Locking out alternative router firmware...
  • japlytic
    • Oct 2005
    • 2086
    http://www.myce.com/news/tp-link-has...-dd-wrt-78623/
    Ever seen DearFCC.org? You have probably heard about this, but a number of manufacturers have stopped producing firmware updates for a particular model after a certain (and often short) time, which can leave networking equipment open to security problems because updates have been discontinued for the particular model.
    I believe that firmware updates should constitute being "spare parts", and that firmware should be updated for at least 5 years (or longer under national law) after the particular model has been discontinued.
    Also, I have read for the total lines of code, proprieatary software can have up to 3% with security bugs whereas open-source code has no more than 0.02%.
    So basically, the FCC rules can be a bit of a security risk to consumers.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Locking out alternative router firmware...
    Really they should separate the two pieces of firmware and be damned it costs more... because it'd cost more for everyone anyway.
    Just those people who don't care about open firmware and simply want to pay less for their routers...
      • 31198
      jtag or use the internal serial port to flash the bitches.
      • Spork Schivago
        • Mar 2012
        • 4734
        • United States of America
        I wish more companies would release their code open source once they discontinue their products (if they're not open source to begin with). I contacted HP once. I have a few of their wireless print servers. They said on the box they supported multi-function printers. To some degree, they do. But the printers I had, I could only print wirelessly, not scan. Since HP discontinued the models, I asked if they would release the source code to their print servers. Unfortunately, they said they couldn't because they didn't own the rights to all of the software. I asked if they could release the code with the parts they didn't have rights to removed but I never got a response.
        I did manage to dump the firmware using some USB JTAG device I bought. Boy was that an experience!
        -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
        • Spork Schivago
          • Mar 2012
          • 4734
          Is there a way to figure out the pin outs of the serial ports? It shouldn't be dangerous if you accidently switch the RX and TX lines, right? I think I found some serial lines on this wireless print server. Also, do you know of anyways to verify that they're actual serial lines? Would it cause any damage if they weren't? Thanks.
            • 31198
            the internal serial ports are usually 4pins.
            ground - obvious
            vcc - 3.3v or 5v usually - used to power your level convertor, not needed if your adapting to usb
            txd - easy to detect because when the router boots you will see data on it.
            rxd - the only one left
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              I just want to make sure people understand the problem:
              I'm sure most router manufacturers don't give a crap to what you do to their routers. The FCC doesn't care what you TCP/IP packets do on your router either. The FCC (and any other country that governs the airwaves) does care about what comes out of your antennas, however. The problem being is that someone, defaulting to the router manufacturer, may be liable for any damages caused by you inadvertently changing the software defined radio to interfere with something else.
              But you'll say "I'll be doubly careful..."
              No, FCC wants to make sure that there's a clear person to sue if someone comes to them and complains that their band that was allocated to them was infringed upon. Say you hack your router to use a cell phone band, accidentally or not... You could go claim innocence - "I just modified the firmware to change to $CUSTOMFIRMWARE... but I didn't know that it would interfere with terrestrial TV..." Multiply this by *EVERYONE* who downloaded the firmware and started interfering with bands they were not licensed to use. So they have to keep the genie in the bottle.
              If they kept the SDR software separate from the router firmware and do not allow updates to the SDR firmware, then all this would be skirted as the user now only changes the router portion, and not the radio. This unfortunately also prevents or makes difficult updates to the SDR in case a new algorithm comes out that's more reliable.
              Ultimately, yes, FCC wants you to simply toss the router when it no longer useful... As much as I want to be able to hack my routers or any other computer equipment, they have a case here. People who could arbitrarily broadcast on a shared medium must be licensed by the FCC (Ask amateur radio users, they know the rules of using radio, that's what the ham license is rewarded for). The reason why 802.11a/b/g/n/ac/... along with cellular phones and FRS bands is that the manufacturer/carriers vouched for the equipment purchasers (You!) won't go off their assigned frequencies.
              So really there are two solutions:
              1. Each person buy/use SDRs must get a FCC license to prove they understand the rules of the road for using the airwaves
              or
              2. SDR firmware must be locked.
              Fine grain locking (meaning, keep SDR software separate) might be the best overall though it costs more money to build the hardware this way.
              So don't complain about the FCC, don't complain about router manufacturers, complain to the people who want to pay as little as possible for a router.
                • 31198
                i think it's more that they dont want people region-switching to say "japan" to unlock extra channels.
                a number of router company's already have u.s. and non-u.s. firmware versions for download.
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  ground - obvious
                  I got two pads hidden under a heatsink that I suspect are the TXD and RXD lines. I have a TTL to serial converter. Would I need to use that? The GND and VCC I'll have to find somewheres else on the board.
                  I bet my new logic analyzer might help figure if they're TXD / RXD lines.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    Why don't they want people region switching to unlock extra channels? I know in the US, we have region locked DVD players. I think in other countries, like Australia, their DVD players have to be able to play DVDs from all regions. In the US though, it's kind of the opposite. I think here, it's mainly for money.
                    For the router, is it because the other channels are being used for other services in the USA?
