CDS‑200B ultrasonic cleaner - (other generic Chinese cleaners are somewhat similar)
  • itsthatidiotagain
    • Dec 2014
    • 39
    CDS‑200B ultrasonic cleaner - AKA James Ultra 7050 etc.
    There are many versions of cheap Chinese ultrasonic cleaners, and a fair few share this design, with a removable tank with handle. There are also fixed tank versions which look to use the same basic layout and presumably the same PCBs.
    I picked one up "spares or repair" on ebay, and the cleaner was dead, but the fuse wasn't blown.
    A quick diode check revealed D7 was shorted. D7 is a 12V 1/2 Watt Zener. I had one in my stash, so this was about as close to a "five minute repair" as they ever are.
    The Zener I used was a BZX79C12 but pretty much any 12v Zener of the same or higher wattage, which fits in the holes should do the trick. You may want to stand it slightly off the board to improve airflow and heat dissipation, as Zeners tortured in this crude way as voltage regulators do tend to get warm.
  • tricky74
    Chinese no brand ultrasonic cleaner
    by tricky74
    I bought an ultrasonic cleaner from ebay and after a couple of years it blew one of the driver boards fuse and a couple of diodes. I replaced the parts and it worked for a while then died again. Since then I have thrown out the board and just use one. The unit had 2 drivers and the good one drives 1 transducer only. The fried board was driving 2 transducers. The unit works on 1 transducer but is weak in power. I am tempted to connect the 2 transducers that were driven by the dead board. And leave the single disconnected. Not sure if it there is a fault in them and will just kill the driver. As...
    07-01-2022, 06:20 PM
  • diif
    Ultrasonic cleaner but a bit faulty.
    by diif
    After a not very cool noise and the display dimming my ultrasonic cleaner powered off. The display and fan work, just nothing happens when I press the ultrasonic button.
    I think it's at least the triac that is at fault (on the small PCB), showing 57 ohms between pin 1 and 3 and possibly one of the relays (marked in red), I was hoping someone might advise. Thank you....
    09-01-2020, 07:04 PM
  • valente222
    help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
    by valente222
    Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
    05-12-2025, 03:42 PM
  • AlexVG
    Replacing the WiFi module on a vacuum cleaner iROBOT i7
    by AlexVG
    I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
    I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
    (This board does not respond, only the LEDs light up in a circle.
    The liquid damage is catastrophic and restoration is impractical).
    (I bought this board to get the WiFi module and camera).
    The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
    If...
    10-22-2024, 07:20 AM
  • BalkanBoy
    Cypress CY8C27543-24AXI programmer
    by BalkanBoy
    Hi guys,
    I bought faulty Elmasonic S300H ultrasonic cleaner with shorted Cypress microcontroller which I replaced but now machine just turns on with every possible LED on and that's it more or less, it's unresponisive on any button pressed.
    I need dump for CY8C27543 which is my 1st problem, other problem is I don't know how to program it and if there's some universal chinese programmer available. I don't want to pay 200USD for original programmer I will probably use once in a lifetime such as Miniprog1 or newer.
    If anybody got experience with flashing...
    10-27-2023, 11:19 AM
