MSI MS-6368 mainboard freezes before loading OS
  • delaware74b
    • Apr 2009
    • 628
    Re: MSI MS-6368 mainboard freezes before loading OS
    The 4 solder holes in your last post look okay. Clean the board with a little 90% iso alcohol on a cotton swab and you're ready to reinstall.
    Some of the through holes I have done looked far worse than yours and they still worked. As long as you don't pull the via out of the board, you're good. I had pulled a via out of a cordless mouse when I went to remove the left button momentary switch. It had at least one layer between the top and bottom (D-OH!)
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
      master hoarder
      • May 2008
      • 12175
      Originally posted by gandhig
      1) Can anybody tell me what the colour(dark and light green) of protective lacquer on the mainboard signifies?
      light green = signal or voltage trace (essentially a wire that connects different components)
      dark green = no trace. Basically it indicates insulating material between the signal/voltage traces.
      There are many layers of this sandwiched in the board.
      Congrats on the fix, btw!
      • gandhig
        • Dec 2012
        • 12
        • India
        The snaps were taken before cleaning. i could find only 70% iso alcohol here and it was not removing the flux. A gentle rub with a fine tipped screw driver removed the flux, then i cleaned it with iso after which it looked a lot better. Are via and solder pads one and the same?
        Ran some DOS diagnostics from UBCD which turned out OK. i will run some more tests and boot from ubuntu live CD before attaching my hard drive(which is already in use in other system) with Win XP OS to this recapped board for final confirmation.
        • delaware74b
          • Apr 2009
          • 628
          Solder pads are what you solder components to the board's traces (think of traces as the wires).
          Vias are the tubes that go through the circuit board, connecting the various layers to the different components.
          Example: a via for a (-)capacitor leg connects the capacitor to the ground plane on the top side of the board and a layer in the middle while the via for a (+) capacitor lef connects to the plane on the bottom of the board.
          • gandhig
            • Dec 2012
            • 12
            • India
            Ok, got it. Thanks.
            • Kambi13
              Lenovo IdeaPad 100-15IBD Freezes when loading Windows
              by Kambi13
              Hi all, I have a Lenovo IdeaPad 100-15IBD, motherboard NM-A681 Rev1.0 that posts normally, all voltages ok, but when its starts to load Windows after a few seconds the spinning dots just freezes. Unplugged everything unecessary from the board, tryied different ram sticks with no avail. Tried also just booting from the usb stick and the issue persists. There's also an option in Bios to use Intel's UMA only, turned off secure boot also, and nothing...
              Please advice, thinking to ask Bios guru's to clean ME region, just to make sure it's not related
              Thank you in advance
              11-23-2023, 12:02 PM
            • Kambi13
              hp Pavilion X360 14-dh1017np freezes when loading Windows
              by Kambi13
              Hi, today on the menu i've got an hp Pavilion X360 14-dh1017np that had it's main power rail shorted with 4 blown 10uf caps and one of the DrMos.
              Replaced all, and now the laptop does power on, but when it starts to load Windows freezes within a few seconds.
              CPU VCore has 0.931v in first Coil, 1,045 in 2nd coil and the third has nothing. Resistance to ground is 3,1 Ohms, which should be ok, but when I measure in continuity mode from ground to one side of the coil the multimeter beeps. Could be because the treshold is so low that it actually gives it as short.
              This coil is...
              05-17-2023, 01:45 PM
            • Mirenia
              Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
              by Mirenia
              I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
              I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
              In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
              The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
              03-30-2025, 06:47 AM
            • orcic
              MASTER TL240 and new mainboard LW36BKC01
              by orcic
              I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
              The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
              After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
              Now I have some doubts about how to connect the new mainboard to the old power supply.
              First of...
              05-12-2023, 08:10 AM
            • Devonavar
              Vizio M43-C1 - How closely do I need to match the mainboard number?
              by Devonavar
              I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
              I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
              Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
              So, I've ruled out the PSU for now.
              The reboot loop...
              08-14-2022, 08:46 PM