                      • 31198
                      there are 14 wifi channels,
                      a lot of country's reserve one or more of those channel slots for government or millitary use.
                      not specificly for wifi - could be mobile-radio or anything really.
                      https://en.wikipedia.org/wiki/List_of_WLAN_channels
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        The DVD regions is purely for profit and control of such.
                        The Radio frequencies is regional because countries develop at different rates, and allocate spectrum different from each other.
                        Two different issues here.
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          Gotcha!
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            Yeah, I knew it couldn't of been for the same reason. Only reason I could think we were doing the region lock thing for DVDs was so companies could make even more money in the US by preventing other countries from making good movies and selling them here without paying lots of cash.
                            So, would China be more developed than us when it comes to electronics (including wireless technologies?) I believe I've heard some gamers say they have much harder video games over there but the players are generally better players.
                            For example, here, we had Super Mario Bros for the NES. There, they had Super Mario Bros and then Super Mario Bros - The Lost Levels. That Lost Levels game is crazy hard, especially compared to the first NES version of Mario. It never got released for the NES in America though.
                              • 31198
                              the u.s. is very behind most of the world actually.
                              and you can blame your government for refusing to adopt other people's standards.
                              an example, we had GSM cellfones in europe over 22years ago, because it was not a u.s. standard the u.s. stuck with analog for years.
                              even before GSM there was AMPS vs TACTS / ETACS
                              the world has DVB tv, the u.s. insisted on going with ATSC
                              https://www.chinavasion.com/digital-tv-explained.html
                              the shit goes on and on.
                              dont even get me started on Pal vs NTSC
                              what it's all about is simple, market protection.
                              the u.s. will never adopt some other country's standard because it gives the other country's manufacturers a headstart on equipment import and sales.
                              my giving the world (and the u.s. public) the middle finger, they create a u.s. centric "standard" for something and then give the spec to u.s. manufacturers like motorola before the rest of the world gets a look--in.
                              even when they do eventually follow the rest of the world they find a way to throw a fucking spanner in the works.
                              the u.s. GSM band is shifted 100MHz from the rest of the world, so you need a different tuner or firmware in the handset!
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                Huh, so it's all about the money, eh? I remember learning in History (way back in the day!) that China used to be superior in many ways towards the rest of the world. They blocked off the rest of the world and wouldn't import anything. Time went by, the rest of the world evolved and China didn't. They realized they were behind and decided to change.
                                I think it shouldn't be about all the benjamins but more about making the human race better. I guess I'm just a dreamer though
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Actually no, it's not the US adopting other people's standards, it's the US picking things first before thinking things through, and then other countries learning from the mistakes the US did... and after proliferation in the US, it's too expensive to fix the mistakes.
                                  Then the people in the US not wanting government control of things like forcing people to use metric, etc... let the free market decide, etc...
                                  *shrug* I'm stuck in the US, not much I can do...do I suck up to the free market or do I suck up to the government? Either way, it sucks.
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    I guess the nice thing about the US is things can change fairly quick like. That's also one of the problems though as well. Every four years, we can get another president.
                                    I think learning the metric system would be nice. They tried teaching us back in high school. We did a lot in the metric system, but we didn't really have to learn the basics. For example, if you tell me to go find you a piece of wood, 2 feet long by 4 inches wide, I could find it with no problems. But if you tell me to go find you a piece of wood 2 meters wide by 40 cm, I wouldn't have an idea what you was talking about. Like, I have no idea how big a meter is, nor do I have any idea how big most of the other metric units are. I think this is a flaw in the way they teach us and it needs to be changed before the metric system really catches on over here.
                                      • 31198
                                      what's to learn? it's just decimal.
                                      10mm = 1cm
                                      100cm = 1m
                                      1000m = 1km
                                      and such.
                                        • 31198
                                        just remember this:
                                        1foot = about 30cm
                                        so a meter = about 3.3feet
                                        or 3foot and 4inches
                                        • filippia1981
                                          Starlink WiFi router firmware of the HR1211 IC
                                          by filippia1981
                                          Hi, I would like to ask if someone has the firmware of the HR1211 IC of the Starlink WiFi router in order to program a new IC
                                          The diagnosis showed that this IC is shorted and need to be replaced with the right firmware. I cannot find the firmware
                                          kind regards
                                          Ioannis Balouktsis
                                          06-17-2024, 11:38 AM
                                        • TheUser
                                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                          by TheUser
                                          Hello to everyone ,
                                          This is my first post here, and i would like to share with you a small story in case you can help me.
                                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                          02-10-2024, 02:07 PM
                                        • zklgfs
                                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                          by zklgfs
                                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                          08-11-2025, 02:14 PM
                                        • double_DD
                                          Why does my ISP router hate my "homemade" power supply??
                                          by double_DD
                                          It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                          So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                          For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                          07-12-2025, 03:09 AM
                                        • gurj1979
                                          Ubiquiti firmware help. US-8-150W POE
                                          by gurj1979
                                          Hi guys.
                                          I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                                          Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                                          So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                                          Got New chip and writes good.
                                          THE PROBLEM...
                                          It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                                          Does anyone have a Good Firmware I can have?...
                                          07-22-2024, 05:13 PM
