ATI Radeon 9800XT 256MB Video Card Cap Fallen off and Inductor Missing
  • ComputerGeek
    • Oct 2011
    • 262
    Hello I have a ATI Radeon 9800XT 256MB Video Card that has one Poly Cap that has Fallen off and Inductor Completely Missing. I have the Cap but no Inductor, I know it was on the card at some point because I see the solder marks where it was. So I need a replacement and can't find anything on the numbers or what I look for on digikey. Here are two photos I think from the ebay link that the one that is missing is the same value as the one next to the cap that fell off.
    Thanks!
    http://www.ebay.com/itm/ATI-Radeon-9...vip=true&rt=nc
  • gilly1984
    • 751
    Re: ATI Radeon 9800XT 256MB Video Card Cap Fallen off and Inductor Missing
    Cant you just use any 3.3uh inductor if you know how much current runs through it?
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    • ComputerGeek
      • Oct 2011
      • 262
      I don't know thats why I am asking, I can't seem to find anything when I look up these numbers,
      3.3
      Falco
      0419
      THanks!
      • gilly1984
        • 751
        This guy says bridge it with coiled up wire.
        He gets a little flaming for it though.
        http://www.austech.info/electronics/...ication-q.html
        Sorry I am not much help.
        I had a look at a couple of old gpus I have but none have them type of inductors, would of sent you one.
        • ComputerGeek
          • Oct 2011
          • 262
          Thanks for trying though! Hopefully someone else will come along and make a suggestion.
          • ComputerGeek
            • Oct 2011
            • 262
            Anyone?
            • Gariarto
              • Jul 2012
              • 151
              Here's a few shots of a 9800 Pro 128mb. Can't be too far from the same reference design ? Lightings' not the best but I hope it helps.
              • gilly1984
                • 751
                3.3 UH, Just be sure to cover the amperage.
                I think max draw through agp is 9.2 amps and I have read the 9800xt only draws around 3amps.
                • ComputerGeek
                  • Oct 2011
                  • 262
                  I don't know what the amperage would be. I found this .pdf on Falco's Website.
                  https://cdn.badcaps-static.com/pdfs/...215548ed15.pdf
                  Dimensions seem to indicate that it is either SDIP0804LP or SDIP0804, however the markings are not the same. Any idea what the 0419 means on mine? Still should I use the specs on the Data Sheet to find a new one? It would be either D08037 or D08001 which are rated [5.90 | 15] [MAXIMUM ALLOWABLE CURRENT (Amps) ** | DCR (m½)] and have 70 as a ENERGY STORAGE LIMITS (μJ). Do I have to match all of those specs? Thanks!
                  • ComputerGeek
                    • Oct 2011
                    • 262
                    http://www.digikey.com/scripts/dksea...=0&ptm=0&fid=0
                    Would one of those work? The Amperage is only 5.4A. What about Current Saturation and DCR do I have to worry about them. The Minimum order must be 1 I don't want 500 of these things.
                    • selldoor
                      Slow Learner
                      • 7870
                      Originally posted by ComputerGeek
                      Any idea what the 0419 means on mine? !
                      Only a guess but it may be 19th week of 2004 production date.
                      • ComputerGeek
                        • Oct 2011
                        • 262
                        Would any of those work?
                        • ComputerGeek
                          • Oct 2011
                          • 262
                          Can anyone help me out with the last two posts above ^^^^
                          • tmiha71
                            • Apr 2010
                            • 130
                            Post (look at) back side of card, on some cards (other models), this inductor was omitted, and replaced with something like on the photo attached, and there is a posibility (if caps are not so low esr), that inductor was never there...
                            If ( missing ?? ) inductor is on 12V, max alowable current of 5.9 A is TOO LOW...
                            Try to figure out, is this part of memory supply, or core supply (to estimate max. consumption), then use formulas for calculating MAXIMUM current from LOAD current in DC-DC circuits (from 5V input, and from 12V input )...
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              It looks like the missing inductor is connected to that solid cap to the right of it. That cap looks to be a 6.3V cap, which would suggest it would handle something like 3.3V or 2.5V (likely) or possibly 5V (unlikely).
                              In this case, I would believe that 5.4A is plenty of current.
                              It looks like many in your digikey link would work, the falco datasheet shows 5.4A current and 15mOhms, so something like this:
                              http://www.digikey.com/product-detai...TCT-ND/3060316
                              should work.
                                Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                by momaka
                                Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                09-19-2021, 08:44 PM
                              • ein_individuum
                                Missing Capacitator Intel I9-12900KF CPU
                                by ein_individuum
                                I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
                                I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
                                Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
                                08-06-2025, 01:36 AM
                              • ugamazing
                                820-02020 PPBUS_AON missing
                                by ugamazing
                                Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                02-05-2025, 04:21 PM
                              • Bartoloni
                                Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
                                by Bartoloni
                                Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
                                everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
                                there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
                                replaced the capacitor (330) and the inductor (R15) without any change
                                any idea? very thank you!
                                input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
                                12-09-2024, 12:42 PM
                              • gurj1979
                                Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                by gurj1979
                                Hey guys.
                                Need help with this one.
                                Fan not spinning due to missing PWN Fan signal.
                                Also 5 seconds from powering up it freezes, unless in BIOS.
                                But as soon as Windows starts to load, it will freeze.
                                CPU is COLD / Room temp when it freezes.
                                I've replaced the CPU, same problem.
                                Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                Replaced fan - same problem.
                                Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                08-19-2024, 05:22 PM
