Can't connect laptop to hidden network
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. This issue has been driving me up the wall lately and I decided I'd have to discuss it with someone else, since I couldn't possibly solve it myself. I've got a laptop which refuses to connect to hidden SSIDs. It's a pretty nasty thing - it's got an Atheros wireless card on it currently...been through the "reflow" oven a couple of times, managed to bring it back from the dead a couple of times....that's beside the point. The point is I CANNOT get this thing to connect to hidden SSIDs: it always says "was unable to connect to"...I tried manually creating a profile, reinstalling the wireless card, even changing the card and nothing helped...it's got win7 Pro running on it. There's probably some small quirk that I'm missing, like you know when browsers refuse to display pages because the date is off - that sort of stuff.....any ideas ?
    Yes, if I unhide the SSID, it works and virtually every other device in my house works without a problem with it hidden. Please don't suggest unhiding the SSID and leave it like that...the question is why would a device NOT connect to a hidden SSID in general
    Wattevah...
    • 31214
    Re: Can't connect laptop to hidden network
    are you setting the channel number?
    if you arent broadcasting the ssid then how will the laptop know what channel to be on?
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      I managed to get it going eventually with a third WLAN card. How can you set the channel number in Windows ? I don't remember there being such option.
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        ..but now I've ran into another issue: it takes it a very long time after startup to connect on its own. It does it eventually, but only after like 3 minutes :|
        Wattevah...
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Sounds a lot like a bad cat. cable. Is that with wifi? If everything otherwise looks fine, then I would do a real-deal fresh reinstall of the OS! If it's with wifi, run a command prompt as administrator and run tracert!
          Reply with the tracert results. If there's packet loss, then you're on the same kind of boat as I was, which is most likely a bad wifi receiver and transmitter.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • diif
            • Feb 2014
            • 6978
            • England
            The channel is set on the transmitting device not the receiving. It's in the router settings.
            The question for me is why hide the SSID in the first place. It's more likely to attract skiddie hack attempts due to it being hidden and does nothing to improve security.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              I dunno...it's more of a mental comfort than anything, since I'm perfectly aware it's useless otherwise...I got MAC filtering going on too, which I reckon is a step-up.
              Wattevah...
              • diif
                • Feb 2014
                • 6978
                • England
                MAC spoofing isn't hard. A decent admin password and wifi password using WPA2 + AES is usually all you need.
                I think hiding the SSID has the opposite affect, it's more likely to attract attention.
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  Got that too
                  Wattevah...
                    • 31214
                    change the ssid to look like a printer or some other "connected" junk - that may put a few people off.
                    • TechGeek
                      Computer Geek
                      • Jan 2015
                      • 2254
                      Such as Nest-Thermostat-3
                      Permanently Retired Systems:
                      Kooky and Kool Systems
                      sigpic
                        master hoarder
                        • May 2008
                        • 12175
                        I had that happen today on a Windows 7 laptop that I was cleaning up too. But it only happened once. After I pulled up the wireless list and tried again the second time, it connected fine.
                        Meanwhile, none of my XP machines have ever had a problem with that. I'll just chuck that as another random Windows 7 bug that will probably never get fixed, among many others. Or is it not?
                        • howardc64
                          Samsung UN55JU650DF network/streaming problem
                          by howardc64
                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                          07-09-2025, 12:44 PM
                        • KYBOSH
                          Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                          by KYBOSH
                          I picked this one up today.
                          Previous owner says no signs of life.
                          TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                          Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                          The TV model is QN65LS03BAFXZA - version: CB06
                          The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                          I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                          Will keep you all...
                          04-05-2025, 08:32 PM
                        • japlytic
                          Maximum speed should be marked on network ports
                          by japlytic
                          I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                          One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                          12-19-2024, 05:04 PM
                        • An-klamm
                          Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
                          by An-klamm
                          Hello!
                          I have a TV that I can't get any further with.
                          It is a Samsung UE 55HU8590 with one connect box.
                          When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
                          As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
                          Since the TV works without ocb, I assume that it can't be the PSU?!
                          I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
                          Is there...
                          12-04-2023, 01:35 AM
                        • hikomalek
                          SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                          by hikomalek
                          Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                          When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                          Transformer:
                          |Info| Primary | Aux | AB | CD|
                          |Ratio|1|25|40|12|
                          |Voltage AC|230V|9.2V|5.8V|19V|
                          |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                          I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                          09-19-2025, 03:30 AM
