I have two blown caps on this graphics card. One labelled 'FZ77 1000 16v' and another labelled 'FZ77 10000 16v'. I assume the former is a 1000uf cap, but can the latter be a 10,000uf? All replacement 10,000uf caps I have seen are larger than the 10mm diameter of both the blown ones on the board.
Force3D HD4670
Tags: None
Re: Force3D HD4670
The 'F' suggests Sacon FZ series, which is VERY widely know to blowup on graphics cards!.Muh-soggy-knee -
Re: Force3D HD4670
agreed
There's no such thing as a 10,000uF cap on a graphics card. It must be a 1000uF 16V. Do you have a picture of the cap(s) in question?
Use http://www.digikey.co.uk/product-det...MPD-ND/2428114
or
http://uk.farnell.com/nichicon/uhm1c...16v/dp/1823807
or
https://www.badcaps.net/store/produc...roducts_id=174
depending on where you'd like to order fromI love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
sigpic
(Insert witty quote here)Comment
Re: Force3D HD4670
Even more so when they lack vent stamps
https://www.badcaps.net/forum/showthread.php?t=19521I love putting bad caps and flat batteries in fire and watching them explode!!
Re: Force3D HD4670
robertvan1:
If there are any more sacon FZs on that graphics card, replace them too!Muh-soggy-kneeComment
Re: Force3D HD4670
is there any way to tell if these are polys post-explosion?Cap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
Re: Force3D HD4670
Turns out they both did say 1000, I was just reading it wrong on one. Have ordered some replacement caps, wish me luck for when they arrive!Comment
Re: Force3D HD4670
I successfully recapped the card today and it's working great! Thanks for the advice guys.Comment
Re: Force3D HD4670
No Problem. I'm glad we could help out.I love putting bad caps and flat batteries in fire and watching them explode!!
by sam_sam_samHere is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel...-
by frannyjunkHi, my Vizio M60-C3 does not power on. No lights whatsoever. Upon opening up the TV, the power supply board has 4 bulging capacitors. Each is 1000uF 16V. I have read that one can use capacitors of the same uF and higher voltage rating, but is 1000uF 35V capacitor too high of a voltage rating? My local shop only has these higher voltage capacitors so would rather just buy the 35V variety if it is OK to use them.
Any thoughts if OK to use these higher voltage capacitors? -
1000uf 120v 46mmx18mm or something close, Thanks3 Photos
by awdrifterI just bought some 1000uF 10v capacitors from eBay to fix my Samsung 2220WM, but it seems like they are already bulging? Are they ok to use? Thanks....
by JunkrepairI'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
I found this nice little description of the conversion:
Calculating capacitor ESR from Tan(delta)
https://forum.digikey.com/t/calculat...-from-tan/2633
It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...-
- Loading...
