Chinese 845GL Motherboard [ Recapping ]
  • Amarbir[CDRLABS]
    • May 2012
    • 11
    • India
    Hi Guys ,
    My name is Amarbir and i am from india .I ran a Computer & Portable Audio store here [ That i have closed ] . Diversifying this financial year to " Data Recovery " and Sale Of Electronic Instruments And Tools and Also Repair and Maintenance Tools .I Will also Include Some Other Services Regarding Computer and audio that i might like later . Started electronics since class 3 as a hobbyist now i am 37 years old and still cannot get it off my head .I have a passion to collect good gadgets for helping me do my work and experiments .
    In my data recovery business we have some tools that work solely with some el cheapo chinese make motherboards .The chipset of the motherboard is 845gl .This motherboard has 20 capacitors in total .Here goes the list
    1 : 2200 micro farad / 16 volts X 2 Units
    2 : 2200 micro farad / 6.3 volts X 5 Units
    3 : 1000 Micro Farad / 6.3 Volts X 4 Units
    4 : 220 Micro Farad / X 7 Units
    5 : 100 Micro Farad / X 2 Units
    All are Caps With "HR" written on them ,have no idea who the manufacturer is .Anyways my observation is that the caps 2200 micro farad 6.3 volts and the 1000 microfard 6.3 volts are the once that go bad more often cos this board is always on when we are using these machines for data recovery .I Planned To change all 20 of them ,Is this a wise step or i should stuck myself to change just serial no 1,2,3 .I have a bunch of old 478 socket motherboards and i could take off good capacitors from there and put in this system .I would like to do this first so that i could start my two pc's asap .Once things are rolling i would like to order top grade caps with your assistance on the forums and then recap the same board again with those .The tools for Testing i have Are the following
    1 : Protek 608 Multimeter
    2 : Dick Smith Kit for ESR Meter By BOB PARKER Not The New Blue ESR Meter
    3 : Goot Soldering station
    4 : Quick Hot Air to preheat board at large ground plane .
    6 : Inspection Glass
  • Amarbir[CDRLABS]
    • May 2012
    • 11
    • India
    Re: Chinese 845GL Motherboard [ Recapping ]
    Well,
    No Response From such a Great Forum ? .any Clarification Needed
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      give us a pic of the caps in question. I'm not finding much on HR by itself
      • Amarbir[CDRLABS]
        • May 2012
        • 11
        • India
        Sir ,
        Today i Am sorting Out My 20 Years collection Of Caps .Will Get Them Out And Show It To The Forum Users .
        • c_hegge
          • Sep 2009
          • 5219
          I don't know what electronics suppliers are available to you in India, but I'm pretty sure Topcat (the owner of this site) sends caps to most countries. So, here's what I'd recommend to replace your caps
          1 : 2200 micro farad / 16 volts X 2 Units - https://www.badcaps.net/store/produc...roducts_id=167 (Assuming they are 12.5mm Diameter)
          2 : 2200 micro farad / 6.3 volts X 5 Units - https://www.badcaps.net/store/produc...roducts_id=168
          3 : 1000 Micro Farad / 6.3 Volts X 4 Units - https://www.badcaps.net/store/produc...roducts_id=131
          4 : 220 Micro Farad / X 7 Units - https://www.badcaps.net/store/produc...products_id=53 (Assuming they are 16V or less)
          5 : 100 Micro Farad / X 2 Units - can probably be left alone
          • Amarbir[CDRLABS]
            • May 2012
            • 11
            • India
            Sir ,
            initial plans are to use the spares i have in stock on the motherboards i have and the motherboards are head due to other issues other then caps
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              There was no real need for this post your question is a waste of time. You intend to
              recap 2 motherboards with bad caps with poor caps off other boards you already have.
              You dont really need any advice - just go ahead and do it and let us know how you get on.
              I suspect from your other post that you dont have any 220 uf caps and were hoping to use 330uf caps which have degraded to 220uf
              The only sound advice - recap with good quality caps has been provided.
              • Amarbir[CDRLABS]
                • May 2012
                • 11
                • India
                Well,
                No Way I Do Not Intend To Recap The Two chinese boards with el cheapo caps off other boards .I took out about a bunch of the boards and handpicked some good quality caps off boards like original intel And Some other brands and took out the caps from them .This is what i did today with all the support i got from the forum .I Decided I Would Just Recap The Following Once Only .
                I Tested Each Old Cap i took Out for the following tests .
                1 : Open And Short Circuit Test On a Multimeter " analogue One "
                2 : Capacitance Testing On a Digital Multimeter The Protek 608 Within 10% specs
                3 : Checked ESR value of all the caps that i intended to put online .
                I have completed the same and the boards are back to life ,I am just stress testing the same now .I did take some excellent pics off the process and hope to update them online if i do get the time .
