Roku Won't Connect Error 014
  • ivtec
    • Dec 2008
    • 1967
    Hi guys i've got a Roku 1 and i have 2 routers one is Tg862 from xfinity and a second router Bufallo with Wrt software,i can connect to Buffalo with Wrt but i can't connect to xfinity tj862 my main router,i have error code 014.40,anybody know what should i do?
    I got this advice text from someone in the site with same issue that posted this solution bellow, what do you guys think,i don't want to loose speed?
    If your Roku won't connect to Xfinity modem / wireless router call Comcast Wireless 855-308-9453 and insist they set the modem to Channel 11 and also have them set Mode to 802.11 B/GN. This will save you 8 hourse of h*** like I went through.This worked for me as I am using ARRIS TG862 wireless router at 25Mbps speed. Can't vouch for other routers or speeds.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Roku Won't Connect Error 014
    What have you tried ? why the two routers ?
    Changing to a weird channel will do nothing for connectivity.
    • ivtec
      • Dec 2008
      • 1967
      Thanks diif; i did not try anything yet, i have the same issue (not that code but can't get wireless) with some of my old PC's under linux or Win XP, Win 7 or above is ok,
      that's the reason i have another Router, Buffalo with WRT software connected to Arris TG862 ,but i only can get 12MBPS out of the 30MBPS.
      I try to get in Arris TG862 but it doesn't let me,or i'm not doing it right!
      • ivtec
        • Dec 2008
        • 1967
        I'm also trying to set port forward following instructions here
        http://www.computerforum.com/threads...orward.232855/
        but my Default gateway is as follows, is this an encrypted default gate way #?see pic attach. any help here.
        • diif
          • Feb 2014
          • 6978
          • England
          Your gateway looks to be 10.0.0.1. Have you tried to login to that address ?
          Which device do you want to use for the wireless ?
          If i am remembering correctly when i upgraded my broadband router ages ago my XP machine needed a patch to get full speed. Windows 7 at the time did not.
          If you are not transferring files between machines the connection speed is irrelevant as it's faster than your net connection anyway.
          • ivtec
            • Dec 2008
            • 1967
            i 've tried 10.0.01. no avail.
            I want to use my roku 1 with the 30mbps that i have since i'm using the other router i only get about 12mbps
            • ivtec
              • Dec 2008
              • 1967
              Also this is my default gateway.
              • ivtec
                • Dec 2008
                • 1967
                Thanks guys i was able to get in with; http //10.0.0.1 name; admin, password;password
                now i have this page, what do i do next,thanks
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  If you are port forwarding, go here and select your router. http://portforward.com/english/route...is/default.htm
                  Port forwarding is under the Advanced tab.
                  • ivtec
                    • Dec 2008
                    • 1967
                    For now i'd just like to have my Roku working with Arris TG862,thanks
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Now you're in, you can configure the wireless settings.
                      • ivtec
                        • Dec 2008
                        • 1967
                        I tried a few things but nothing that i tried works
                        • ivtec
                          • Dec 2008
                          • 1967
                          Ok guys,you're not believe this, but actually one of the first letters of the password given by the installer was an 1 instead of an I, that i always used and it works on Win7 and win10 not in linux or xp,i don't know why?this mystery was solved because i checked the password in the router settings,check this pic,what would you make of thes 4 first letters?
                          • ivtec
                            • Dec 2008
                            • 1967
                            Ok guys,you're not believe this, but actually one of the first letters of the password given by the installer was an 1 instead of an I, that i always used and it works on Win7 and win10 not in linux or xp,i don't know why?this mystery was solved because i checked the password in the router settings,check this pic,what would you make of these 4 first letters CEIC? it is actually CE1C
                            i've been pooling my hair over this for more than a year,today i solved this weird mystery. Thanks folks for punting up with me.
                            • KYBOSH
                              Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                              by KYBOSH
                              I picked this one up today.
                              Previous owner says no signs of life.
                              TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                              Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                              The TV model is QN65LS03BAFXZA - version: CB06
                              The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                              I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                              Will keep you all...
                              04-05-2025, 08:32 PM
                            • An-klamm
                              Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
                              by An-klamm
                              Hello!
                              I have a TV that I can't get any further with.
                              It is a Samsung UE 55HU8590 with one connect box.
                              When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
                              As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
                              Since the TV works without ocb, I assume that it can't be the PSU?!
                              I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
                              Is there...
                              12-04-2023, 01:35 AM
                            • harp
                              simple win network with optimization issue
                              by harp
                              simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                              06-23-2025, 11:01 AM
                            • double_DD
                              Why does my ISP router hate my "homemade" power supply??
                              by double_DD
                              It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                              So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                              For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                              07-12-2025, 03:09 AM
                            • EazyBone
                              Samsung The Frame TV no power indicator issues diagnosing the one connect box
                              by EazyBone
                              I got a qn65ls03ta from someone who stated shows no power at all. They said they bought a fully new tv (same one) and tested the one connect box from the old one onto the new one and said it worked.
                              I have no reason not to believe them, so I crack open the TV and test for voltages on the main board. There are none. I can't get any voltage at all. (Power comes from one connect to Main board then sends power to additional power board for backlights I believe)
                              While doing some digging I found the connection to the one connect cable ON the main board seems to be missing small...
                              07-28-2024, 04:46 PM
