close-ups.
            You could offer us some proper pics, as well as give it a real cleaning / inspection.
            Love your sig, we fought for over a year at Anand's.
            • Sparky
              High voltage
              • Jan 2007
              • 234
              Haha yeah we did have our little disputes I just wish that I hadn't learned the hard way
              Anyway, I can't take pics of this board right now since I don't have my camera with me, but here is a list of the caps on the board.
              7x OST 3300uF 6.3V
              6x OST 1000uF 6.3V
              2x G-Luxon 1500uF 6.3V
              4x G-Luxon 100uF 16V (2 are half-height)
              1x G-Luxon 470uF 16V
              5x G-Luxon 22uF 25V
              None look bad, they are all sitting flat on the board and have flat tops.
              I'll post some pics after this weekend once I have my camera with me.
              • gdement
                • Jan 2007
                • 690
                Maybe a component is suffering from heat. Could also be some loose capacitors or other parts not making reliable contact anymore. If you already have the parts I'd probably go ahead and try replacing the caps, regardless of how they look.
                • Sparky
                  High voltage
                  • Jan 2007
                  • 234
                  I thought maybe heat, but it has done it when just turned on and nothing had a chance to get hot yet. I didn't see any dry joints on the board.
                  I think I have some more of those OST caps in a bag somewhere, I may just replace crap with crap and see if that fixes it
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
                  • EvazX
                    ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                    by EvazX
                    I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                    Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                    For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                    However, after some time, the replacement motherboard...
                    08-25-2025, 06:09 PM
                  • Cerberuska
                    Mobo MSI B550-A PRO password popup
                    by Cerberuska
                    Hello guys,
                    I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                    BIOS I updated to last one.
                    any suggestions?
                    And same thing for two different 5600G, and yes, MoBo supposed to support it.
                    Thank you...
                    11-10-2024, 01:23 PM
                  • Prosatanosz
                    Asus B85M-GAMER no hdmi output and random restarts
                    by Prosatanosz
                    Hi!
                    Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
                    10-19-2024, 05:27 AM
                  • mrsith
                    Dell G3 17 3779 - no display after mobo replacement
                    by mrsith
                    Hi guys,
                    I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                    Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                    04-30-2023, 05:11 AM
