Keep It Simple
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Keep It Simple
    A while ago I was having problems with my "Neckwork." I run a Westel DSL wireless modem router. The wireless is disabled and I run it hard wired. My internet just got slow and then sometime later the modem kept dropping off and it would take the thing forever to find the DSL line again. Well I played around with all the software settings. This didn't change a thing. I checked the thing for bad caps and they were all good. My son the Comcast installer was going to drop a new linksys on me to try and fix my issues. Well I had another Westel single port modem router here so I hooked it up in place of the big westel for a test. It worked the same way. Next I checked the wire run from the phone plug to the modem. This is where I found my problem. At the time my wife had a new puppy. It had gone under here desk and used the DSL wire to cut its teeth on. That wire was torn to shreads. After switching out that wire my DSL worked fine again. My internet has been acting a little freaky the past week or so again. I checked the new wire and he has eaten that one up too. I think I'll wrap the next one in tin foil. That might stop him...I hope.
    Mark Twain
    John Paul Jones
    Rod Serling
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Keep It Simple
    neighbor had that problem.i put some daves insanity sauce on a rag and wiped all the wires behind the pc and ht systems.end of problem.easy to wash of later.critters hate that stuff.
    http://www.davesgourmet.peachhost.com/ct_PRdain.htm
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      Re: Keep It Simple
      Waste Dave's Insanity Sauce on a dog? Are you nuts! That shit is for me...LOL My Bullmastiffe loves anything hot. His favorite snack is hot chips or hot cheese curls. What a dog! There is only a small part of the wire run that the puppy can get to. I'm going to wrap the new one I have in Tin Foil. He just may chew a little but I think that the tin foil will put him off. As and added bonus I could always construct a little circuit car a car coil and a groud plate. That would fix him when he put his wet little mouth on the tinfoil wrap.
      Mark Twain
      John Paul Jones
      Rod Serling
      • c_hegge
        • Sep 2009
        • 5219
        Re: Keep It Simple
        I had a problem with our dog when she was a pup chewing the keyboard cables. I went through two keyboards in one week. We kept her out of the office untill she grew out of it. If she'd done it one more time I would have ended up getting a wireless one.
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          Re: Keep It Simple
          When my cat "LIL Bit" was a kitten she bit the wires off of three sets of head phones for me. One set she did in while I was using them...LOL These were not expensive ones. I buy them at the dollar store.
          Mark Twain
          John Paul Jones
          Rod Serling
          • ant3202
            • Jun 2006
            • 275
            • Singapore
            Re: Keep It Simple
            ideally if possible get a cable trunk to conceal those cables.
            check your main phone line for any noises, bad weather, etc can cause corrosion in the distribution panel and thus affect the connection
            • mattch
              • Mar 2010
              • 121
              Re: Keep It Simple
              once had a dog who did this to extension cords and power cords...
              we used tobasco, at first she hated it, eventually she got older and started liking it again.. shocking..
              • Junk Parts
                Court Jester
                • Jun 2006
                • 8953
                Re: Keep It Simple
                These dogs also chew live 110 volt cords right off at the plug! How the hell do they do it, and not let the magic smoke out of their bodies??????
                Mark Twain
                John Paul Jones
                Rod Serling
                • mattch
                  • Mar 2010
                  • 121
                  Re: Keep It Simple
                  hahaha they must have internal breakers and fuses on the main internal circuit
                  • Junk Parts
                    Court Jester
                    • Jun 2006
                    • 8953
                    Re: Keep It Simple
                    It must be something like that...These are little dogs too. We are talking about Chihuahuas, Pekinese, and Maltese critters here. They are about the size of a wild cotton tailed rabbits at best.
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                    • wnlewis
                      New wire for my RDE3340 Whirlpool electric range
                      by wnlewis
                      OK. I got the rocker switch figured out thanks to the good advice on this forum.
                      Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                      This is a Whirlpool RDE3340 electric range.
                      The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                      Where may I find parts...
                      01-08-2025, 11:21 PM
                    • emeskay
                      Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                      by emeskay
                      We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                      08-06-2024, 07:13 AM
                    • technicalspecialist
                      Vintage fan repair, copper wire question
                      by technicalspecialist
                      I currently have a customer's vintage fan on the work bench to repair.
                      It uses an induction motor with 4 poles. One of the poles is open.
                      I couldn't find the break so i cut off the original wire.
                      I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                      I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                      The enamelled copper...
                      03-16-2023, 12:54 PM
                      Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                      I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                      I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                      12-16-2023, 08:39 PM
                    • GlenBrim
                      1070 GPU. DVI port removed, wire in its place, why? Stuck on low clocks too.
                      by GlenBrim
                      I got this recently as-is. Gigabyte 1070 video card.
                      DVI port is removed. I don't know why.
                      A wire is soldered across two spots where it looks like the DVI port was. I don't know why.
                      I've read of people simply ripping out DVI ports and the rest of the cards still working fine. Never read anything about soldering a wire in there for some reason.
                      The card seems to work fine, except it's stuck in low clock speeds. While starting a game or benchmarking, the clocks may momentarily increase to around where they should be, then goes way back down and stays...
                      02-14-2024, 02:08 AM