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  keep in mind, just because its a 'good board' doesn't mean it has good brand caps. I've seen intel boards with cheap UCC KZG's before. Look for the following brands:
                  rubycon: "K" stamp
                  Sanyo: off "K" stamp
                  panasonic: wierd T stamp, how can I explain, ahh: http://www.rock-grotto.co.uk/v3v3/DSCF2152.jpg
                  Nichicon: X stamp, nothing between '04 and '06 on date codes
                  • c_hegge
                    • Sep 2009
                    • 5219
                    The problem HMs were '01 - '05
                    • Evil Lurker
                      Warranty Voider
                      • Feb 2011
                      • 454
                      I see nothing wrong with attempting to recap a socket 478 board with used capacitors as long as they check good for capacitance and ESR. Reason being that the entire socket 478 platform is pretty much near the point where it is no longer cost effective to repair with new caps. Of course other's opinions will differ on this, but considering how cheap LGA775 boards and used celerons are nowadays it makes no sense in my opinion to plunk down an hour's labor and $15-20 dollars worth of caps on some energy inefficient system that takes overpriced RAM, uses underhorsepowered AGP graphics cards, and consumes two to three times the electricity of a newer platform.
                      • Amarbir[CDRLABS]
                        • May 2012
                        • 11
                        • India
                        Sir ,
                        You Missed This from my first post "In my data recovery business we have some tools that work solely with some el cheapo chinese make motherboards .The chipset of the motherboard is 845gl ."
                        • Evil Lurker
                          Warranty Voider
                          • Feb 2011
                          • 454
                          Originally posted by Amarbir[CDRLABS]
                          Sir ,
                          Oh ok I think I understand now... so what your saying is you have a lot of very expensive software that when the motherboard dies, the software dies too because the two are "married" and you can't install the software on any other machine because of anti-piracy or licensing protections built into the software.
                          If that is the case then money is no option contact the owner of this forum Topcat for replacement capacitors. Yes you can probably source them cheaper and faster in your own country, but if you purchase them here you are guaranteed to get first quality genuine Japanese manufactured capacitors which could save a lot of headaches down the road. Also you may look into purchasing used boards in working condition locally and swapping BIOS chips if you need an exact replacement.
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            i'm curious as to what the name of these tools are
                            • klkmalik
                              seeking Tips
                              • Nov 2011
                              • 68
                              • UAE
                              All cap available in india, but you need low esr and 105'c should be replace all new caps.
                              because caps are using in electronic circuits day by day and year , changing value by heat.
                              • noppa
                                • 41
                                PCI 3000 (Chinese)
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  I think it should work with any intel 845 based chipset.
                                  you can go through websites with old hardware listings and find model numbers, then maybe find what you need on ebay
                                  I certainly ran across tons of that shit in my time at goodwill
                                  • brethin
                                    • Dec 2008
                                    • 1907
                                    Well,
                                    I am sure you will get some helpful responses when you ask real questions with real details. I am not going to rip apart all your posts but things like "EL Cheapo Chinese made motherboard with 845GL chipset" doesn't tell us shit.
                                    Try providing Brand/Model names when asking for help, pictures are a plus too. When it comes to help with capacitors you need to provide more information than just the capacitance and voltage, again pictures are a plus.
                                    What we don't need to know is your resume and what tools (toys) you have.
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      actually I asked him what software he was using to come to the conclusion that consumer boards eventually die no matter how good or bad the caps are. hes going to eather find more 845 boards or move to something different in a few years
                                      • Taurus12
                                        Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                        by Taurus12
                                        Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                        I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                        i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                        Any recommendation on what I have to do next? Thanks in advance
                                        06-10-2025, 05:05 PM
                                      • Isabella91
                                        Possible to convert eMMC Socket to a micro SD Card socket?
                                        by Isabella91
                                        I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
                                        Read/Write a Micro SD Card from an eMMC Socket.
                                        I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
                                        Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
                                        Not to remove...
                                        01-14-2024, 05:10 PM
                                      • valente222
                                        help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
                                        by valente222
                                        Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
                                        05-12-2025, 03:42 PM
                                      • Altemon Moura
                                        Optiplex 3000 micro
                                        by Altemon Moura
                                        Unfortunately, when removing the chip
                                        (GIGADEVICE 25R256EYIG)
                                        It broke in the hot air.
                                        Will I be able to buy this same model?
                                        (GD25R256EYIG)
                                        "Can I burn the Bios?"
                                        motherboard
                                        DELL Optplex 3000 - 202040-1 D10NK$HA
                                        Optiplex 3000 micro
                                        Service tag: C7CG7T3
                                        SERVICE CODE: 26565563271​
                                        05-20-2025, 06:35 AM
                                      • tracks
                                        Dell 3080 Micro BIOS dead
                                        by tracks
                                        Hello all,
                                        I have a Dell 3080 Micro with a problem. As it is right now, it seems to be boot looping, maybe... There's no output, just fan on and power led lights up and blinks off every 2 seconds or so.
                                        Previous owner told me he bought it with a BIOS password, he tried to use a CH341A programmer with some random test clip and tried to mess with it while it was powered on. Now it won't boot.
                                        I tried to dump the bios with an EZP2023+ but I can't get a consistent read. Every time the dump is different, so it's unusable. I think the BIOS chip is fried.
                                        04-19-2025, 03:42 PM
